Roadblock trying to build from SVN with VS2005...
Trevor Wekel trevor.wekel at autodesk.com
Fri Aug 25 16:31:43 EDT 2006
Hi Jason,
The SQLite project piggybacks on the SWIG infrastructure used by the Web
Extensions.  You are correct, the common framework changes broke the
SQLite compilation.  I have just put a fix in under "MG371: Add
resources to Platform libraries, fix Sqlite compilation".  An SVN update
should fix the compile error.
Thanks,
Trevor
-----Original Message-----
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: Friday, August 25, 2006 2:13 PM
To: dev at mapguide.osgeo.org
Subject: Roadblock trying to build from SVN with VS2005...
Has the build order changed with the introduction of the common
framework, or is there an additional environment variable or VS setting
that I need to have?
When I try to build Oem (the first step in the docs) I get an error in
the SQLite compilation:
Error	1	fatal error C1083: Cannot open include file:
'MapGuideCommon.h': No such file or directory
d:\osgeo\mgbuild\oem\sqlite\src\sqlitephpapi\sqlitephpapi_wrap.cpp
62
Jason
More information about the Mapguide-internals mailing list
