[mapguide-dev] RE: Roadblock trying to build from SVN with VS2005...
Steve Dang steve.dang at autodesk.com
Sat Aug 26 02:02:07 EDT 2006
I've just reviewed/verified Trevor's fix (thanks Trevor!).
The Debug build should be fine now.
Steve.
-----Original Message-----
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: Friday, August 25, 2006 10:50 PM
To: Trevor Wekel; dev at mapguide.osgeo.org
Subject: [mapguide-dev] RE: Roadblock trying to build from SVN with
VS2005...
Thanks; I've switched to Release builds now, and was able to get
everything compiled.
Jason
From: Trevor Wekel [mailto:trevor.wekel at autodesk.com]
Sent: Fri 2006-08-25 4:46 PM
To: Jason Birch; dev at mapguide.osgeo.org
Subject: RE: Roadblock trying to build from SVN with VS2005...
Hi Jason,
Ok.  This one is caused by three template classes declared with missing
dll import/export attributes.  It works ok in a release build but fails
under a debug build.  I've just put in another fix.  Hopefully this will
clear up both build flavours for you.  You should be able to svn update
from just MgDev/Common.
This library is a support library for unit testing.  If you're not
running the Web Extension (Php) unit tests, you could comment this
project out of your build.  It's just a Php extension library that we
include to access the SQLite test databases under
MgDev/UnitTest/TestData.
Thanks,
Trevor
Sent: Friday, August 25, 2006 5:28 PM
Thanks.  Couple new issues now:
Error   1564    error LNK2019: unresolved external symbol
"__declspec(dllimport) public: void __thiscall
MgDisposable::SetRefCountFlag(void)"
(__imp_?SetRefCountFlag at MgDisposable@@QAEXXZ) referenced in function
"public: __thiscall Ptr<class MgLongTransactionData>::Ptr<class
MgLongTransactionData>(class MgLongTransactionData *)"
(??0?$Ptr at VMgLongTransactionData@@@@QAE at PAVMgLongTransactionData@@@Z)
SwigWrappers.obj
Error   1565    fatal error LNK1120: 1 unresolved externals
..\..\bin\win32\debug/php_SQLitePhpApid.dll
Jason
Sent: Friday, August 25, 2006 13:32
Hi Jason,
The SQLite project piggybacks on the SWIG infrastructure used by the Web
Extensions.  You are correct, the common framework changes broke the
SQLite compilation.  I have just put a fix in under "MG371: Add
resources to Platform libraries, fix Sqlite compilation".  An SVN update
should fix the compile error.
Thanks,
Trevor
Sent: Friday, August 25, 2006 2:13 PM
To: dev at mapguide.osgeo.org
Subject: Roadblock trying to build from SVN with VS2005...
Has the build order changed with the introduction of the common
framework, or is there an additional environment variable or VS setting
that I need to have?
When I try to build Oem (the first step in the docs) I get an error in
the SQLite compilation:
Error   1       fatal error C1083: Cannot open include file:
'MapGuideCommon.h': No such file or directory
d:\osgeo\mgbuild\oem\sqlite\src\sqlitephpapi\sqlitephpapi_wrap.cpp
62
Jason
To unsubscribe, e-mail: dev-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: dev-help at mapguide.osgeo.org
More information about the Mapguide-internals mailing list
