[mapguide-dev] Load Raster
Andy Morsell amorsell at spatialgis.com
Mon Nov 20 11:15:30 EST 2006
 You are posting to the wrong list.  These types of items should be posted
to the [mapguide-users] list.
But, have you tried adding that layer to one of your existing Sheboygan
maps?  It may show up.  When looking at the layer definition in Studio, it
looks like it is not recognizing the image extents for the preview mode, but
it may work just fine when actually part of a map with bounding coordinates
defined.
I'm cc'ing the users list on this so that the discussion can be continued
there.
Andy
-----Original Message-----
From: Albina Penitente [mailto:a.penitente at gepaspa.com]
Sent: Monday, November 20, 2006 2:41 AM
To: dev at mapguide.osgeo.org
Subject: SPAM-LOW: [mapguide-dev] Re: [SPAM] Re: [mapguide-dev] Fw: Load
Raster
Hi Paul
I have configured the raster
The raster are Sheboygan_000_001.tif   Sheboygan_001_001.tif
Sheboygan_001_000.tif   Sheboygan_000_000.tif
I think that the error is in the file config.xml
<fdo:DataStore xmlns:xs="http://www.w3.org/2001/XMLSchema"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xlink="http://www.w3.org/1999/xlink"
xmlns:gml="http://www.opengis.net/gml"
xmlns:fdo="http://fdo.osgeo.org/schemas"
xmlns:fds="http://fdo.osgeo.org/schemas/fds">
<gml:DerivedCRS gml:id="coordSys">
<gml:remarks>LL84</gml:remarks>
<gml:srsName>LL84</gml:srsName>
<gml:validArea>
<gml:boundingBox>
<gml:pos>-180.0 -90.0</gml:pos>
<gml:pos>180.0 90.0</gml:pos>
</gml:boundingBox>
</gml:validArea>
<gml:baseCRS>
<fdo:WKTCRS gml:id="coordSys">
<fdo:WKT>GEOGCS[&quot;WGS84 Lat/Long&apos;s, Degrees, -180 ==&gt;
+180&quot;,DATUM[&quot;D_WGS_1984&quot;,SPHEROID[&quot;World_Geodetic_Sy
+stem_of_1984&quot;,6378137,298.257222932867]],PRIMEM[&quot;Greenwich&qu
+ot;,0],UNIT[&quot;Degree&quot;,0.017453292519943295]]</fdo:WKT>
</fdo:WKTCRS>
</gml:baseCRS>
<gml:definedByConversion
xlink:href="http://fdo.osgeo.org/coord_conversions#identity"/>
<gml:derivedCRSType
codeSpace="http://fdo.osgeo.org/crs_types">geographic</gml:derivedCRSTy
pe>
<gml:usesCS
xlink:href="http://fdo.osgeo.org/cs#default_cartesian"/>
</gml:DerivedCRS>
<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema"
targetNamespace="http://fdo.osgeo.org/schemas/feature/rasters"
xmlns:rasters="http://fdo.osgeo.org/schemas/feature/rasters"
elementFormDefault="qualified" attributeFormDefault="unqualified">
<xs:element name="RasterType" type="rasters:RasterTypeType"
abstract="false" substitutionGroup="gml:_Feature">
<xs:key name="RasterTypeKey">
<xs:selector xpath=".//RasterType"/>
<xs:field xpath="Id"/>
</xs:key>
</xs:element>
<xs:complexType name="RasterTypeType" abstract="false"
fdo:hasGeometry="false">
<xs:complexContent>
<xs:extension base="gml:AbstractFeatureType">
<xs:sequence>
<xs:element name="Id">
<xs:annotation>
<xs:documentation/>
</xs:annotation>
<xs:simpleType>
<xs:restriction base="xs:string">
<xs:maxLength value="256"/>
</xs:restriction>
</xs:simpleType>
</xs:element>
<xs:element name="Image" type="fdo:RasterPropertyType"
fdo:defaultImageXSize="200" fdo:defaultImageYSize="200">
<xs:annotation>
<xs:appinfo source="http://fdo.osgeo.org/schemas">
<fdo:DefaultDataModel dataModelType="Unknown"
dataType="Unknown" organization="Row" bitsPerPixel="32" tileSizeX="128"
tileSizeY="128"/>
</xs:appinfo>
</xs:annotation>
</xs:element>
</xs:sequence>
</xs:extension>
</xs:complexContent>
</xs:complexType>
</xs:schema>
<SchemaMapping provider="Autodesk.Raster.3.1" name="rasters"
xmlns="http://www.autodesk.com/isd/fdo/RasterFileProvider">
<complexType name="RasterTypeType">
<RasterDefinition name="rasters">
<Location name="D:\Programmi\Autodesk\MapGuideStudio2007\SampleData\Raster">
<Feature name="Sheboygan_000_000.tif">
<Band name="RGB" number="1">
<Image name="Sheboygan_000_000.tif" frame="1">
<Georeference>
<InsertionPointX>215086,9080</InsertionPointX>
<InsertionPointY>178712,0510</InsertionPointY>
<ResolutionX>1,000000</ResolutionX>
<ResolutionY>0,000000</ResolutionY>
<RotationX>0,000000</RotationX>
<RotationY>-1,000000</RotationY>
</Georeference>
</Image>
</Band>
</Feature>
<Feature name="Sheboygan_000_001.tif">
<Image name="Sheboygan_000_001.tif" frame="1">
<Georeference>
<InsertionPointX>216221,9080</InsertionPointX>
</Georeference>
</Image>
</Band>
</Feature>
<Feature name="Sheboygan_001_000.tif">
<Image name="Sheboygan_001_000.tif" frame="1">
<Georeference>
<InsertionPointY>177716,0510</InsertionPointY>
</Georeference>
</Image>
</Band>
</Feature>
<Feature name="Sheboygan_001_001.tif">
<Image name="Sheboygan_001_001.tif" frame="1">
<Georeference>
</Georeference>
</Image>
</Band>
</Feature>
</Location>
</RasterDefinition>
</complexType>
</SchemaMapping>
</fdo:DataStore>
Can you help me?
Thank you
Alba
More information about the Mapguide-internals mailing list
