[mapguide-dev] mg version stamp
Walt Welton-Lair walt.welton-lair at autodesk.com
Tue Oct 31 18:08:38 EST 2006
Another thing to check is your server error.log (in your case under C:\Programmi\MapGuideOpenSource\Server\Logs).  Does it contain any error messages related to packages?
Or how about this: make a simple map using Studio or WebStudio, and then create a package with everything in your repository.  That package should then be listed under "Load Packages".  Then find out where on your computer the package file was actually written (search your drive).  It should be your Packages folder, but if it isn't then we have clue as to what's wrong.
Walt
-----Original Message-----
From: a.penitente at gepaspa.com [mailto:a.penitente at gepaspa.com]
Sent: Thu 10/26/2006 6:19 PM
To: dev at mapguide.osgeo.org
Cc:
Subject: RE: [mapguide-dev] mg version stamp
	Hi Walt Welton-Lair
	After clicking on Configure Package Directory and I am sure
	it's set up
	correctly, I attached file
	Another
	C:\Programmi\MapGuideOpenSource\Server\Packages\Sheboygan.mgp
	thank for help
	alba
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-internals/attachments/20061031/fb6ef22a/attachment.bin
More information about the Mapguide-internals mailing list
