[mapguide-dev] Build error in OEM\SQLite?
Trevor Wekel trevor.wekel at autodesk.com
Wed Sep 13 18:49:40 EDT 2006
Hi Jason,
I just put in a fix.  The SQLite project is only needed if you are
running the PHP unit tests.  It is not part of the Server or the Web
Extensions.  Thanks for the heads up.
Trevor
-----Original Message-----
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: Wednesday, September 13, 2006 2:43 PM
To: dev at mapguide.osgeo.org
Subject: [mapguide-dev] Build error in OEM\SQLite?
It looks like SWIG doesn't like the commandline parameters used to build
the SQLitePhpApi project.  Is this used?
Jason
More information about the Mapguide-internals mailing list
