[mapguide-dev] Metadata
Trevor Wekel trevor.wekel at autodesk.com
Mon Sep 18 17:21:37 EDT 2006
Hi Paul,
Yes.  You are correct.  The metadata system is intended to store a
free-form XML blob for a specific resource.  Resource content documents
are similar.  Each resource does have a specific XML schema but as far
as the ResourceService is concerned, they are just valid XML blobs.
Thanks,
Trevor
-----Original Message-----
Sent: Monday, September 18, 2006 3:13 PM
To: dev at mapguide.osgeo.org
Subject: Re: [mapguide-dev] Metadata
Jason,
I suspect that the metadata system they are putting in is more in the
line of free-form storage system associated with a resource rather than
a structured metadata standard (FGDC?) which you seem to think this is.
I could be wrong :)
For instance, the description of the MapDefinition that you enter in
Studio is stored in a metadata tag inside the actual XML representation
of the MapDefinition.
I think you raise an excellent point, though.  It could be very
compelling to have a real metadata capability inside MapGuide.
Cheers
Paul
On 18-Sep-06, at 4:17 PM, Jason Birch wrote:
> Hi all,
> I am concerned that by just storing Metadata as an XML chunk against
> resources, that it will be extremely difficult to manage on an
> enterprise level.  I may just be getting worked up about something
> that has already been considered but...
> A good metadata system should store at least organisation and contact
> information independently, taking advantage of a relational model and
> making maintenance easier.  Meta information stored against data sets
> should be composited on the fly into the required metadata standard.
> As well, metadata should not be limited to the information stored
> directly in MapGuide.  It should be possible to store metadata for
> external resources, including those referred to in load procedures.
> The metadata for the resultant data would then reference the source
> they were derived from.
> Hmm.  On the flip side, there should at least be the ability to parse
> and load XML metadata in standard formats, such as generated by
> ArcGIS.
> Jason
> To unsubscribe, e-mail: dev-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: dev-help at mapguide.osgeo.org
|Paul Spencer                           pspencer at dmsolutions.ca   |
|Applications & Software Development                              |
|DM Solutions Group Inc                 http://www.dmsolutions.ca/|
More information about the Mapguide-internals mailing list
