[mapguide-internals] FW: [mapguide-users] patch for Mouse WheelZoom, set scale and image on loading map in Ajax.
Tom Fukushima tom.fukushima at autodesk.com
Mon Apr 2 17:49:22 EDT 2007
Thanks for this Jason, I haven't been able to look at the users list for a bit.
Chris is looking into this and if it looks good, we'll put it in for the beta.
Tom
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Monday, April 02, 2007 3:22 PM
To: MapGuide Internals Mail List
Subject: [mapguide-internals] FW: [mapguide-users] patch for Mouse WheelZoom, set scale and image on loading map in Ajax.
How invasive are these changes?  Is it something that we could add to 1.2 during the beta stages? :)
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of José Manuel Cerrejón González
Sent: Friday, March 30, 2007 04:36
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] patch for Mouse Wheel Zoom, set scale and image on loading map in Ajax.
I've try to post the code in the internal list, but I don't how to register. Anyway here the code. I've applied the changes on the 1.0.2, but in the last version works fine.
Somebody who know how to do it, please e-mail me.
This patch use javascript to zoom with the wheel mouse, like in AutoCAD.
Another patch is to input in the scale bar, a scale manually.
You can see an icon in the toolbar when the map is loading.
All these changes in action here <http://wms.diphuelva.es/mapguide/phpviewersample/index.php> . Click on the help icon to see more features.
E-mail me with any problem.
Thank you.
[toolbar.templ]
In css:
        div.cssRefresh
            position: absolute;
            right:10px;
            top:4px;
The body seems like this. Rotating_arrow.gif is the image. You can design it or use the attached:
<body class="Toolbar" onload="InitDocument()" leftmargin=10 topmargin=0 rightmargin=0 bottommargin=0 marginwidth=0>
    <div id="divRefresh" name="divRefresh" class="cssRefresh"><img alt="loading" src="../phpviewersample/images/common/rotating_arrow.gif"></div>
    <span id="ToolbarContent"><td></td></span>
    <div class="TextMetricsDiv" id="TextMetricsDiv"><span class="TextMetrics" id="Metrics"></span></div>
  </body>
[ajaxmappane.templ]
About line 1350:
  if(requestObj.responseXML)
        var resp = ParseEnvelope(requestObj.responseXML.documentElement);
        if(resp == null)
            RequestFailed("Invalid XML response");
        else
            var frmParent = parent.frames ["tbFrame"];
            var objDivRefresh = frmParent.document.getElementById("divRefresh");
            if(objDivRefresh!=null){  objDivRefresh.style.display='block'; }
            panX1 = extX1 = resp.lowerLeft.X;
Line 1463 after the changes:
    if(safari)
        curimg = (curimg == "mapImage1"? "mapImage2": "mapImage1");
    if(objDivRefresh!=null){    objDivRefresh.style.display='none'; }
    return false;
Jose Manuel Cerrejon Gonzalez
jose.cerrejon at mapas-sll.com | gis at mapas-sll.com
I+D
MAPAS SLL <http://mapas-sll.com>
More information about the mapguide-internals mailing list
