[mapguide-internals] Raster provider problems...
Robert Bray rbray at robertbray.net
Sat Apr 7 11:10:41 EDT 2007
Ah thats too bad. I thought there was some way to limit the upper
connection limit on a per provider basis.
Bob
Bruce Dechant wrote:
> Limiting the pooling to 1 won't solve this as the server will simply use un unpooled connection on the 2nd GDAL request if the 1st is already in use.
> Bruce
> 	-----Original Message-----
> 	From: mapguide-internals-bounces at lists.osgeo.org on behalf of Robert Bray
> 	Sent: Sat 4/7/2007 12:03 AM
> 	To: MapGuide Internals Mail List
> 	Cc:
> 	Subject: Re: [mapguide-internals] Raster provider problems...
> 	Yea, guess you are right. For the vetted providers it could be marked
> 	per connection threaded, but we cannot blindly mark it that way.
> 	So that means there can never be more than one instance of the GDAL
> 	provider in use within the server. I wonder if we simply limit pooling
> 	on that provider to 1 if that would do the trick.
> 	Bruce what do you think?
> 	Bob
> 	Frank Warmerdam wrote:
> 	> Robert Bray wrote:
> 	>> Frank,
> 	>> Yes I am suggesting the server should take responsibility. At the same
> 	>> time I wonder if GDAL is not per connection thread safe. What that
> 	>> means is that the server will never use the same connection to GDAL on
> 	>> more than one thread at any give time.
> 	>> When you say GDALDataSet you mean the C++ object right?
> 	> Yes
> 	>  > Is a single
> 	>> instance of that ever shared between FDO Connection objects? If not
> 	>> then  the GDAL Provider can be marked as "Per Connection Threaded".
> 	>> The server as designed today will never assign an FDO Connection
> 	>> object to more than one thread at a time.
> 	> Frank wrote:
> 	>>> I will note that GDAL is threadsafe under certain restricted
> 	>>> circumstances:
> 	>>>  o Using only threadsafe vetted drivers (ie. GeoTIFF, HFA).
> 	>>>  o Only having a single thread touch any given GDALDataset at any
> 	>>>    one time.
> 	> So, to reiterate, GDAL could be marked as per connection threaded if
> 	> we know that only vetted drivers were going to be used.  But GDAL has
> 	> many format drivers, most of which have not been meaningfully vetted
> 	> for multi-thread safety.
> 	> Best regards,
> 	_______________________________________________
> 	mapguide-internals mailing list
> 	mapguide-internals at lists.osgeo.org
> 	http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
