[mapguide-internals] Session-MapName-Map
Paul Spencer pspencer at dmsolutions.ca
Fri Aug 31 14:35:07 EDT 2007
I'm confused about what supporting this in the server would mean.
Would this impact the scripting APIs at all?  What would it make easier?
Paul
On 31-Aug-07, at 2:27 PM, Trevor Wekel wrote:
> Hi Haris,
> The resource identifier is the Berkeley DBXML "key" for both the
> Library:// and Session:// repositories.
> Thanks,
> Trevor
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org
> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Haris
> Kurtagic
> Sent: Friday, August 31, 2007 12:21 PM
> To: MapGuide Internals Mail List
> Subject: RE: [mapguide-internals] Session-MapName-Map
> Hi Trevor,
> Yes leading path from Library is stripped (changed with Session ) and
> Name part is given by application like MapGudie Viewer for example.
> As you suggested application can use full name ( with folders ) or as
> Paul suggested hash the name or ..
> I have a feeling that server should return the key from db. In Map.cpp
> MapName is input parameter for creating entry in db.
> Haris
> Trevor
> Wekel
> Sent: Friday, August 31, 2007 8:08 PM
> Hi Haris,
> If you have the map definition
> Library://Samples/Sheboygan/Test.MapDefinition then the MgMap
> resourceid
> be default will be Session:xx-yy-zz//Test.MgMap.  The leading path is
> stripped.
> I don't know if we have folder support in the session repository
> but it
> would probably be better to construct the MgMap session using the full
> path.  Something like this might work:
> Session:xx-yy-zz//Samples_Sheboygan_Test.MgMap
> This would be an appropriate enhancement/bugfix request.  A search for
> MgResourceType::Map should take you to most of the code that would
> require change - DwfController.cpp and Map.cpp I believe.
> Thanks,
> Trevor
> Kurtagic
> Sent: Friday, August 31, 2007 11:40 AM
> Thank you, you are right on the track.
> Yes, you could change name as you suggested or use different sesion
> for
> every map or ...
> I would prefer to have a in server solution for this (and to be
> able to
> work with multiple maps in one session).
> Perhaps server could return DataKey from DB after creating new Map in
> it?
> Haris
> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Paul
> Spencer
> Sent: Friday, August 31, 2007 7:23 PM
> Subject: Re: [mapguide-internals] Session-MapName-Map
> Haris,
> I'm not sure if I really know what I am talking about here, but my
> understanding is that when you start up a session with a
> MapDefinition, you can save the runtime MgMap object to the session
> repository as a Map resource and give it a name at that time.  The
> name is arbitrary, but in the case of the AJAX viewer it is
> predictable from the MapDefinition name and I think you are right
> that it would either blow away the existing Map or conflict in some
> way.
> I'm not sure how the existing viewer works, but it doesn't contain
> the capability to change maps at run time so it would never run into
> this issue.  In Fusion, we can load different MapDefinitions at run
> time and we do something like this when the user wants to load the
> map:
> /* $mapid is a string resource id Library://... */
> $resourceID = new  MgResourceIdentifier($mapid);
> $map = new MgMap();
> $mapName = $resourceID->GetName();
> $map->Create($resourceService, $resourceID, $mapName);
> $mapStateId = new MgResourceIdentifier("Session:" . $sessionID .
> "//" . $map->GetName() . "." . MgResourceType::Map);
> $map->Save($resourceService, $mapStateId);
> (NB: there is a potential problem here if the map name is the same as
> one already in the session.  I will need to fix this potential bug in
> Fusion - I will probably use an md5 hash of the string version of the
> full Library:// path to the original map.  This would probably look
> like:
> $mapName = md5($mapid);
> and the rest of the code would look the same.
> We return the $mapName to the client so that subsequent requests can
> operate on the the appropriate Map object on the server side using
> something like this:
> $map = new MgMap();
> $map->Open($resourceService, $mapName);
> The mapagent rendering operations take the session id and the map
> name to render map images and dynamic map overlays.
> Does that help?
> Cheers
> Paul
> On 31-Aug-07, at 1:05 PM, Haris Kurtagic wrote:
>> I would appreciate if someone could help me to clarify
>> Session-MapName-Map interaction.
>> Now how MG Viewer-Server  is working is that it will create new
>> session
>> and read web layout and create a runtime map in session repository.
>> Later runtime map is accessed by name (only name part of it) from the
>> session repository.
>> So, if I would have two Maps created in Library in separate folders
>> with
>> same name and if I would add the second map to session repository I
>> could not access both Maps ( because Session Id and MapName are
>> used to
>> identify it - and they are same).
>> Am I right about this ?
>> Thanks,
>> Haris
>> mapguide-internals mailing list
>> mapguide-internals at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
> |Paul Spencer                          pspencer at dmsolutions.ca    |
> |Chief Technology Officer                                         |
> |DM Solutions Group Inc                http://www.dmsolutions.ca/ |
More information about the mapguide-internals mailing list
