[mapguide-internals] Session-MapName-Map
Trevor Wekel
trevor.wekel at autodesk.com
Fri Aug 31 15:26:30 EDT 2007
I just checked with Steve. We do support folders in the session
repository. There is no "id" in MapGuide currently so it will be a pain
to introduce one. However, we could remap the entire Library based
resource identifier into a session resource identifier.
"Library://Samples/Sheboygan/MyMap.MapDefinition"
would become
"Session:xx-yy-zz://Samples/Sheboygan/MyMap.Map"
And we could add an MgResourceIdentifier return value to MgMap.Save
although it may break existing apps. Using "non-deprecated" API we
would then have:
$resourceId = new MgResourceIdentifier($mapid);
$map = new MgMap($siteConnection);
$map->Create($resourceId);
$mgMapResourceId = $map->Save();
and then to recover the runtime map:
$map->Open($mgMapResourceId);
It is easy to construct the $mgMapResourceId from the $resourceId by
calling MgResourceIdentifier.SetRepositoryType(MgRepositoryType.Session)
and SetRepositoryName($session)
This does reduce some of the API flexibility because it enforces a one
to one correspondence between a map definition and a runtime map. but
it is less "wordy". I have not looked at all the API impacts but this
would require an RFC. We could add a second
MgMap.Create($mapDefinitionResourceId, $mgMapResourceId) to make it a
little more flexible.
Thanks,
Trevor
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Haris
Kurtagic
Sent: Friday, August 31, 2007 12:58 PM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] Session-MapName-Map
Yes, that is a way I was thinking about.
Thanks,
Haris
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Paul
Spencer
Sent: Friday, August 31, 2007 8:50 PM
Subject: Re: [mapguide-internals] Session-MapName-Map
So the logic (in PHP anyway) could be:
$resourceID = new MgResourceIdentifier($mapid);
$map = new MgMap();
$map->Create($resourceService, $resourceID);
$mapStateId = $map->Save($resourceService);
$map = new MgMap();
$map->Open($resourceService, $mapStateId);
Where mapStateId is returned from Save (or obtained in some other
way) and is automagically created from the resourceId in such a way
as to guarantee uniqueness for maps with the same name in different
folders.
I like this. One thing that I find about the MapGuide APIs is that
using them is often quite verbose. Over time, I would like to see
common patterns that require a lot of code be moved into API
convenience functions so that it is easier for folks to accomplish
basic programming tasks.
Paul
On 31-Aug-07, at 2:40 PM, Haris Kurtagic wrote:
> I am thinking that instead client application figure out what to
> use for
> MapName, unique name would be returned from server after saving Map
> into
> session repository.
> Benefits would be that we wouldn't need to implement unique
> algorithm in
> every client application/viewer.
> Haris
> Spencer
> Sent: Friday, August 31, 2007 8:35 PM
> I'm confused about what supporting this in the server would mean.
> Would this impact the scripting APIs at all? What would it make
> easier?
> Paul
> On 31-Aug-07, at 2:27 PM, Trevor Wekel wrote:
>> Hi Haris,
>> The resource identifier is the Berkeley DBXML "key" for both the
>> Library:// and Session:// repositories.
>> Thanks,
>> Trevor
>> Haris
>> Kurtagic
>> Sent: Friday, August 31, 2007 12:21 PM
>> Hi Trevor,
>> Yes leading path from Library is stripped (changed with Session ) and
>> Name part is given by application like MapGudie Viewer for example.
>> As you suggested application can use full name ( with folders ) or as
>> Paul suggested hash the name or ..
>> I have a feeling that server should return the key from db. In
>> Map.cpp
>> MapName is input parameter for creating entry in db.
>> Haris
>> Trevor
>> Wekel
>> Sent: Friday, August 31, 2007 8:08 PM
>> Hi Haris,
>> If you have the map definition
>> Library://Samples/Sheboygan/Test.MapDefinition then the MgMap
>> resourceid
>> be default will be Session:xx-yy-zz//Test.MgMap. The leading path is
>> stripped.
>> I don't know if we have folder support in the session repository
>> but it
>> would probably be better to construct the MgMap session using the
>> full
>> path. Something like this might work:
>> Session:xx-yy-zz//Samples_Sheboygan_Test.MgMap
>> This would be an appropriate enhancement/bugfix request. A search
>> for
>> MgResourceType::Map should take you to most of the code that would
>> require change - DwfController.cpp and Map.cpp I believe.
>> Thanks,
>> Trevor
>> Haris
>> Kurtagic
>> Sent: Friday, August 31, 2007 11:40 AM
>> Thank you, you are right on the track.
>> Yes, you could change name as you suggested or use different sesion
>> for
>> every map or ...
>> I would prefer to have a in server solution for this (and to be
>> able to
>> work with multiple maps in one session).
>> Perhaps server could return DataKey from DB after creating new Map in
>> it?
>> Haris
>> Spencer
>> Sent: Friday, August 31, 2007 7:23 PM
>> Haris,
>> I'm not sure if I really know what I am talking about here, but my
>> understanding is that when you start up a session with a
>> MapDefinition, you can save the runtime MgMap object to the session
>> repository as a Map resource and give it a name at that time. The
>> name is arbitrary, but in the case of the AJAX viewer it is
>> predictable from the MapDefinition name and I think you are right
>> that it would either blow away the existing Map or conflict in some
>> way.
>> I'm not sure how the existing viewer works, but it doesn't contain
>> the capability to change maps at run time so it would never run into
>> this issue. In Fusion, we can load different MapDefinitions at run
>> time and we do something like this when the user wants to load the
>> map:
>> /* $mapid is a string resource id Library://... */
>> $map = new MgMap();
>> $mapName = $resourceID->GetName();
>> $map->Create($resourceService, $resourceID, $mapName);
>> $mapStateId = new MgResourceIdentifier("Session:" . $sessionID .
>> "//" . $map->GetName() . "." . MgResourceType::Map);
>> $map->Save($resourceService, $mapStateId);
>> (NB: there is a potential problem here if the map name is the same as
>> one already in the session. I will need to fix this potential bug in
>> Fusion - I will probably use an md5 hash of the string version of the
>> full Library:// path to the original map. This would probably look
>> like:
>> $mapName = md5($mapid);
>> and the rest of the code would look the same.
>> We return the $mapName to the client so that subsequent requests can
>> operate on the the appropriate Map object on the server side using
>> something like this:
>> $map = new MgMap();
>> $map->Open($resourceService, $mapName);
>> The mapagent rendering operations take the session id and the map
>> name to render map images and dynamic map overlays.
>> Does that help?
>> Cheers
>> Paul
>> On 31-Aug-07, at 1:05 PM, Haris Kurtagic wrote:
>>> I would appreciate if someone could help me to clarify
>>> Session-MapName-Map interaction.
>>> Now how MG Viewer-Server is working is that it will create new
>>> session
>>> and read web layout and create a runtime map in session repository.
>>> Later runtime map is accessed by name (only name part of it) from
>>> the
>>> session repository.
>>> So, if I would have two Maps created in Library in separate folders
>>> with
>>> same name and if I would add the second map to session repository I
>>> could not access both Maps ( because Session Id and MapName are
>>> used to
>>> identify it - and they are same).
>>> Am I right about this ?
>>> Thanks,
>>> Haris
>>> mapguide-internals mailing list
>>> mapguide-internals at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
>> |Paul Spencer pspencer at dmsolutions.ca |
>> |Chief Technology Officer |
>> |DM Solutions Group Inc http://www.dmsolutions.ca/ |
More information about the mapguide-internals
