[mapguide-internals] MGOS 2.0 beta 2 candidate
Kenneth, GEOGRAF A/S ks at geograf.dk
Mon Dec 10 17:04:22 EST 2007
I did use the MetaEdit tool, which indicated that the problem was with
the .json mime type.
I cannot see any difference between the broken entry and the working entry.
Either there are some undisplayed characters, or perhaps a SzString vs.
SzMultiString problem.
In any case, the solution seems to be manual delete and re-create.
The MIME types appear on the four sub folders that are marked
"application", and all four folders exhibit the problem.
Manual deletion and recreate on the "mapguide" folder solves the problem
and assigns correct mime type.
I am willing to test other installers if that can narrow the problem down.
Regards, Kenneth, GEOGRAF A/S
Jason Birch skrev:
> Weird.  Maybe setting it through the UI adds a period, or escapes the /
> or something.
> Are you able to check it out after a failed installer using the MetaEdit
> utility?
> http://support.microsoft.com/kb/232068
> BTW, I'm surprised that it's in there as text/plain.  JSON's official
> IANA media type is application/json
> http://www.iana.org/assignments/media-types/application/
> http://www.ietf.org/rfc/rfc4627.txt
> Jason
> -----Original Message-----
> From: Kenneth, GEOGRAF A/S
> Subject: Re: [mapguide-internals] MGOS 2.0 beta 2 candidate
> I just added the mime type again, exactly as it appeared after the
> install, and it works.
> I tried the installer twice with the same result.
> Kenneth, GEOGRAF A/S skrev:
>> I fixed it by deleting the MIME entry from the MapGuide folder
>> (.json,text/plain).
>> No idea why it is a problem.
>> I seem to recal that some fusion stuff did not work without the entry?
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
