[mapguide-internals] [mapguide-users] Adding a CoordinateSystem to MGE/MGOS
Orest Halustchak orest.halustchak at autodesk.com
Mon Dec 17 11:54:25 EST 2007
Hi Maksim,
The FDO Client Utilities section of FDO Futures is there for discussion and is not an established "plan". The points included in that page are ones that some folks have raised recently. We posted the ideas so that we could start a discussion and get some more feedback. So, if you have some ideas or feedback that you'd like to throw in there, please feel free to add your comments.
Regarding CRS support in FDO, as Jason points out, FDO doesn't do coordinate transformation itself. FDO can return the CRS definition from the data source if it is known (returned as a WKT string). That definition is passed by MG to Proj4 or Mentor. MG relies on these libraries to recognize the CRS definition.
Thanks,
Orest.
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Maksim Sestic
Sent: Monday, December 17, 2007 4:54 AM
To: mapguide-internals at lists.osgeo.org
Subject: RE: RE: [mapguide-internals] [mapguide-users] Adding a CoordinateSystem to MGE/MGOS
Jason, is there some sort of "global" OSGeo roadmap on active projects and
code being shared among them? Like - what project depends on other projects'
deadlines, common cores (i.e. FDO in MG), etc. I guess there's a geospatial
product manager somewhere at Autodesk who actively tracks this :-) Otherwise
there will be lots of inner branching and wheel reinventing, but the purpose
stays the same.
Frankly, lack of CRS support in FDO is still mistery to me :-) MG should be
able to detect and reuse any managed feature store's CRS, where applicable
(if not explicitly overriden by MG at feature source level). This should
also solve WMS/WFS troubles on WGS84 reprojection parameters and envelope
definition.
If I understood "FDO Futures" right, there's a plan to gradually switch
general FDO architecture to client/server?
Regards,
Maksim Sestic
JasonBirch wrote:
> FDO doesn't do coordinate transformation yet.  There has been some talk
> about adding this at a "utility" layer (see the "Futures" section on the
> FDO Trac wiki) but this discussion hasn't received much attention yet.  I
> believe that this is because of time constraints on the part of interested
> parties, because there was a lot of interest in this at FOSS4G.
> Jason
> ________________________________
> From: Maksim Sestic
> Another thing - what about underlying FDO, shouldn't it have Mentor
> libraries implemented in first place? I haven't seen any 3.3.0 RFC related
> to it. Will Mentor implementation affect existing FDO providers?
> mapguide-internals mailing list
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
View this message in context: http://www.nabble.com/RE%3A--mapguide-users--Adding-a-Coordinate-System-to-MGE-MGOS-tp14343358s16610p14370193.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals mailing list
