[mapguide-internals] ogr postgis layer problems
Traian Stanev traian.stanev at autodesk.com
Thu Feb 1 09:50:43 EST 2007
That was being caused by the FID filter not working, at least in the
case of SHP. Not sure if the Postgres driver does anything differently.
Can you try connecting to an SHP file (with the OGR provider) to see if
selection highlights in the case of SHP. That way I'll know at least the
code path I fixed is working for you.
Traian
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Paul
Spencer (External)
Sent: Thursday, February 01, 2007 7:12 AM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] ogr postgis layer problems
Thanks Traian, that fixed the problems.  There is one small remaining
issue that is not critical - the selected features (postgis again) don't
seem to highlight in the ajax viewer.
Cheers
Paul
On 31-Jan-07, at 4:49 PM, Traian Stanev wrote:
> Hi again.
> I've fixed both issues in the OGR provider. Selection now works fine,
> including multi-select, when tested on SHP files. There was a problem
> with intersection queries (the problem was they weren't implemented,
> heh). I also fixes the problem of the features disappearing after
> selection -- I had forgotten to reset the filters on the OGRLayer in
> between Selects. I also fixed a small problem in OGR, which was making
> FID filters fail. I'll have Tom post a new Win32 DLL to the provider
> download location.
> FYI, I recompiled against the following versions of the dependent
> libraries: GDAL 1.4.0 (plus my fix), PostgreSQL 8.2.1, Proj 4.5.0,
> Geos 2.2.3, plus unknown versions of Oracle OCI and ODBC.
> Traian
> From: Traian Stanev
> Sent: Wednesday, January 31, 2007 3:33 PM
> To: 'MapGuide Internals Mail List'
> Subject: RE: [mapguide-internals] ogr postgis layer problems
> Hi Paul.
> I tried it against an SHP file and selection is definitely not working
> right. :) To avoid the disappearing map problem, you can disable
> connection pooling for the OGR provider in the serverconfig.ini file.
> This will prevent the map from disappearing (since the connection is
> not reused after it breaks during selection), but it will not make
> selection work. I will see what can be done about fixing this and let
> you know.
> Traian
> Spencer (External)
> Sent: Tuesday, January 30, 2007 9:18 PM
> Subject: [mapguide-internals] ogr postgis layer problems
> Hi all,
> I am looking into an issue regarding postgis layers loaded via the OGR
> provider for a client.  The postgis layer is functioning normally when
> the map loads (it is initially off but it can be toggled on/off no
> problem).  It can be queried using the select.  However, when the
> layer has had features selected on it, the next action causes the
> layer to be turned off and the layer cannot be turned back on without
> restarting the service and web browser.
> Any ideas what might be going on?  Bug in the OGR provider?  AJAX
> Viewer?  Bad data?
> Cheers
> Paul
> |Paul Spencer                          pspencer at dmsolutions.ca    |
> |Chief Technology Officer                                         |
> |DM Solutions Group Inc                http://www.dmsolutions.ca/ |
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
