[mapguide-internals] DWF from MapGuide OS doesn't work in AutoCAD ?
Jason Birch Jason.Birch at nanaimo.ca
Mon Feb 12 22:16:27 EST 2007
You're talking about an ePlot generated with MgMapPlot?
What version of AutoCAD is being used?
What do you mean by Import?  I think (but could easily be wrong) that DWFs are only available as reference layers in AutoCAD.
Care to post a sample?
Jason
From: mapguide-internals-bounces at lists.osgeo.org on behalf of Paul Spencer
Sent: Mon 2007-02-12 5:43 PM
To: MapGuide Internals Mail List
Subject: [mapguide-internals] DWF from MapGuide OS doesn't work in AutoCAD ?
Hi, I've got a client who is reporting that a DWF generated by MGOS
works with the DWF viewer but won't import into AutoCAD.  Is this a
known issue?  A problem with MapGuide?  I suspect that AutoCAD just
hasn't been updated to work with the DWF version being spit out by
MGOS or something like that but would like confirmation ...
Cheers
Paul
More information about the mapguide-internals mailing list
