[Mapguide_dev] svn commit: r1033 - Miscellaneous code cleanups and fixes.
Steve Dang steve.dang at autodesk.com
Fri Jan 5 15:48:49 EST 2007
Revision: 1033
Author: stevedang
Date: 2:34:30 PM, Friday, January 05, 2007
Message:
MG456 (Miscellaneous code cleanups and fixes)
- Added a new error message to clarify the reason why the server fails
to open the repository.
- Cleaned up/sorted string resource IDs.
- Synchronized the server/web tier resource files.
Modified : /trunk/MgDev/Server/src/Resources/server_en.res
Modified : /trunk/MgDev/Server/src/Services/Resource/Repository.cpp
Modified : /trunk/MgDev/Web/src/mapagent/Resources/web_en.res
Index: C:/Projects/MgDev/OS/Server/src/Services/Resource/Repository.cpp
--- C:/Projects/MgDev/OS/Server/src/Services/Resource/Repository.cpp
(revision 1032)
+++ C:/Projects/MgDev/OS/Server/src/Services/Resource/Repository.cpp
(revision 1033)
@@ -73,7 +73,7 @@
         throw new MgRepositoryOpenFailedException(
             L"MgRepository.VerifySafeDatabaseAccess",
-            __LINE__, __WFILE__, &arguments, L"", NULL);
+            __LINE__, __WFILE__, &arguments,
L"MgRepositoryAlreadyOpened", NULL);
Index: C:/Projects/MgDev/OS/Server/src/Resources/server_en.res
--- C:/Projects/MgDev/OS/Server/src/Resources/server_en.res
(revision 1032)
+++ C:/Projects/MgDev/OS/Server/src/Resources/server_en.res    (revision
1033)
@@ -154,6 +154,7 @@
 [ErrorDescription]
 MgArgumentsMismatch                                   = The arguments
needed do not match the arguments provided.
+MgClassWOIdentity                                     = A class
definition has no identity property.
 MgCollectionEmpty                                     = The collection
cannot be empty.
 MgConfigurationPropertyLengthIsInvalid                = The value of
property %1 under section %2 is %3. Its length must be %4
 MgConfigurationPropertyLengthIsOutOfRange             = The value of
property %1 under section %2 is %3. Its length must be between %4 and %5
@@ -222,9 +223,13 @@
 MgInvalidXmlDateTime                                  = The Xml date
time is invalid because not all of the fields were found.
 MgInvalidYear                                         = The year is
invalid because it must be between 1 and 9999.
 MgMapLayerGroupNameNotFound                           = The map layer
group name was not found.
+MgMissingClassDef                                     = No class
definition specified.
+MgMissingSchema                                       = No schema
specified.
+MgMissingSrs                                          = No coordinate
system specified.
 MgNameNotFound                                        = The name was
not found.
 MgPropertyValuesEmpty                                 = The property
values cannot be empty.
 MgReaderIdNotFound                                    = The reader ID
was not found.
+MgRepositoryAlreadyOpened                             = The repository
is already opened by another process (e.g. If you are running the server
interactively as an application from the command line, are you also
running the server as a service?).
 MgResourceDataFilePathEmpty                           = The resource
data file path is empty.
 MgResourceNameDoesNotContainSectionName               = The resource
name does not contain a section name.
 MgResourceNameSeparatorNotFound                       = The resource
name separator was not found.
@@ -242,10 +247,6 @@
 MgValueCannotBeLessThanOrEqualToZero                  = The value
cannot be less than or equal to zero.
 MgValueCannotBeLessThanZero                           = The value
cannot be less than zero.
 MgValueCannotBeZero                                   = The value
cannot be zero.
-MgMissingClassDef                                     = No class
-MgClassWOIdentity                                     = A class
-MgMissingSrs                                          = No coordinate
system specified.
-MgMissingSchema                                       = No schema
specified.
 # D R A W I N G  S E R V I C E
@@ -256,24 +257,29 @@
 # F E A T U R E  S E R V I C E
 [FeatureService]
+MgBatchInsertNotSupported                             = Provider does
not support batch insert. Only one Feature instance is allowed.
+MgCommandNotSupported                                 = Command is not
supported by Provider.
+MgCustomFunctionNotSupported                          = Aggregate
function specified not supported or invalid data type
+MgGroupingNotSupported                                = Grouping is not
supported by provider
+MgInsertError                                         = Error occurred
while insert operation, no ID to retrieve
+MgInvalidComputedProperty                             = Invalid
Computed property specified, Make sure valid no of arguments are
specified
+MgInvalidConnectionString                             = Invalid
Connection String.
 MgInvalidFdoProvider                                  = Invalid Feature
Provider specified.
 MgInvalidPropertyName                                 = Invalid
Property Name found.
 MgMissingConfiguration                                = No
configuration specified.
-MgInvalidConnectionString                             = Invalid
Connection String.
-MgPropertyNotEnumerable                               = Property
specified is not enumerable.
+MgMissingPropertyAlias                                = Alias for
computed property is missing
 MgMissingRasterProperty                               = No Raster
Property available in the class.
-MgCommandNotSupported                                 = Command is not
+MgNoFeaturesForInsert                                 = No Features for
Insert supplied
 MgOnlyOnePropertyAllowed                              = Only one
aggregate function of this kind is supported
-MgInvalidComputedProperty                             = Invalid
specified
-MgCustomFunctionNotSupported                          = Aggregate
-MgMissingPropertyAlias                                = Alias for
-MgBatchInsertNotSupported                             = Provider does
-MgNoFeaturesForInsert                                 = No Features for
Insert supplied
-MgInsertError                                         = Error occurred
 MgOrderingOptionNotSupported                          = Ordering Option
is not supported by provider
-MgGroupingNotSupported                                = Grouping is not
+MgPropertyNotEnumerable                               = Property
+# K M L  S E R V I C E
+[KmlService]
 # M A P P I N G  S E R V I C E
 [MappingService]
@@ -287,12 +293,12 @@
 # R E S O U R C E  S E R V I C E
 [ResourceService]
+MgPackageStatusMessageLoadPackageFailed               = LOAD FAILED: %1
failed to load package on %2
+MgPackageStatusMessageLoadPackageInProgress           = Loading package
%1 ...
 MgPackageStatusMessageLoadPackageSucceeded            = LOAD SUCCEEDED:
%1 successfully loaded package on %2
-MgPackageStatusMessageMakePackageSucceeded            = MAKE SUCCEEDED:
%1 successfully made package on %2
-MgPackageStatusMessageLoadPackageFailed               = LOAD FAILED: %1
 MgPackageStatusMessageMakePackageFailed               = MAKE FAILED: %1
failed to make package on %2
-MgPackageStatusMessageLoadPackageInProgress           = Loading package
%1 ...
 MgPackageStatusMessageMakePackageInProgress           = Making package
%1 ...
+MgPackageStatusMessageMakePackageSucceeded            = MAKE SUCCEEDED:
 MgPackageStatusMessageNotStarted                      = Not started
 MgPackageStatusMessageUnknown                         = Unknown
 MgRepositoryBusy                                      = Please try your
operation later as the repository was busy.
@@ -322,3 +328,8 @@
 MgUserFullNameAuthor                                  = Map Author
 MgUserFullNameWfsUser                                 = WFS User
 MgUserFullNameWmsUser                                 = WMS User
+# T I L E  S E R V I C E
+[TileService]
Index: C:/Projects/MgDev/OS/Web/src/mapagent/Resources/web_en.res
--- C:/Projects/MgDev/OS/Web/src/mapagent/Resources/web_en.res
(revision 1032)
+++ C:/Projects/MgDev/OS/Web/src/mapagent/Resources/web_en.res
(revision 1033)
@@ -30,6 +30,7 @@
 MgCoordinateSystemComputationFailedException          = The coordinate
system computation failed.
 MgCoordinateSystemConversionFailedException           = The coordinate
system conversion failed.
 MgCoordinateSystemInitializationFailedException       = The coordinate
system initialization failed.
+MgCoordinateSystemLoadFailedException                 = The coordinate
system load failed.
 MgCoordinateSystemMeasureFailedException              = The coordinate
system measure failed.
 MgCoordinateSystemTransformFailedException            = The coordinate
system transform failed.
 MgDateTimeException                                   = A date and/or
time exception occurred.
@@ -95,6 +96,7 @@
 MgInvalidResourcePreProcessingTypeException           = Invalid
resource pre-processing type.
 MgInvalidResourceTypeException                        = Invalid
resource type.
 MgInvalidServerNameException                          = Invalid server
+MgInvalidSerialNumberException                        = Invalid serial
number: %1
 MgInvalidStreamHeaderException                        = Invalid stream
header exception.
 MgIoException                                         = An IO exception
occurred.
 MgLayerNotFoundException                              = The specified
layer was not found: %1
@@ -135,7 +137,9 @@
 MgServiceNotAvailableException                        = The specified
service is not available.
 MgServiceNotSupportedException                        = The specified
service is not supported.
 MgSessionExpiredException                             = Session has
expired or is invalid. Please log in again.
+MgSessionNotFoundException                            = A required
session was not found.
 MgStreamIoException                                   = A stream IO
exception occurred.
+MgStylizeLayerFailedException                         = Failed to
stylize layer: %1
 MgTemporaryFileNotAvailableException                  = Temporary file
is not available.
 MgUnauthorizedAccessException                         = Unauthorized
access.
 MgUnclassifiedException                               = An unclassified
exception occurred.
@@ -150,6 +154,7 @@
 [ErrorDescription]
cannot be empty.
@@ -218,9 +223,13 @@
specified.
system specified.
not found.
was not found.
@@ -250,6 +259,11 @@
 [FeatureService]
+[KmlService]
 [MappingService]
@@ -263,12 +277,12 @@
 [ResourceService]
%1 ...
%1 ...
%1 ...
URL: http://lists.osgeo.org/pipermail/mapguide-internals/attachments/20070105/a453529f/attachment.html
More information about the Mapguide-internals mailing list
