[Mapguide_dev] svn commit: r1038 - RFC 10 Make Schemas More Amenable to Interim Enhancements
Trevor Wekel trevor.wekel at autodesk.com
Mon Jan 8 21:20:46 EST 2007
Revision: 1038
Author: trevorwekel
Date: 8:10:06 PM, Monday, January 08, 2007
Message:
RFC 10 - Make Schemas More Amenable to Interim Enhancements
Modified : /trunk/MgDev/Common/MdfModel/AttributeRelate.h
Modified : /trunk/MgDev/Common/MdfModel/CalculatedProperty.h
Modified : /trunk/MgDev/Common/MdfModel/ChannelBand.h
Modified : /trunk/MgDev/Common/MdfModel/Extension.h
Modified : /trunk/MgDev/Common/MdfModel/FeatureSource.h
Modified : /trunk/MgDev/Common/MdfModel/FeatureTypeStyle.h
Modified : /trunk/MgDev/Common/MdfModel/Fill.h
Modified : /trunk/MgDev/Common/MdfModel/GridColor.h
Modified : /trunk/MgDev/Common/MdfModel/GridScaleRange.h
Modified : /trunk/MgDev/Common/MdfModel/HillShade.h
Modified : /trunk/MgDev/Common/MdfModel/Label.h
Modified : /trunk/MgDev/Common/MdfModel/LayerDefinition.h
Modified : /trunk/MgDev/Common/MdfModel/Makefile.am
Modified : /trunk/MgDev/Common/MdfModel/MdfModel.vcproj
Added : /trunk/MgDev/Common/MdfModel/MdfRootObject.cpp
Added : /trunk/MgDev/Common/MdfModel/MdfRootObject.h
Modified : /trunk/MgDev/Common/MdfModel/NameStringPair.h
Modified : /trunk/MgDev/Common/MdfModel/RelateProperty.h
Modified : /trunk/MgDev/Common/MdfModel/Rule.h
Modified : /trunk/MgDev/Common/MdfModel/Stroke.h
Modified : /trunk/MgDev/Common/MdfModel/SupplementalSpatialContextInfo.h
Modified : /trunk/MgDev/Common/MdfModel/Symbol.h
Modified : /trunk/MgDev/Common/MdfModel/Symbolization.h
Modified : /trunk/MgDev/Common/MdfModel/VectorScaleRange.h
Modified : /trunk/MgDev/Common/MdfParser/FSDSAX2Parser.cpp
Modified : /trunk/MgDev/Common/MdfParser/FSDSAX2Parser.h
Modified : /trunk/MgDev/Common/MdfParser/IOAreaRule.cpp
Modified : /trunk/MgDev/Common/MdfParser/IOAreaSymbolization2D.cpp
Modified : /trunk/MgDev/Common/MdfParser/IOAreaTypeStyle.cpp
Modified : /trunk/MgDev/Common/MdfParser/IOAttributeRelate.cpp
Modified : /trunk/MgDev/Common/MdfParser/IOBlockSymbol.cpp
Modified : /trunk/MgDev/Common/MdfParser/IOCalculatedProperty.cpp
Modified : /trunk/MgDev/Common/MdfParser/IOChannelBand.cpp
Modified : /trunk/MgDev/Common/MdfParser/IODrawingLayerDefinition.cpp
Modified : /trunk/MgDev/Common/MdfParser/IOExtension.cpp
Modified : /trunk/MgDev/Common/MdfParser/IOFeatureSource.cpp
Modified : /trunk/MgDev/Common/MdfParser/IOFill.cpp
Modified : /trunk/MgDev/Common/MdfParser/IOFontSymbol.cpp
Modified : /trunk/MgDev/Common/MdfParser/IOGridColor.cpp
Added : /trunk/MgDev/Common/MdfParser/IOGridColorBands.cpp
Modified : /trunk/MgDev/Common/MdfParser/IOGridColorRule.cpp
Modified : /trunk/MgDev/Common/MdfParser/IOGridColorStyle.cpp
Modified : /trunk/MgDev/Common/MdfParser/IOGridLayerDefinition.cpp
Modified : /trunk/MgDev/Common/MdfParser/IOGridScaleRange.cpp
Modified : /trunk/MgDev/Common/MdfParser/IOGridSurfaceStyle.cpp
Modified : /trunk/MgDev/Common/MdfParser/IOHillShade.cpp
Modified : /trunk/MgDev/Common/MdfParser/IOImageSymbol.cpp
Modified : /trunk/MgDev/Common/MdfParser/IOLabel.cpp
Modified : /trunk/MgDev/Common/MdfParser/IOLineRule.cpp
Modified : /trunk/MgDev/Common/MdfParser/IOLineSymbolization2D.cpp
Modified : /trunk/MgDev/Common/MdfParser/IOLineTypeStyle.cpp
Modified : /trunk/MgDev/Common/MdfParser/IOMarkSymbol.cpp
Modified : /trunk/MgDev/Common/MdfParser/IONameStringPair.cpp
Modified : /trunk/MgDev/Common/MdfParser/IOPointRule.cpp
Modified : /trunk/MgDev/Common/MdfParser/IOPointSymbolization2D.cpp
Modified : /trunk/MgDev/Common/MdfParser/IOPointTypeStyle.cpp
Modified : /trunk/MgDev/Common/MdfParser/IORelateProperty.cpp
Modified : /trunk/MgDev/Common/MdfParser/IOStroke.cpp
Modified :
/trunk/MgDev/Common/MdfParser/IOSupplementalSpatialContextInfo.cpp
Added : /trunk/MgDev/Common/MdfParser/IOUnknown.cpp
Added : /trunk/MgDev/Common/MdfParser/IOUnknown.h
Modified : /trunk/MgDev/Common/MdfParser/IOUtil.cpp
Modified : /trunk/MgDev/Common/MdfParser/IOUtil.h
Modified : /trunk/MgDev/Common/MdfParser/IOVectorLayerDefinition.cpp
Modified : /trunk/MgDev/Common/MdfParser/IOVectorScaleRange.cpp
Modified : /trunk/MgDev/Common/MdfParser/IOW2DSymbol.cpp
Modified : /trunk/MgDev/Common/MdfParser/Makefile.am
Modified : /trunk/MgDev/Common/MdfParser/MdfParser.vcproj
Added : /trunk/MgDev/Common/MdfParser/SAX2ElementHandler.cpp
Modified : /trunk/MgDev/Common/MdfParser/SAX2ElementHandler.h
Modified : /trunk/MgDev/Common/MdfParser/SAX2Parser.cpp
Modified : /trunk/MgDev/Common/MdfParser/SAX2Parser.h
Modified : /trunk/MgDev/Common/Schema/FeatureSource-1.0.0.xsd
Modified : /trunk/MgDev/Common/Schema/LayerDefinition-1.0.0.xsd
Index: E:/MgDev/OS/Common/Schema/FeatureSource-1.0.0.xsd
--- E:/MgDev/OS/Common/Schema/FeatureSource-1.0.0.xsd	(revision 1037)
+++ E:/MgDev/OS/Common/Schema/FeatureSource-1.0.0.xsd	(revision 1038)
@@ -54,9 +54,11 @@
                 <xs:documentation>The feature class that is being
extended; this is the class whose attributes are used for joining other
attribute classes</xs:documentation>
               </xs:annotation>
             </xs:element>
+            <xs:element name="ExtendedData1" type="ExtendedDataType"
minOccurs="0" />
           </xs:sequence>
         </xs:complexType>
       </xs:element>
minOccurs="0" />
     </xs:sequence>
     <xs:attribute name="version" type="xs:string">
       <xs:annotation>
@@ -79,6 +81,7 @@
           <xs:documentation>Text for value of
parameter</xs:documentation>
         </xs:annotation>
       </xs:element>
minOccurs="0" />
     </xs:sequence>
   </xs:complexType>
   <xs:simpleType name="RelateTypeEnum">
@@ -112,6 +115,7 @@
           <xs:documentation>Expression for the
property</xs:documentation>
         </xs:annotation>
       </xs:element>
minOccurs="0" />
     </xs:sequence>
   </xs:complexType>
   <xs:complexType name="RelatePropertyType">
@@ -126,6 +130,7 @@
           <xs:documentation>Name of property (field) in attribute
class</xs:documentation>
         </xs:annotation>
       </xs:element>
minOccurs="0" />
     </xs:sequence>
   </xs:complexType>
   <xs:complexType name="AttributeRelateType">
@@ -165,6 +170,7 @@
           <xs:documentation>Force 1 : 1 in the case of 1 : many
</xs:documentation>
         </xs:annotation>
       </xs:element>
minOccurs="0" />
     </xs:sequence>
   </xs:complexType>
   <xs:complexType name="SpatialContextType">
@@ -182,6 +188,15 @@
           <xs:documentation>Coordinate system used for this spatial
context</xs:documentation>
         </xs:annotation>
       </xs:element>
minOccurs="0" />
     </xs:sequence>
   </xs:complexType>
-</xs:schema>
\ No newline at end of file
+    <xs:complexType name="ExtendedDataType">
+        <xs:annotation>
+            <xs:documentation>A type allocating space for future,
additional, and validatable data for this feature
source</xs:documentation>
+        </xs:annotation>
+        <xs:sequence>
+            <xs:any maxOccurs="unbounded" processContents="lax"/>
+        </xs:sequence>
+    </xs:complexType>
+</xs:schema>
Index: E:/MgDev/OS/Common/Schema/LayerDefinition-1.0.0.xsd
--- E:/MgDev/OS/Common/Schema/LayerDefinition-1.0.0.xsd	(revision 1037)
+++ E:/MgDev/OS/Common/Schema/LayerDefinition-1.0.0.xsd	(revision 1038)
@@ -90,6 +90,7 @@
               <xs:documentation>The zoomed out part of the scale range.
Assume application's maximum value if the value is not specified.
Exclusive.</xs:documentation>
             </xs:annotation>
           </xs:element>
minOccurs="0" />
         </xs:sequence>
       </xs:extension>
     </xs:complexContent>
@@ -140,6 +141,7 @@
               <xs:documentation>The stylization to be applied to the
features for a given scale range.</xs:documentation>
             </xs:annotation>
           </xs:element>
minOccurs="0" />
         </xs:sequence>
       </xs:extension>
@@ -188,6 +190,7 @@
           </xs:annotation>
         </xs:element>
       </xs:choice>
minOccurs="0" />
     </xs:sequence>
   </xs:complexType>
   <xs:complexType name="PointTypeStyleType">
@@ -210,6 +213,7 @@
           <xs:documentation>One or more PointRules defining the
PointTypeStyle</xs:documentation>
         </xs:annotation>
       </xs:element>
minOccurs="0" />
     </xs:sequence>
   </xs:complexType>
   <xs:complexType name="PointRuleType">
@@ -235,6 +239,7 @@
       <xs:choice minOccurs="0">
         <xs:element name="PointSymbolization2D"
type="PointSymbolization2DType"/>
       </xs:choice>
minOccurs="0" />
     </xs:sequence>
   </xs:complexType>
   <xs:complexType name="PointSymbolizationType">
@@ -246,33 +251,36 @@
     <xs:annotation>
       <xs:documentation>The different types of point
geometries.</xs:documentation>
     </xs:annotation>
-    <xs:choice>
-      <xs:element name="Mark" type="MarkSymbolType">
-        <xs:annotation>
-          <xs:documentation>Predefined shape such as square or
circle.</xs:documentation>
-        </xs:annotation>
-      </xs:element>
-      <xs:element name="Image" type="ImageSymbolType">
-        <xs:annotation>
-          <xs:documentation>Raster or image symbol. Note that these do
not scale well, but sometimes this is all that you have. Supported
formats are application specific.</xs:documentation>
-        </xs:annotation>
-      </xs:element>
-      <xs:element name="Font" type="FontSymbolType">
-        <xs:annotation>
-          <xs:documentation>Specify the symbol using a font
character.</xs:documentation>
-        </xs:annotation>
-      </xs:element>
-      <xs:element name="W2D" type="W2DSymbolType">
-        <xs:annotation>
-          <xs:documentation>Vector symbol defined using a W2D
stream.</xs:documentation>
-        </xs:annotation>
-      </xs:element>
-      <xs:element name="Block" type="BlockSymbolType">
-        <xs:annotation>
-          <xs:documentation>Vector symbol specifed from a
block.</xs:documentation>
-        </xs:annotation>
-      </xs:element>
-    </xs:choice>
+    <xs:sequence>
+      <xs:choice>
+        <xs:element name="Mark" type="MarkSymbolType">
+          <xs:annotation>
+            <xs:documentation>Predefined shape such as square or
+          </xs:annotation>
+        </xs:element>
+        <xs:element name="Image" type="ImageSymbolType">
+          <xs:annotation>
+            <xs:documentation>Raster or image symbol. Note that these
do not scale well, but sometimes this is all that you have. Supported
+          </xs:annotation>
+        </xs:element>
+        <xs:element name="Font" type="FontSymbolType">
+          <xs:annotation>
+            <xs:documentation>Specify the symbol using a font
+          </xs:annotation>
+        </xs:element>
+        <xs:element name="W2D" type="W2DSymbolType">
+          <xs:annotation>
+            <xs:documentation>Vector symbol defined using a W2D
+          </xs:annotation>
+        </xs:element>
+        <xs:element name="Block" type="BlockSymbolType">
+          <xs:annotation>
+            <xs:documentation>Vector symbol specifed from a
+          </xs:annotation>
+        </xs:element>
+      </xs:choice>
minOccurs="0" />
+    </xs:sequence>
   </xs:complexType>
   <xs:complexType name="LineTypeStyleType">
     <xs:annotation>
@@ -284,6 +292,7 @@
           <xs:documentation>Rules to define a theme.</xs:documentation>
         </xs:annotation>
       </xs:element>
minOccurs="0" />
     </xs:sequence>
   </xs:complexType>
   <xs:complexType name="LineRuleType">
@@ -309,6 +318,7 @@
       <xs:choice minOccurs="0" maxOccurs="unbounded">
         <xs:element name="LineSymbolization2D" type="StrokeType"/>
       </xs:choice>
minOccurs="0" />
     </xs:sequence>
   </xs:complexType>
   <xs:complexType name="AreaSymbolizationType">
@@ -333,6 +343,7 @@
               <xs:documentation>The style of the polygon
edge.</xs:documentation>
             </xs:annotation>
           </xs:element>
minOccurs="0" />
         </xs:sequence>
       </xs:extension>
@@ -347,6 +358,7 @@
         </xs:annotation>
       </xs:element>
minOccurs="0" />
     </xs:sequence>
   </xs:complexType>
   <xs:complexType name="AreaRuleType">
@@ -376,6 +388,7 @@
           </xs:annotation>
         </xs:element>
       </xs:choice>
minOccurs="0" />
     </xs:sequence>
   </xs:complexType>
   <xs:complexType name="StrokeType">
@@ -392,6 +405,7 @@
           <xs:documentation>Unit of measurement that the thickness is
specified in</xs:documentation>
         </xs:annotation>
       </xs:element>
minOccurs="0" />
     </xs:sequence>
   </xs:complexType>
   <xs:complexType name="FillType">
@@ -406,6 +420,7 @@
           <xs:documentation>The background color. Not applicable to
solid fills. </xs:documentation>
         </xs:annotation>
       </xs:element>
minOccurs="0" />
     </xs:sequence>
   </xs:complexType>
   <xs:simpleType name="BackgroundStyleType">
@@ -514,6 +529,7 @@
               </xs:sequence>
             </xs:complexType>
           </xs:element>
minOccurs="0" />
         </xs:sequence>
       </xs:extension>
@@ -583,6 +599,7 @@
               <xs:documentation>No edge is drawin if not
specified.</xs:documentation>
             </xs:annotation>
           </xs:element>
minOccurs="0" />
         </xs:sequence>
       </xs:extension>
@@ -602,6 +619,7 @@
           <xs:documentation>The name to show the end
user.</xs:documentation>
         </xs:annotation>
       </xs:element>
minOccurs="0" />
     </xs:sequence>
   </xs:complexType>
   <xs:simpleType name="ShapeType">
@@ -623,32 +641,35 @@
     </xs:annotation>
     <xs:complexContent>
       <xs:extension base="SymbolType">
-        <xs:choice>
-          <xs:element name="Image">
-            <xs:annotation>
-              <xs:documentation>Reference to the
image.</xs:documentation>
-            </xs:annotation>
-            <xs:complexType>
-              <xs:sequence>
-                <xs:element name="ResourceId">
-                  <xs:annotation>
-                    <xs:documentation>The reference to the
resource.</xs:documentation>
-                  </xs:annotation>
-                </xs:element>
-                <xs:element name="LibraryItemName" minOccurs="0">
-                  <xs:annotation>
-                    <xs:documentation>If ResourceId specifies a
library, this identifies the name of a library item.</xs:documentation>
-                  </xs:annotation>
-                </xs:element>
-              </xs:sequence>
-            </xs:complexType>
-          </xs:element>
-          <xs:element name="Content" type="xs:hexBinary">
-            <xs:annotation>
-              <xs:documentation>BinHex data for image.
</xs:documentation>
-            </xs:annotation>
-          </xs:element>
-        </xs:choice>
+        <xs:sequence>
+          <xs:choice>
+            <xs:element name="Image">
+              <xs:annotation>
+                <xs:documentation>Reference to the
+              </xs:annotation>
+              <xs:complexType>
+                <xs:sequence>
+                  <xs:element name="ResourceId">
+                    <xs:annotation>
+                      <xs:documentation>The reference to the
+                    </xs:annotation>
+                  </xs:element>
+                  <xs:element name="LibraryItemName" minOccurs="0">
+                    <xs:annotation>
+                      <xs:documentation>If ResourceId specifies a
+                    </xs:annotation>
+                  </xs:element>
+                </xs:sequence>
+              </xs:complexType>
+            </xs:element>
+            <xs:element name="Content" type="xs:hexBinary">
+              <xs:annotation>
+                <xs:documentation>BinHex data for image.
</xs:documentation>
+              </xs:annotation>
+            </xs:element>
+          </xs:choice>
minOccurs="0" />
+        </xs:sequence>
       </xs:extension>
   </xs:complexType>
@@ -669,6 +690,7 @@
           <xs:element name="Italic" type="xs:boolean" minOccurs="0"/>
           <xs:element name="Underlined" type="xs:boolean"
minOccurs="0"/>
           <xs:element name="ForegroundColor" type="xs:string"/>
minOccurs="0" />
         </xs:sequence>
       </xs:extension>
@@ -711,6 +733,7 @@
               <xs:documentation>If specified all text in the symbol is
drawn in this color.</xs:documentation>
             </xs:annotation>
           </xs:element>
minOccurs="0" />
         </xs:sequence>
       </xs:extension>
@@ -734,6 +757,7 @@
               <xs:documentation>Static color.</xs:documentation>
             </xs:annotation>
           </xs:element>
minOccurs="0" />
         </xs:sequence>
       </xs:extension>
@@ -760,6 +784,7 @@
             </xs:annotation>
           </xs:element>
           <xs:element name="GridScaleRange" type="GridScaleRangeType"
maxOccurs="unbounded"/>
minOccurs="0" />
         </xs:sequence>
       </xs:extension>
@@ -794,6 +819,7 @@
           <xs:documentation>Default is 255.  Range is
0:255.</xs:documentation>
         </xs:annotation>
       </xs:element>
minOccurs="0" />
     </xs:sequence>
   </xs:complexType>
   <xs:complexType name="GridColorBandsType">
@@ -810,15 +836,18 @@
     <xs:annotation>
       <xs:documentation>The color to use for a grid
rule.</xs:documentation>
     </xs:annotation>
-    <xs:choice>
-      <xs:element name="ExplicitColor" type="xs:string">
-        <xs:annotation>
-          <xs:documentation>Explicit ARGB color.</xs:documentation>
-        </xs:annotation>
-      </xs:element>
-      <xs:element name="Band" type="xs:string"/>
-      <xs:element name="Bands" type="GridColorBandsType"/>
-    </xs:choice>
+    <xs:sequence>
+      <xs:choice>
+        <xs:element name="ExplicitColor" type="xs:string">
+          <xs:annotation>
+            <xs:documentation>Explicit ARGB color.</xs:documentation>
+          </xs:annotation>
+        </xs:element>
+        <xs:element name="Band" type="xs:string"/>
+        <xs:element name="Bands" type="GridColorBandsType"/>
+      </xs:choice>
minOccurs="0" />
+    </xs:sequence>
   </xs:complexType>
   <xs:complexType name="GridColorRuleType">
     <xs:annotation>
@@ -841,6 +870,7 @@
         </xs:annotation>
       </xs:element>
       <xs:element name="Color" type="GridColorType"/>
minOccurs="0" />
     </xs:sequence>
   </xs:complexType>
   <xs:complexType name="HillshadeType">
@@ -868,6 +898,7 @@
           <xs:documentation>Default is 1. Applied to band prior to
computing hillshade.</xs:documentation>
         </xs:annotation>
       </xs:element>
minOccurs="0" />
     </xs:sequence>
   </xs:complexType>
   <xs:complexType name="GridColorStylizationType">
@@ -892,6 +923,7 @@
         </xs:annotation>
       </xs:element>
       <xs:element name="ColorRule" type="GridColorRuleType"
minOccurs="0" maxOccurs="unbounded"/>
minOccurs="0" />
     </xs:sequence>
   </xs:complexType>
   <xs:complexType name="GridSurfaceStylizationType">
@@ -919,6 +951,7 @@
           <xs:documentation>The color that will show if there is no
ColorStyle defined at a pixel.</xs:documentation>
         </xs:annotation>
       </xs:element>
minOccurs="0" />
     </xs:sequence>
   </xs:complexType>
   <xs:complexType name="GridScaleRangeType">
@@ -947,6 +980,15 @@
           <xs:documentation>When the user has zoomed in by this amount,
a request for more detailed raster data is made.</xs:documentation>
         </xs:annotation>
       </xs:element>
minOccurs="0" />
     </xs:sequence>
   </xs:complexType>
+        <xs:annotation>
+        </xs:annotation>
+        <xs:sequence>
+        </xs:sequence>
+    </xs:complexType>
 </xs:schema>
Index: E:/MgDev/OS/Common/MdfParser/IOCalculatedProperty.cpp
--- E:/MgDev/OS/Common/MdfParser/IOCalculatedProperty.cpp
(revision 1037)
+++ E:/MgDev/OS/Common/MdfParser/IOCalculatedProperty.cpp
(revision 1038)
@@ -22,6 +22,11 @@
 using namespace MDFMODEL_NAMESPACE;
 using namespace MDFPARSER_NAMESPACE;
+CREATE_ELEMENT_MAP;
+ELEM_MAP_ENTRY(1, CalculatedProperty);
+ELEM_MAP_ENTRY(2, Name);
+ELEM_MAP_ENTRY(3, Expression);
 IOCalculatedProperty::IOCalculatedProperty()
     : m_pCalculatedProperty(NULL), m_pExtension(NULL)
@@ -39,10 +44,21 @@
 void IOCalculatedProperty::StartElement(const wchar_t *name,
HandlerStack *handlerStack)
     m_currElemName = name;
-    if (m_currElemName == L"CalculatedProperty") // NOXLATE
+    m_currElemId = _ElementIdFromName(name);
+    switch (m_currElemId)
+    case eCalculatedProperty:
         m_startElemName = name;
         m_pCalculatedProperty = new CalculatedProperty();
+        break;
+    case eUnknown:
+        ParseUnknownXml(name, handlerStack);
+        break;
+    default:
+        break;
@@ -58,6 +74,9 @@
     if (m_startElemName == name)
+        if (!UnknownXml().empty())
+            this->m_pCalculatedProperty->SetUnknownXml(UnknownXml());
m_pExtension->GetCalculatedProperties()->Adopt(m_pCalculatedProperty);
         handlerStack->pop();
         this->m_pCalculatedProperty = NULL;
@@ -81,6 +100,12 @@
     fd << EncodeString(pCalculatedProperty->GetExpression());
     fd << "</Expression>" << std::endl; // NOXLATE
+    // Write any previously found unknown XML
+    if (!pCalculatedProperty->GetUnknownXml().empty())
+        fd << toCString(pCalculatedProperty->GetUnknownXml());
     dectab();
     fd << tab() << "</CalculatedProperty>" << std::endl; // NOXLATE
Index: E:/MgDev/OS/Common/MdfParser/IOPointTypeStyle.cpp
--- E:/MgDev/OS/Common/MdfParser/IOPointTypeStyle.cpp	(revision 1037)
+++ E:/MgDev/OS/Common/MdfParser/IOPointTypeStyle.cpp	(revision 1038)
@@ -23,6 +23,12 @@
+ELEM_MAP_ENTRY(1, PointTypeStyle);
+ELEM_MAP_ENTRY(2, PointRule);
+ELEM_MAP_ENTRY(3, DisplayAsText);
+ELEM_MAP_ENTRY(4, AllowOverpost);
 IOPointTypeStyle::IOPointTypeStyle()
     this->_pointTypeStyle = NULL;
@@ -42,17 +48,30 @@
 void IOPointTypeStyle::StartElement(const wchar_t *name, HandlerStack
*handlerStack)
-    if (m_currElemName == L"PointTypeStyle") // NOXLATE
+    case ePointTypeStyle:
         this->_pointTypeStyle = new PointTypeStyle();
+        break;
+    case ePointRule:
+            IOPointRule *IO = new IOPointRule(this->_pointTypeStyle);
+            handlerStack->push(IO);
+            IO->StartElement(name, handlerStack);
+        break;
+    case eUnknown:
+        break;
+    default:
+        break;
-    else if (m_currElemName == L"PointRule") // NOXLATE
-        IOPointRule *IO = new IOPointRule(this->_pointTypeStyle);
-        handlerStack->push(IO);
-        IO->StartElement(name, handlerStack);
 void IOPointTypeStyle::ElementChars(const wchar_t *ch)
@@ -67,6 +86,9 @@
+            this->_pointTypeStyle->SetUnknownXml(UnknownXml());
this->scaleRange->GetFeatureTypeStyles()->Adopt(this->_pointTypeStyle);
         this->scaleRange = NULL;
@@ -99,6 +121,12 @@
         delete IO;
+    if (!pointTypeStyle->GetUnknownXml().empty())
+        fd << toCString(pointTypeStyle->GetUnknownXml());
     dectab();
     fd << tab() << "</PointTypeStyle>" << std::endl; // NOXLATE
Index: E:/MgDev/OS/Common/MdfParser/MdfParser.vcproj
--- E:/MgDev/OS/Common/MdfParser/MdfParser.vcproj	(revision 1037)
+++ E:/MgDev/OS/Common/MdfParser/MdfParser.vcproj	(revision 1038)
@@ -328,6 +328,10 @@
 		</File>
 		<File
+			RelativePath=".\IOGridColorBands.cpp"
+		</File>
+		<File
 			RelativePath=".\IOGridColorRule.cpp"
 		</File>
@@ -536,6 +540,14 @@
 		</File>
 		<File
+			RelativePath=".\IOUnknown.cpp"
+		</File>
+		<File
+			RelativePath=".\IOUnknown.h"
+		</File>
+		<File
 			RelativePath=".\IOUtil.cpp"
 		</File>
@@ -580,6 +592,10 @@
 		</File>
 		<File
+			RelativePath=".\SAX2ElementHandler.cpp"
+		</File>
+		<File
 			RelativePath=".\SAX2ElementHandler.h"
 		</File>
Index: E:/MgDev/OS/Common/MdfParser/IOLabel.cpp
--- E:/MgDev/OS/Common/MdfParser/IOLabel.cpp	(revision 1037)
+++ E:/MgDev/OS/Common/MdfParser/IOLabel.cpp	(revision 1038)
@@ -23,6 +23,29 @@
+ELEM_MAP_ENTRY(1, Label);
+ELEM_MAP_ENTRY(2, AdvancedPlacement);
+ELEM_MAP_ENTRY(3, ScaleLimit);
+ELEM_MAP_ENTRY(4, Text);
+ELEM_MAP_ENTRY(5, FontName);
+ELEM_MAP_ENTRY(6, ForegroundColor);
+ELEM_MAP_ENTRY(7, BackgroundColor);
+ELEM_MAP_ENTRY(8, BackgroundStyle);
+ELEM_MAP_ENTRY(9, HorizontalAlignment);
+ELEM_MAP_ENTRY(10, VerticalAlignment);
+ELEM_MAP_ENTRY(11, Bold);
+ELEM_MAP_ENTRY(12, Italic);
+ELEM_MAP_ENTRY(13, Underlined);
+ELEM_MAP_ENTRY(14, Unit);
+ELEM_MAP_ENTRY(15, SizeContext);
+ELEM_MAP_ENTRY(16, SizeX);
+ELEM_MAP_ENTRY(17, SizeY);
+ELEM_MAP_ENTRY(18, InsertionPointX);
+ELEM_MAP_ENTRY(19, InsertionPointY);
+ELEM_MAP_ENTRY(20, Rotation);
+ELEM_MAP_ENTRY(21, MaintainAspect);
 IOLabel::IOLabel()
     this->_label = NULL;
@@ -44,16 +67,30 @@
 void IOLabel::StartElement(const wchar_t *name, HandlerStack
*handlerStack)
-    if (m_currElemName == L"Label") // NOXLATE
+    case eLabel:
         this->_label = new Label();
+        break;
+    case eAdvancedPlacement:
+        if (this->_label)
+            this->_label->GetSymbol()->SetAdvancedPlacement(true);
+            this->m_handlingPlacement = true;
+        break;
+    case eUnknown:
+        break;
+    default:
+        break;
-    else if (m_currElemName == L"AdvancedPlacement" && this->_label) //
NOXLATE
-        this->_label->GetSymbol()->SetAdvancedPlacement(true);
-        this->m_handlingPlacement = true;
 void IOLabel::ElementChars(const wchar_t *ch)
@@ -126,6 +163,9 @@
+            this->_label->SetUnknownXml(UnknownXml());
         this->rule->AdoptLabel(this->_label);
         this->rule= NULL;
@@ -231,6 +271,12 @@
             fd << tab() << "</AdvancedPlacement>" << std::endl; //
NOXLATE
+        if (!label->GetUnknownXml().empty())
+            fd << toCString(label->GetUnknownXml());
         dectab();
         fd << tab() << "</Label>" << std::endl; // NOXLATE
Index: E:/MgDev/OS/Common/MdfParser/IOBlockSymbol.cpp
--- E:/MgDev/OS/Common/MdfParser/IOBlockSymbol.cpp	(revision 1037)
+++ E:/MgDev/OS/Common/MdfParser/IOBlockSymbol.cpp	(revision 1038)
@@ -25,13 +25,41 @@
 // When a BlockSymbol is successfully parsed by this class, it must be
accessed by the
 // parent class and then managed appropriately.  It will not be deleted
by this class.
+// Inherited Symbol Elements
+ELEM_MAP_ENTRY(1, Unit);
+ELEM_MAP_ENTRY(2, SizeContext);
+ELEM_MAP_ENTRY(3, SizeX);
+ELEM_MAP_ENTRY(4, SizeY);
+ELEM_MAP_ENTRY(5, InsertionPointX);
+ELEM_MAP_ENTRY(6, InsertionPointY);
+ELEM_MAP_ENTRY(7, Rotation);
+ELEM_MAP_ENTRY(8, MaintainAspect);
+// Local Elements
+ELEM_MAP_ENTRY(9, Block);
+ELEM_MAP_ENTRY(10, DrawingName);
+ELEM_MAP_ENTRY(11, BlockName);
+ELEM_MAP_ENTRY(12, BlockColor);
+ELEM_MAP_ENTRY(13, LayerColor);
 void IOBlockSymbol::StartElement(const wchar_t *name, HandlerStack
*handlerStack)
     this->m_currElemName = name;
-    if (this->m_currElemName == L"Block") // NOXLATE
+    case eBlock:
         this->m_startElemName = name;
         this->m_symbol = new BlockSymbol();
+        break;
+    case eUnknown:
+        break;
+    default:
+        break;
@@ -54,6 +82,9 @@
+            this->m_symbol->SetUnknownXml(UnknownXml());
         this->m_startElemName = L"";
@@ -92,6 +123,12 @@
         fd << "</LayerColor>" << std::endl; // NOXLATE
+    if (!symbol->GetUnknownXml().empty())
+        fd << toCString(symbol->GetUnknownXml());
     dectab();
     fd << tab() << "</Block>" << std::endl; // NOXLATE
Index: E:/MgDev/OS/Common/MdfParser/IONameStringPair.cpp
--- E:/MgDev/OS/Common/MdfParser/IONameStringPair.cpp	(revision 1037)
+++ E:/MgDev/OS/Common/MdfParser/IONameStringPair.cpp	(revision 1038)
@@ -22,6 +22,12 @@
+ELEM_MAP_ENTRY(1, PropertyMapping);
+ELEM_MAP_ENTRY(2, Parameter);
+ELEM_MAP_ENTRY(3, Name);
+ELEM_MAP_ENTRY(4, Value);
 IONameStringPair::IONameStringPair()
 : _nameStringPair(NULL), layer(NULL), featureSource(NULL)
@@ -46,21 +52,32 @@
 void IONameStringPair::StartElement(const wchar_t *name, HandlerStack
*handlerStack)
-    if (NULL != layer)
-        if (m_currElemName == L"PropertyMapping") // NOXLATE
+    case ePropertyMapping:
+        if (NULL != layer)
             this->_nameStringPair = new NameStringPair(L"", L"");
-    else if (NULL != featureSource)
-        if (m_currElemName == L"Parameter") // NOXLATE
+        break;
+    case eParameter:
+        if (NULL != featureSource)
+        break;
+    case eUnknown:
+        break;
+    default:
+        break;
@@ -76,6 +93,9 @@
+            this->_nameStringPair->SetUnknownXml(UnknownXml());
         if (NULL != this->layer)
this->layer->GetPropertyMappings()->Adopt(this->_nameStringPair);
         else if (NULL != this->featureSource)
@@ -101,4 +121,10 @@
     fd << tab() << "<Value>"; // NOXLATE
     fd << EncodeString(nameStringPair->GetValue());
     fd << "</Value>" << std::endl; // NOXLATE
+    if (!nameStringPair->GetUnknownXml().empty())
+        fd << toCString(nameStringPair->GetUnknownXml());
Index: E:/MgDev/OS/Common/MdfParser/IOVectorScaleRange.cpp
--- E:/MgDev/OS/Common/MdfParser/IOVectorScaleRange.cpp	(revision 1037)
+++ E:/MgDev/OS/Common/MdfParser/IOVectorScaleRange.cpp	(revision 1038)
@@ -26,6 +26,14 @@
+ELEM_MAP_ENTRY(1, VectorScaleRange);
+ELEM_MAP_ENTRY(2, AreaTypeStyle);
+ELEM_MAP_ENTRY(3, LineTypeStyle);
+ELEM_MAP_ENTRY(4, PointTypeStyle);
+ELEM_MAP_ENTRY(5, MinScale);
+ELEM_MAP_ENTRY(6, MaxScale);
 IOVectorScaleRange::IOVectorScaleRange()
     this->_scaleRange = NULL;
@@ -45,29 +53,46 @@
 void IOVectorScaleRange::StartElement(const wchar_t *name, HandlerStack
*handlerStack)
-    if (m_currElemName == L"VectorScaleRange") // NOXLATE
+    case eVectorScaleRange:
         this->_scaleRange = new VectorScaleRange();
+        break;
+    case eAreaTypeStyle:
+            IOAreaTypeStyle *IO = new
IOAreaTypeStyle(this->_scaleRange);
+        break;
+    case eLineTypeStyle:
+            IOLineTypeStyle *IO = new
IOLineTypeStyle(this->_scaleRange);
+        break;
+            IOPointTypeStyle *IO = new
IOPointTypeStyle(this->_scaleRange);
+        break;
+    case eUnknown:
+        break;
+    default:
+        break;
-    else if (m_currElemName == L"AreaTypeStyle") // NOXLATE
-        IOAreaTypeStyle *IO = new IOAreaTypeStyle(this->_scaleRange);
-    else if (m_currElemName == L"LineTypeStyle") // NOXLATE
-        IOLineTypeStyle *IO = new IOLineTypeStyle(this->_scaleRange);
-    else if (m_currElemName == L"PointTypeStyle") // NOXLATE
-        IOPointTypeStyle *IO = new IOPointTypeStyle(this->_scaleRange);
 void IOVectorScaleRange::ElementChars(const wchar_t *ch)
@@ -82,6 +107,9 @@
+            this->_scaleRange->SetUnknownXml(UnknownXml());
         this->layer->GetScaleRanges()->Adopt(this->_scaleRange);
         this->layer = NULL;
@@ -135,6 +163,12 @@
+    if (!scaleRange->GetUnknownXml().empty())
+        fd << toCString(scaleRange->GetUnknownXml());
     dectab();
     fd << tab() << "</VectorScaleRange>" << std::endl; // NOXLATE
Index: E:/MgDev/OS/Common/MdfParser/IOGridLayerDefinition.cpp
--- E:/MgDev/OS/Common/MdfParser/IOGridLayerDefinition.cpp
(revision 1037)
+++ E:/MgDev/OS/Common/MdfParser/IOGridLayerDefinition.cpp
(revision 1038)
@@ -23,6 +23,15 @@
+ELEM_MAP_ENTRY(1, GridLayerDefinition);
+ELEM_MAP_ENTRY(2, GridScaleRange);
+ELEM_MAP_ENTRY(3, ResourceId);
+ELEM_MAP_ENTRY(4, FeatureName);
+ELEM_MAP_ENTRY(5, Geometry);
+ELEM_MAP_ENTRY(6, Filter);
+ELEM_MAP_ENTRY(7, Opacity);
 IOGridLayerDefinition::IOGridLayerDefinition():_layer(NULL)
@@ -38,16 +47,29 @@
 void IOGridLayerDefinition::StartElement(const wchar_t *name,
-    if (m_currElemName == L"GridLayerDefinition") // NOXLATE
+    case eGridLayerDefinition:
+        break;
+    case eGridScaleRange:
+            IOGridScaleRange *IO = new IOGridScaleRange(this->_layer);
+        break;
+    case eUnknown:
+        break;
+    default:
+        break;
-    else if (m_currElemName == L"GridScaleRange") // NOXLATE
-        IOGridScaleRange *IO = new IOGridScaleRange(this->_layer);
 void IOGridLayerDefinition::ElementChars(const wchar_t *ch)
@@ -68,6 +90,9 @@
+            this->_layer->SetUnknownXml(UnknownXml());
         this->_layer = NULL;
@@ -122,6 +147,12 @@
         delete IO;
+    if (!gridLayer->GetUnknownXml().empty())
+        fd << toCString(gridLayer->GetUnknownXml());
     dectab();
     fd << tab() << "</GridLayerDefinition>" << std::endl; // NOXLATE
Index: E:/MgDev/OS/Common/MdfParser/IOGridColorBands.cpp
--- E:/MgDev/OS/Common/MdfParser/IOGridColorBands.cpp	(revision 0)
+++ E:/MgDev/OS/Common/MdfParser/IOGridColorBands.cpp	(revision 1038)
@@ -0,0 +1,146 @@
+//  Copyright (C) 2004-2006  Autodesk, Inc.
+//  This library is free software; you can redistribute it and/or
+//  modify it under the terms of version 2.1 of the GNU Lesser
+//  General Public License as published by the Free Software
Foundation.
+//  This library is distributed in the hope that it will be useful,
+//  but WITHOUT ANY WARRANTY; without even the implied warranty of
+//  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+//  Lesser General Public License for more details.
+//  You should have received a copy of the GNU Lesser General Public
+//  License along with this library; if not, write to the Free Software
+//  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA
02110-1301  USA
+#include "stdafx.h"
+#include "IOGridColor.h"
+#include "IOChannelBand.h"
+#include "IOExtra.h"
+using namespace XERCES_CPP_NAMESPACE;
+using namespace MDFMODEL_NAMESPACE;
+using namespace MDFPARSER_NAMESPACE;
+ELEM_MAP_ENTRY(1, Bands);
+ELEM_MAP_ENTRY(2, RedBand);
+ELEM_MAP_ENTRY(3, GreenBand);
+ELEM_MAP_ENTRY(4, BlueBand);
+// IOGridColorBands
+IOGridColorBands::IOGridColorBands():color(NULL),redChannel(NULL),
greenChannel(NULL), blueChannel(NULL)
+IOGridColorBands::IOGridColorBands(GridColorRule * colorRule):
IOGridColor(colorRule),color(NULL),
redChannel(NULL), greenChannel(NULL), blueChannel(NULL)
+IOGridColorBands::~IOGridColorBands()
+void IOGridColorBands::StartElement(const wchar_t *name, HandlerStack
*handlerStack)
+    m_currElemName = name;
+    case eBands:
+        m_startElemName = name;
+        this->color = new GridColorBands();
+        break;
+    case eRedBand:
+            redChannel = new ChannelBand();
+            IOChannelBand* pIO = new IOChannelBand(redChannel,
m_currElemName);
+            handlerStack->push(pIO);
+            pIO->StartElement(name, handlerStack);
+        break;
+    case eGreenBand:
+            greenChannel = new ChannelBand();
+            IOChannelBand* pIO = new IOChannelBand(greenChannel,
m_currElemName);
+        break;
+    case eBlueBand:
+            blueChannel = new ChannelBand();
+            IOChannelBand* pIO = new IOChannelBand(blueChannel,
m_currElemName);
+        break;
+    case eUnknown:
+        break;
+    default:
+        break;
+void IOGridColorBands::ElementChars(const wchar_t *ch)
+void IOGridColorBands::EndElement(const wchar_t *name, HandlerStack
*handlerStack)
+    if (m_startElemName == name)
+            this->color->SetUnknownXml(UnknownXml());
+        this->color->SetRedBand(*redChannel);
+        this->color->SetGreenBand(*greenChannel);
+        this->color->SetBlueBand(*blueChannel);
+        this->colorRule->AdoptGridColor(color);
+        handlerStack->pop();
+        this->colorRule = NULL;
+        this->color     = NULL;
+        m_startElemName = L"";
+        delete this;
+void IOGridColorBands::Write(MdfStream &fd,  GridColorBands * pColor)
+    fd << tab() << "<Bands>" << std::endl; // NOXLATE
+    inctab();
+    std::auto_ptr<IOChannelBand> spIO;
+    spIO.reset(new IOChannelBand(L"RedBand")); // NOXLATE
+    spIO->Write(fd, &(pColor->GetRedBand()));
+    spIO.reset(new IOChannelBand(L"GreenBand")); // NOXLATE
+    spIO->Write(fd, &(pColor->GetGreenBand()));
+    spIO.reset(new IOChannelBand(L"BlueBand")); // NOXLATE
+    spIO->Write(fd, &(pColor->GetBlueBand()));
+    if (!pColor->GetUnknownXml().empty())
+        fd << toCString(pColor->GetUnknownXml());
+    dectab();
+    fd << tab() << "</Bands>" << std::endl; // NOXLATE
Property changes on: E:\MgDev\OS\Common\MdfParser\IOGridColorBands.cpp
___________________________________________________________________
   + native
Index: E:/MgDev/OS/Common/MdfParser/SAX2ElementHandler.cpp
--- E:/MgDev/OS/Common/MdfParser/SAX2ElementHandler.cpp	(revision 0)
+++ E:/MgDev/OS/Common/MdfParser/SAX2ElementHandler.cpp	(revision 1038)
@@ -0,0 +1,32 @@
Foundation.
02110-1301  USA
+#include "SAX2ElementHandler.h"
+#include "IOUnknown.h"
+void SAX2ElementHandler::ParseUnknownXml(const wchar_t *name,
+    IOUnknown *IO = new IOUnknown(&m_unknownXml);
Property changes on: E:\MgDev\OS\Common\MdfParser\SAX2ElementHandler.cpp
   + native
Index: E:/MgDev/OS/Common/MdfParser/IOGridColorStyle.cpp
--- E:/MgDev/OS/Common/MdfParser/IOGridColorStyle.cpp	(revision 1037)
+++ E:/MgDev/OS/Common/MdfParser/IOGridColorStyle.cpp	(revision 1038)
@@ -25,6 +25,14 @@
+ELEM_MAP_ENTRY(1, ColorStyle);
+ELEM_MAP_ENTRY(2, HillShade);
+ELEM_MAP_ENTRY(3, ColorRule);
+ELEM_MAP_ENTRY(4, TransparencyColor);
+ELEM_MAP_ENTRY(5, BrightnessFactor);
+ELEM_MAP_ENTRY(6, ContrastFactor);
 IOGridColorStyle::IOGridColorStyle():colorStyle(NULL), scaleRange(NULL)
@@ -40,23 +48,38 @@
 void IOGridColorStyle::StartElement(const wchar_t *name, HandlerStack
*handlerStack)
-    if (m_currElemName == L"ColorStyle") // NOXLATE
+    case eColorStyle:
         this->colorStyle = new GridColorStyle();
+        break;
+    case eHillShade:
+            IOHillShade *IO = new IOHillShade(this->colorStyle);
+        break;
+    case eColorRule:
+            IOGridColorRule *IO = new
IOGridColorRule(this->colorStyle);
+        break;
+    case eUnknown:
+        break;
+    default:
+        break;
-    else if (m_currElemName == L"HillShade") // NOXLATE
-        IOHillShade *IO = new IOHillShade(this->colorStyle);
-    else if (m_currElemName == L"ColorRule") // NOXLATE
-        IOGridColorRule *IO = new IOGridColorRule(this->colorStyle);
 void IOGridColorStyle::ElementChars(const wchar_t *ch)
@@ -73,6 +96,9 @@
+            this->colorStyle->SetUnknownXml(UnknownXml());
         this->scaleRange->AdoptColorStyle(this->colorStyle);
@@ -132,6 +158,12 @@
+    if (!pColorStyle->GetUnknownXml().empty())
+        fd << toCString(pColorStyle->GetUnknownXml());
     dectab();
     fd << tab() << "</ColorStyle>" << std::endl; // NOXLATE
Index: E:/MgDev/OS/Common/MdfParser/SAX2Parser.h
--- E:/MgDev/OS/Common/MdfParser/SAX2Parser.h	(revision 1037)
+++ E:/MgDev/OS/Common/MdfParser/SAX2Parser.h	(revision 1038)
@@ -69,18 +69,13 @@
         // Unfortunately, the SAX2 Parser doesn't necessarily send all
the
         // characters that appear inside a tag in one call of
characters()-
         // for example with escape characters it separates them into
separate calls.
-        // Therefore, m_strbuffer is used to accumulate the characters,
openTag and
-        // prevOpenTag are used to determine if we're still reading
characters in the
-        // same open tag, and tagOpen and charsInTag are used in the
case when you have
-        // no characters in between a tag (i.e. <Metadata></Metadata>)
to make sure
-        // that whitespace or line returns don't get assigned to it
instead.
+        // Therefore, m_strbuffer is used to accumulate the characters.
tagOpen is
+        // used in the case when you have characters outside a tag
+        // to make sure that whitespace or line returns don't get
assigned to it instead.
         std::wstring m_strbuffer;
+        bool m_tagOpen;
-        std::wstring m_openTag;
-        std::wstring m_prevOpenTag;
         MdfString m_strParserError;
-        bool m_tagOpen;
-        bool m_charsInTag;
         void WriteDefinition(MdfStream &fd,
                              MapDefinition* map,
Index: E:/MgDev/OS/Common/MdfParser/IOLineTypeStyle.cpp
--- E:/MgDev/OS/Common/MdfParser/IOLineTypeStyle.cpp	(revision 1037)
+++ E:/MgDev/OS/Common/MdfParser/IOLineTypeStyle.cpp	(revision 1038)
@@ -23,6 +23,10 @@
+ELEM_MAP_ENTRY(1, LineTypeStyle);
+ELEM_MAP_ENTRY(2, LineRule);
 IOLineTypeStyle::IOLineTypeStyle()
     this->_lineTypeStyle = NULL;
@@ -42,17 +46,30 @@
 void IOLineTypeStyle::StartElement(const wchar_t *name, HandlerStack
*handlerStack)
-    if (m_currElemName == L"LineTypeStyle") // NOXLATE
-        this->_lineTypeStyle = new LineTypeStyle(); // NOXLATE
+        this->_lineTypeStyle = new LineTypeStyle();
+        break;
+    case eLineRule:
+            IOLineRule *IO = new IOLineRule(this->_lineTypeStyle);
+        break;
+    case eUnknown:
+        break;
+    default:
+        break;
-    else if (m_currElemName == L"LineRule") // NOXLATE
-        IOLineRule *IO = new IOLineRule(this->_lineTypeStyle);
 void IOLineTypeStyle::ElementChars(const wchar_t *ch)
@@ -64,6 +81,9 @@
+            this->_lineTypeStyle->SetUnknownXml(UnknownXml());
this->scaleRange->GetFeatureTypeStyles()->Adopt(this->_lineTypeStyle);
@@ -86,6 +106,12 @@
         delete IO;
+    if (!lineTypeStyle->GetUnknownXml().empty())
+        fd << toCString(lineTypeStyle->GetUnknownXml());
     dectab();
     fd << tab() << "</LineTypeStyle>" << std::endl; // NOXLATE
Index: E:/MgDev/OS/Common/MdfParser/IOFeatureSource.cpp
--- E:/MgDev/OS/Common/MdfParser/IOFeatureSource.cpp	(revision 1037)
+++ E:/MgDev/OS/Common/MdfParser/IOFeatureSource.cpp	(revision 1038)
@@ -26,6 +26,16 @@
 #include "IOExtension.h"
 #include "IOSupplementalSpatialContextInfo.h"
+ELEM_MAP_ENTRY(1, FeatureSource);
+ELEM_MAP_ENTRY(3, Extension);
+ELEM_MAP_ENTRY(4, SupplementalSpatialContextInfo);
+ELEM_MAP_ENTRY(5, Provider);
+ELEM_MAP_ENTRY(6, ConfigurationDocument);
+ELEM_MAP_ENTRY(7, LongTransaction);
 IOFeatureSource::IOFeatureSource()
     : m_pFeatureSource(NULL)
@@ -43,32 +53,45 @@
 void IOFeatureSource::StartElement(const wchar_t *name, HandlerStack
*handlerStack)
-    if (m_currElemName == L"FeatureSource") // NOXLATE
-        m_startElemName = name;
+    switch (m_currElemId) {
+        case eFeatureSource:
+            break;
+        case eParameter:
+                IONameStringPair *IO = new
IONameStringPair(this->m_pFeatureSource);
+            break;
+        case eExtension:
+                IOExtension *IO = new
IOExtension(this->m_pFeatureSource);
+            break;
+        case eSupplementalSpatialContextInfo:
+                IOSupplementalSpatialContextInfo *IO =
+                    new
IOSupplementalSpatialContextInfo(this->m_pFeatureSource);
+            break;
+        case eUnknown:
+            break;
+        default:
+            break;
-    else
-            IONameStringPair *IO = new
-        else if (m_currElemName == L"Extension") // NOXLATE
-            IOExtension *IO = new IOExtension(this->m_pFeatureSource);
-        else if (m_currElemName == L"SupplementalSpatialContextInfo")
// NOXLATE
-            IOSupplementalSpatialContextInfo *IO =
-                new
 void IOFeatureSource::ElementChars(const wchar_t *ch)
@@ -85,6 +108,9 @@
+            this->m_pFeatureSource->SetUnknownXml(UnknownXml());
         this->m_pFeatureSource = NULL;
@@ -141,7 +167,14 @@
         spIO->Write(fd, pFeatureSource->GetExtensions()->GetAt(x));
+    if (!pFeatureSource->GetUnknownXml().empty())
+        fd << toCString(pFeatureSource->GetUnknownXml());
     dectab();
     fd << tab() << "</FeatureSource>" << std::endl; // NOXLATE
Index: E:/MgDev/OS/Common/MdfParser/IORelateProperty.cpp
--- E:/MgDev/OS/Common/MdfParser/IORelateProperty.cpp	(revision 1037)
+++ E:/MgDev/OS/Common/MdfParser/IORelateProperty.cpp	(revision 1038)
@@ -22,6 +22,11 @@
+ELEM_MAP_ENTRY(1, RelateProperty);
+ELEM_MAP_ENTRY(2, FeatureClassProperty);
+ELEM_MAP_ENTRY(3, AttributeClassProperty);
 IORelateProperty::IORelateProperty()
     : m_pRelateProperty(NULL), m_pAttributeRelate(NULL)
@@ -39,10 +44,21 @@
 void IORelateProperty::StartElement(const wchar_t *name, HandlerStack
*handlerStack)
-    if (m_currElemName == L"RelateProperty") // NOXLATE
+    case eRelateProperty:
         m_pRelateProperty = new RelateProperty();
+        break;
+    case eUnknown:
+        break;
+    default:
+        break;
@@ -65,6 +81,9 @@
+            this->m_pRelateProperty->SetUnknownXml(UnknownXml());
m_pAttributeRelate->GetRelateProperties()->Adopt(m_pRelateProperty);
         this->m_pRelateProperty = NULL;
@@ -89,7 +108,14 @@
     fd << EncodeString(pRelateProperty->GetAttributeClassProperty());
     fd << "</AttributeClassProperty>" << std::endl; // NOXLATE
+    if (!pRelateProperty->GetUnknownXml().empty())
+        fd << toCString(pRelateProperty->GetUnknownXml());
     dectab();
     fd << tab() << "</RelateProperty>" << std::endl; // NOXLATE
Index: E:/MgDev/OS/Common/MdfParser/IOUtil.h
--- E:/MgDev/OS/Common/MdfParser/IOUtil.h	(revision 1037)
+++ E:/MgDev/OS/Common/MdfParser/IOUtil.h	(revision 1038)
@@ -73,5 +73,8 @@
         return false;
+    std::string startStr(const std::string elementName);
+    std::string endStr(const std::string elementName);
 END_NAMESPACE_MDFPARSER
 #endif // _IOUTIL_H
Index: E:/MgDev/OS/Common/MdfParser/IOAreaSymbolization2D.cpp
--- E:/MgDev/OS/Common/MdfParser/IOAreaSymbolization2D.cpp
(revision 1037)
+++ E:/MgDev/OS/Common/MdfParser/IOAreaSymbolization2D.cpp
(revision 1038)
@@ -24,6 +24,11 @@
+ELEM_MAP_ENTRY(1, AreaSymbolization2D);
+ELEM_MAP_ENTRY(2, Fill);
+ELEM_MAP_ENTRY(3, Stroke);
 IOAreaSymbolization2D::IOAreaSymbolization2D()
     this->_areaSymbolization = NULL;
@@ -43,28 +48,43 @@
 void IOAreaSymbolization2D::StartElement(const wchar_t *name,
-    if (m_currElemName == L"AreaSymbolization2D")  // NOXLATE
+    case eAreaSymbolization2D:
         this->_areaSymbolization = new AreaSymbolization2D();
         // delete the fill and edge that are created by default -
recreate if present when parsing
         delete this->_areaSymbolization->OrphanFill();
         delete this->_areaSymbolization->OrphanEdge();
+        break;
+    case eFill:
+            this->_areaSymbolization->AdoptFill(new Fill());
+            IOFill *IO = new
IOFill(this->_areaSymbolization->GetFill());
+        break;
+    case eStroke:
+            this->_areaSymbolization->AdoptEdge(new Stroke());
+            IOStroke *IO = new
IOStroke(this->_areaSymbolization->GetEdge(), m_currElemName);
+        break;
+    case eUnknown:
+        break;
+    default:
+        break;
-    else if (m_currElemName == L"Fill") // NOXLATE
-        this->_areaSymbolization->AdoptFill(new Fill());
-        IOFill *IO = new IOFill(this->_areaSymbolization->GetFill());
-    else if (m_currElemName == L"Stroke") // NOXLATE
-        this->_areaSymbolization->AdoptEdge(new Stroke());
-        IOStroke *IO = new
 void IOAreaSymbolization2D::ElementChars(const wchar_t *ch)
@@ -76,6 +96,9 @@
+            this->_areaSymbolization->SetUnknownXml(UnknownXml());
         if (this->_areaSymbolization != NULL)
this->areaRule->AdoptSymbolization(this->_areaSymbolization);
@@ -99,6 +122,12 @@
     if (areaSymbolization != NULL && areaSymbolization->GetEdge() !=
NULL)
         IOStroke::Write(fd, areaSymbolization->GetEdge(), "Stroke"); //
NOXLATE
+    if (!areaSymbolization->GetUnknownXml().empty())
+        fd << toCString(areaSymbolization->GetUnknownXml());
     dectab();
     fd << tab() << "</AreaSymbolization2D>" << std::endl; // NOXLATE
Index: E:/MgDev/OS/Common/MdfParser/IOGridColor.cpp
--- E:/MgDev/OS/Common/MdfParser/IOGridColor.cpp	(revision 1037)
+++ E:/MgDev/OS/Common/MdfParser/IOGridColor.cpp	(revision 1038)
@@ -24,6 +24,12 @@
+ELEM_MAP_ENTRY(1, Color);
+ELEM_MAP_ENTRY(2, Bands);
+ELEM_MAP_ENTRY(3, ExplicitColor);
+ELEM_MAP_ENTRY(4, Band);
 IOGridColor::IOGridColor():colorRule(NULL)
@@ -39,16 +45,29 @@
 void IOGridColor::StartElement(const wchar_t *name, HandlerStack
*handlerStack)
-    if (m_currElemName == L"Color") // NOXLATE
+    case eColor:
+        break;
+    case eBands:
+            IOGridColorBands* pIO = new IOGridColorBands(colorRule);
+        break;
+    case eUnknown:
+        break;
+    default:
+        break;
-    else if (m_currElemName == L"Bands") // NOXLATE
-        IOGridColorBands* pIO = new IOGridColorBands(colorRule);
-        handlerStack->push(pIO);
-        pIO->StartElement(name, handlerStack);
 void IOGridColor::ElementChars(const wchar_t *ch)
@@ -71,6 +90,9 @@
+            this->colorRule->SetUnknownXml(UnknownXml());
@@ -107,95 +129,13 @@
         delete pIO;
-    dectab();
-    fd << tab() << "</Color>" << std::endl; // NOXLATE
-// IOGridColorBands
-IOGridColorBands::IOGridColorBands():color(NULL),redChannel(NULL),
-IOGridColorBands::IOGridColorBands(GridColorRule * colorRule):
-IOGridColorBands::~IOGridColorBands()
-void IOGridColorBands::StartElement(const wchar_t *name, HandlerStack
*handlerStack)
-    m_currElemName = name;
-    if (m_currElemName == L"Bands") // NOXLATE
-        this->color = new GridColorBands();
-    else if (m_currElemName == L"RedBand") // NOXLATE
-        redChannel = new ChannelBand();
-        IOChannelBand* pIO = new IOChannelBand(redChannel,
m_currElemName);
-    else if (m_currElemName == L"GreenBand") // NOXLATE
-        greenChannel = new ChannelBand();
-        IOChannelBand* pIO = new IOChannelBand(greenChannel,
m_currElemName);
-    else if (m_currElemName == L"BlueBand") // NOXLATE
-        blueChannel = new ChannelBand();
-        IOChannelBand* pIO = new IOChannelBand(blueChannel,
m_currElemName);
-void IOGridColorBands::ElementChars(const wchar_t *ch)
-void IOGridColorBands::EndElement(const wchar_t *name, HandlerStack
*handlerStack)
-    if (m_startElemName == name)
-        this->color->SetRedBand(*redChannel);
-        this->color->SetGreenBand(*greenChannel);
-        this->color->SetBlueBand(*blueChannel);
-        this->colorRule->AdoptGridColor(color);
-        handlerStack->pop();
-        this->colorRule = NULL;
-        this->color     = NULL;
-        m_startElemName = L"";
-        delete this;
-void IOGridColorBands::Write(MdfStream &fd,  GridColorBands * pColor)
-    fd << tab() << "<Bands>" << std::endl; // NOXLATE
-    inctab();
-    std::auto_ptr<IOChannelBand> spIO;
-    spIO.reset(new IOChannelBand(L"RedBand")); // NOXLATE
-    spIO->Write(fd, &(pColor->GetRedBand()));
-    spIO.reset(new IOChannelBand(L"GreenBand")); // NOXLATE
-    spIO->Write(fd, &(pColor->GetGreenBand()));
-    spIO.reset(new IOChannelBand(L"BlueBand")); // NOXLATE
-    spIO->Write(fd, &(pColor->GetBlueBand()));
     dectab();
-    fd << tab() << "</Bands>" << std::endl; // NOXLATE
+    fd << tab() << "</Color>" << std::endl; // NOXLATE
Index: E:/MgDev/OS/Common/MdfParser/IOFill.cpp
--- E:/MgDev/OS/Common/MdfParser/IOFill.cpp	(revision 1037)
+++ E:/MgDev/OS/Common/MdfParser/IOFill.cpp	(revision 1038)
@@ -22,6 +22,12 @@
+ELEM_MAP_ENTRY(1, Fill);
+ELEM_MAP_ENTRY(2, FillPattern);
+ELEM_MAP_ENTRY(3, ForegroundColor);
+ELEM_MAP_ENTRY(4, BackgroundColor);
 IOFill::IOFill()
     this->_fill = NULL;
@@ -39,8 +45,21 @@
 void IOFill::StartElement(const wchar_t *name, HandlerStack
*handlerStack)
-    if (m_currElemName == L"Fill") // NOXLATE
+    case eFill:
+        break;
+    case eUnknown:
+        break;
+    default:
+        break;
 void IOFill::ElementChars(const wchar_t *ch)
@@ -57,6 +76,9 @@
+            this->_fill->SetUnknownXml(UnknownXml());
         this->_fill = NULL;
@@ -84,6 +106,12 @@
     fd << EncodeString(fill->GetBackgroundColor());
     fd << "</BackgroundColor>" << std::endl; // NOXLATE
+    if (!fill->GetUnknownXml().empty())
+        fd << toCString(fill->GetUnknownXml());
     dectab();
     fd << tab() << "</Fill>" << std::endl; // NOXLATE
Index: E:/MgDev/OS/Common/MdfParser/IOAreaTypeStyle.cpp
--- E:/MgDev/OS/Common/MdfParser/IOAreaTypeStyle.cpp	(revision 1037)
+++ E:/MgDev/OS/Common/MdfParser/IOAreaTypeStyle.cpp	(revision 1038)
@@ -23,6 +23,10 @@
+ELEM_MAP_ENTRY(1, AreaTypeStyle);
+ELEM_MAP_ENTRY(2, AreaRule);
 IOAreaTypeStyle::IOAreaTypeStyle()
     this->_areaTypeStyle = NULL;
@@ -42,17 +46,30 @@
 void IOAreaTypeStyle::StartElement(const wchar_t *name, HandlerStack
*handlerStack)
-    if (m_currElemName == L"AreaTypeStyle") // NOXLATE
         this->_areaTypeStyle = new AreaTypeStyle();
+        break;
+    case eAreaRule:
+            IOAreaRule *IO = new IOAreaRule(this->_areaTypeStyle);
+        break;
+    case eUnknown:
+        break;
+    default:
+        break;
-    else if (m_currElemName == L"AreaRule") // NOXLATE
-        IOAreaRule *IO = new IOAreaRule(this->_areaTypeStyle);
 void IOAreaTypeStyle::ElementChars(const wchar_t *ch)
@@ -64,6 +81,9 @@
+            this->_areaTypeStyle->SetUnknownXml(UnknownXml());
this->scaleRange->GetFeatureTypeStyles()->Adopt(this->_areaTypeStyle);
@@ -86,6 +106,12 @@
         delete IO;
+    if (!areaTypeStyle->GetUnknownXml().empty())
+        fd << toCString(areaTypeStyle->GetUnknownXml());
     dectab();
     fd << tab() << "</AreaTypeStyle>" << std::endl; // NOXLATE
Index: E:/MgDev/OS/Common/MdfParser/IOHillShade.cpp
--- E:/MgDev/OS/Common/MdfParser/IOHillShade.cpp	(revision 1037)
+++ E:/MgDev/OS/Common/MdfParser/IOHillShade.cpp	(revision 1038)
@@ -22,6 +22,13 @@
+ELEM_MAP_ENTRY(1, HillShade);
+ELEM_MAP_ENTRY(2, Band);
+ELEM_MAP_ENTRY(3, Azimuth);
+ELEM_MAP_ENTRY(4, Altitude);
+ELEM_MAP_ENTRY(5, ScaleFactor);
 IOHillShade::IOHillShade():colorStyle(NULL),hillShade(NULL)
@@ -37,10 +44,21 @@
 void IOHillShade::StartElement(const wchar_t *name, HandlerStack
*handlerStack)
-    if (m_currElemName == L"HillShade") // NOXLATE
+    case eHillShade:
         this->hillShade = new HillShade();
+        break;
+    case eUnknown:
+        break;
+    default:
+        break;
@@ -60,6 +78,9 @@
+            this->hillShade->SetUnknownXml(UnknownXml());
         this->colorStyle->AdoptHillShade(this->hillShade);
         this->colorStyle = NULL;
@@ -97,6 +118,12 @@
         fd << "</ScaleFactor>" << std::endl; // NOXLATE
+    if (!pHillShade->GetUnknownXml().empty())
+        fd << toCString(pHillShade->GetUnknownXml());
     dectab();
     fd << tab() << "</HillShade>" << std::endl; // NOXLATE
Index: E:/MgDev/OS/Common/MdfParser/IOChannelBand.cpp
--- E:/MgDev/OS/Common/MdfParser/IOChannelBand.cpp	(revision 1037)
+++ E:/MgDev/OS/Common/MdfParser/IOChannelBand.cpp	(revision 1038)
@@ -22,6 +22,18 @@
+// From Grid Color - Start Elements
+ELEM_MAP_ENTRY(1, RedBand);
+ELEM_MAP_ENTRY(2, GreenBand);
+ELEM_MAP_ENTRY(3, BlueBand);
+// Local Elements
+ELEM_MAP_ENTRY(5, LowBand);
+ELEM_MAP_ENTRY(6, HighBand);
+ELEM_MAP_ENTRY(7, LowChannel);
+ELEM_MAP_ENTRY(8, HighChannel);
 IOChannelBand::IOChannelBand(const std::wstring &strElemName)
 : m_pChannel(NULL), m_strElemName(strElemName)
@@ -39,11 +51,24 @@
 void IOChannelBand::StartElement(const wchar_t *name, HandlerStack
*handlerStack)
-    if (m_currElemName == m_strElemName)
+    case eRedBand:
+    case eGreenBand:
+    case eBlueBand:
         if (NULL == this->m_pChannel)
             m_pChannel = new ChannelBand();
+        break;
+    case eUnknown:
+        break;
+    default:
+        break;
@@ -70,6 +95,9 @@
+            this->m_pChannel->SetUnknownXml(UnknownXml());
         this->m_pChannel     = NULL;
@@ -115,6 +143,11 @@
         fd << "</HighChannel>" << std::endl; // NOXLATE
+    if (!pChannel->GetUnknownXml().empty())
+        fd << toCString(pChannel->GetUnknownXml());
     dectab();
     fd << tab() << "</" << EncodeString(this->m_strElemName) << '>'  <<
Index: E:/MgDev/OS/Common/MdfParser/IOAreaRule.cpp
--- E:/MgDev/OS/Common/MdfParser/IOAreaRule.cpp	(revision 1037)
+++ E:/MgDev/OS/Common/MdfParser/IOAreaRule.cpp	(revision 1038)
@@ -24,6 +24,13 @@
+ELEM_MAP_ENTRY(1, AreaRule);
+ELEM_MAP_ENTRY(2, AreaSymbolization2D);
+ELEM_MAP_ENTRY(3, Label);
+ELEM_MAP_ENTRY(4, LegendLabel);
+ELEM_MAP_ENTRY(5, Filter);
 IOAreaRule::IOAreaRule()
     this->_areaRule = NULL;
@@ -43,24 +50,38 @@
 void IOAreaRule::StartElement(const wchar_t *name, HandlerStack
*handlerStack)
-    if (m_currElemName == L"AreaRule") // NOXLATE
+    case eAreaRule:
         this->_areaRule = new AreaRule();
+        break;
+            IOAreaSymbolization2D *IO = new
IOAreaSymbolization2D(this->_areaRule);
+        break;
+    case eLabel:
+            IOLabel *IO = new IOLabel(this->_areaRule);
+        break;
+    case eUnknown:
+        break;
+    default:
+        break;
-    else if (m_currElemName == L"AreaSymbolization2D") // NOXLATE
-        IOAreaSymbolization2D *IO = new
-    else if (m_currElemName == L"Label") // NOXLATE
-        IOLabel *IO = new IOLabel(this->_areaRule);
 void IOAreaRule::ElementChars(const wchar_t *ch)
@@ -75,6 +96,9 @@
+            this->_areaRule->SetUnknownXml(UnknownXml());
         this->areaTypeStyle->GetRules()->Adopt(this->_areaRule);
         this->areaTypeStyle= NULL;
@@ -116,6 +140,12 @@
     IO->Write(fd, symbolization);
     delete IO;
+    if (!areaRule->GetUnknownXml().empty())
+        fd << toCString(areaRule->GetUnknownXml());
     dectab();
     fd << tab() << "</AreaRule>" << std::endl; // NOXLATE
Index: E:/MgDev/OS/Common/MdfParser/IODrawingLayerDefinition.cpp
--- E:/MgDev/OS/Common/MdfParser/IODrawingLayerDefinition.cpp
(revision 1037)
+++ E:/MgDev/OS/Common/MdfParser/IODrawingLayerDefinition.cpp
(revision 1038)
@@ -23,6 +23,15 @@
+ELEM_MAP_ENTRY(1, DrawingLayerDefinition);
+ELEM_MAP_ENTRY(2, Opacity);
+ELEM_MAP_ENTRY(4, Sheet);
+ELEM_MAP_ENTRY(5, LayerFilter);
+ELEM_MAP_ENTRY(6, MinScale);
+ELEM_MAP_ENTRY(7, MaxScale);
 IODrawingLayerDefinition::IODrawingLayerDefinition()
@@ -40,9 +49,20 @@
 void IODrawingLayerDefinition::StartElement(const wchar_t *name,
-    if (m_currElemName == L"DrawingLayerDefinition") // NOXLATE
+    case eDrawingLayerDefinition:
+        break;
+    case eUnknown:
+        break;
+    default:
+        break;
@@ -66,6 +86,9 @@
@@ -123,6 +146,12 @@
         fd << "</MaxScale>" << std::endl; // NOXLATE
+    if (!drawingLayer->GetUnknownXml().empty())
+        fd << toCString(drawingLayer->GetUnknownXml());
     dectab();
     fd << tab() << "</DrawingLayerDefinition>" << std::endl; // NOXLATE
Index: E:/MgDev/OS/Common/MdfParser/IOPointSymbolization2D.cpp
--- E:/MgDev/OS/Common/MdfParser/IOPointSymbolization2D.cpp
(revision 1037)
+++ E:/MgDev/OS/Common/MdfParser/IOPointSymbolization2D.cpp
(revision 1038)
@@ -28,6 +28,14 @@
+ELEM_MAP_ENTRY(1, PointSymbolization2D);
+ELEM_MAP_ENTRY(2, Mark);
+ELEM_MAP_ENTRY(3, Image);
+ELEM_MAP_ENTRY(4, Font);
+ELEM_MAP_ENTRY(5, W2D);
+ELEM_MAP_ENTRY(6, Block);
 IOPointSymbolization2D::IOPointSymbolization2D()
     this->_PointSymbolization2D = NULL;
@@ -49,23 +57,37 @@
 void IOPointSymbolization2D::StartElement(const wchar_t *name,
-    if (m_currElemName == L"PointSymbolization2D") // NOXLATE
+    if (m_currElemId == ePointSymbolization2D)
         this->_PointSymbolization2D = new PointSymbolization2D();
+    else if (m_currElemId == eUnknown)
     else
-        if (m_currElemName == L"Mark") // NOXLATE
+        case eMark:
             this->ioSymbol = new IOMarkSymbol();
-        else if (m_currElemName == L"Image") // NOXLATE
+            break;
+        case eImage:
             this->ioSymbol = new IOImageSymbol();
-        else if (m_currElemName == L"Font") // NOXLATE
+            break;
+        case eFont:
             this->ioSymbol = new IOFontSymbol();
-        else if (m_currElemName == L"W2D") // NOXLATE
+            break;
+        case eW2D:
             this->ioSymbol = new IOW2DSymbol();
-        else if (m_currElemName == L"Block") // NOXLATE
+            break;
+        case eBlock:
             this->ioSymbol = new IOBlockSymbol();
+            break;
         if (this->ioSymbol)
             handlerStack->push(this->ioSymbol);
@@ -84,6 +106,9 @@
         if (this->_PointSymbolization2D != NULL)
this->_PointSymbolization2D->SetUnknownXml(UnknownXml());
this->pointRule->AdoptSymbolization(this->_PointSymbolization2D);
             if (this->ioSymbol != NULL)
     else if (blockSymbol)
         IOBlockSymbol::Write(fd, blockSymbol);
+    if (!PointSymbolization2D->GetUnknownXml().empty())
+        fd << toCString(PointSymbolization2D->GetUnknownXml());
     dectab();
     fd << tab() << "</PointSymbolization2D>" << std::endl; // NOXLATE
Index: E:/MgDev/OS/Common/MdfParser/IOExtension.cpp
--- E:/MgDev/OS/Common/MdfParser/IOExtension.cpp	(revision 1037)
+++ E:/MgDev/OS/Common/MdfParser/IOExtension.cpp	(revision 1038)
@@ -24,6 +24,13 @@
+ELEM_MAP_ENTRY(1, Extension);
+ELEM_MAP_ENTRY(2, CalculatedProperty);
+ELEM_MAP_ENTRY(3, AttributeRelate);
+ELEM_MAP_ENTRY(4, Name);
+ELEM_MAP_ENTRY(5, FeatureClass);
 IOExtension::IOExtension()
     : m_pExtension(NULL), m_pFeatureSource(NULL)
@@ -41,26 +48,37 @@
 void IOExtension::StartElement(const wchar_t *name, HandlerStack
*handlerStack)
-    if (m_currElemName == L"Extension") // NOXLATE
-        m_pExtension = new Extension();
+        case eExtension:
+            m_pExtension = new Extension();
+            break;
+                IOCalculatedProperty *IO = new
IOCalculatedProperty(this->m_pExtension);
+            break;
+        case eAttributeRelate:
+                IOAttributeRelate *IO = new
IOAttributeRelate(this->m_pExtension);
+            break;
+        case eUnknown:
+            break;
+        default:
+            break;
-    else
-            IOCalculatedProperty *IO = new
-        else if (m_currElemName == L"AttributeRelate") // NOXLATE
-            IOAttributeRelate *IO = new
 void IOExtension::ElementChars(const wchar_t *ch)
@@ -75,6 +93,9 @@
+            m_pExtension->SetUnknownXml(UnknownXml());
         m_pFeatureSource->GetExtensions()->Adopt(m_pExtension);
         this->m_pExtension = NULL;
@@ -112,7 +133,14 @@
         spIO->Write(fd, pExtension->GetAttributeRelates()->GetAt(x));
+    if (!pExtension->GetUnknownXml().empty())
+        fd << toCString(pExtension->GetUnknownXml());
     dectab();
     fd << tab() << "</Extension>" << std::endl; // NOXLATE
Index: E:/MgDev/OS/Common/MdfParser/IOGridColorRule.cpp
--- E:/MgDev/OS/Common/MdfParser/IOGridColorRule.cpp	(revision 1037)
+++ E:/MgDev/OS/Common/MdfParser/IOGridColorRule.cpp	(revision 1038)
@@ -25,6 +25,13 @@
+ELEM_MAP_ENTRY(1, ColorRule);
+ELEM_MAP_ENTRY(2, Color);
 IOGridColorRule::IOGridColorRule():colorStyle(NULL), colorRule(NULL)
@@ -40,23 +47,38 @@
 void IOGridColorRule::StartElement(const wchar_t *name, HandlerStack
*handlerStack)
-    if (m_currElemName == L"ColorRule") // NOXLATE
+    case eColorRule:
         this->colorRule = new GridColorRule();
+        break;
+    case eColor:
+            IOGridColor *IO = new IOGridColor(this->colorRule);
+        break;
+    case eLabel:
+            IOLabel *IO = new IOLabel(this->colorRule);
+        break;
+    case eUnknown:
+        break;
+    default:
+        break;
-    else if (m_currElemName == L"Color")  // NOXLATE
-        IOGridColor *IO = new IOGridColor(this->colorRule);
-        IOLabel *IO = new IOLabel(this->colorRule);
 void IOGridColorRule::ElementChars(const wchar_t *ch)
@@ -71,6 +93,9 @@
         this->colorStyle->GetRules()->Adopt(this->colorRule);
@@ -110,6 +135,12 @@
     pIO->Write(fd, pColorRule->GetGridColor());
     delete pIO;
+    if (!pColorRule->GetUnknownXml().empty())
+        fd << toCString(pColorRule->GetUnknownXml());
     dectab();
     fd << tab() << "</ColorRule>" << std::endl; // NOXLATE
Index: E:/MgDev/OS/Common/MdfParser/IOUtil.cpp
--- E:/MgDev/OS/Common/MdfParser/IOUtil.cpp	(revision 1037)
+++ E:/MgDev/OS/Common/MdfParser/IOUtil.cpp	(revision 1038)
@@ -159,4 +159,20 @@
     return std::string("false"); // NOXLATE
+std::string startStr(const std::string elementName)
+    std::string out("<"); // NOXLATE
+    out.append(elementName);
+    out.append(">");  // NOXLATE
+    return out;
+std::string endStr(const std::string elementName)
+    std::string out("</"); // NOXLATE
+    return out;
Index: E:/MgDev/OS/Common/MdfParser/IOLineRule.cpp
--- E:/MgDev/OS/Common/MdfParser/IOLineRule.cpp	(revision 1037)
+++ E:/MgDev/OS/Common/MdfParser/IOLineRule.cpp	(revision 1038)
@@ -24,6 +24,13 @@
+ELEM_MAP_ENTRY(1, LineRule);
+ELEM_MAP_ENTRY(2, LineSymbolization2D);
 IOLineRule::IOLineRule()
     this->_lineRule = NULL;
@@ -43,23 +50,38 @@
 void IOLineRule::StartElement(const wchar_t *name, HandlerStack
*handlerStack)
-    if (m_currElemName == L"LineRule") // NOXLATE
+    case eLineRule:
         this->_lineRule = new LineRule();
+        break;
+    case eLineSymbolization2D:
+            IOLineSymbolization2D *IO = new
IOLineSymbolization2D(this->_lineRule);
+        break;
+    case eLabel:
+            IOLabel *IO = new IOLabel(this->_lineRule);
+        break;
+    case eUnknown:
+        break;
+    default:
+        break;
-    else if (m_currElemName == L"LineSymbolization2D") // NOXLATE
-        IOLineSymbolization2D *IO = new
-        IOLabel *IO = new IOLabel(this->_lineRule);
 void IOLineRule::ElementChars(const wchar_t *ch)
@@ -74,6 +96,9 @@
+            this->_lineRule->SetUnknownXml(UnknownXml());
         this->lineTypeStyle->GetRules()->Adopt(this->_lineRule);
         this->lineTypeStyle= NULL;
@@ -116,6 +141,12 @@
         delete IO;
+    if (!lineRule->GetUnknownXml().empty())
+        fd << toCString(lineRule->GetUnknownXml());
     dectab();
     fd << tab() << "</LineRule>" << std::endl; // NOXLATE
Index: E:/MgDev/OS/Common/MdfParser/IOW2DSymbol.cpp
--- E:/MgDev/OS/Common/MdfParser/IOW2DSymbol.cpp	(revision 1037)
+++ E:/MgDev/OS/Common/MdfParser/IOW2DSymbol.cpp	(revision 1038)
@@ -25,6 +25,23 @@
 // When a W2DSymbol is successfully parsed by this class, it must be
accessed by the
by this class.
+// Local Elements
+ELEM_MAP_ENTRY(9, W2D);
+ELEM_MAP_ENTRY(10, W2DSymbol);
+ELEM_MAP_ENTRY(11, FillColor);
+ELEM_MAP_ENTRY(12, LineColor);
+ELEM_MAP_ENTRY(13, TextColor);
 IOW2DSymbol::IOW2DSymbol() : IOSymbol()
     this->m_ioResourceRef = NULL;
@@ -33,17 +50,30 @@
 void IOW2DSymbol::StartElement(const wchar_t *name, HandlerStack
*handlerStack)
-    if (this->m_currElemName == L"W2D") // NOXLATE
+    case eW2D:
         this->m_symbol = new W2DSymbol(L"", L"");
+        break;
+    case eW2DSymbol:
+            this->m_ioResourceRef = new IOResourceRef(name);
+            handlerStack->push(this->m_ioResourceRef);
+            this->m_ioResourceRef->StartElement(name, handlerStack);
+        break;
+    case eUnknown:
+        break;
+    default:
+        break;
-    else if (this->m_currElemName == L"W2DSymbol") // NOXLATE
-        this->m_ioResourceRef = new IOResourceRef(name);
-        handlerStack->push(this->m_ioResourceRef);
-        this->m_ioResourceRef->StartElement(name, handlerStack);
 void IOW2DSymbol::ElementChars(const wchar_t *ch)
@@ -63,6 +93,9 @@
     if (this->m_startElemName == name)
         // copy the values found by the IOResourceRef into our symbol
         W2DSymbol* symbol = static_cast<W2DSymbol*>(this->m_symbol);
         if (this->m_ioResourceRef)
@@ -112,6 +145,12 @@
         fd << "</TextColor>" << std::endl; // NOXLATE
     dectab();
     fd << tab() << "</W2D>" << std::endl; // NOXLATE
Index: E:/MgDev/OS/Common/MdfParser/IOFontSymbol.cpp
--- E:/MgDev/OS/Common/MdfParser/IOFontSymbol.cpp	(revision 1037)
+++ E:/MgDev/OS/Common/MdfParser/IOFontSymbol.cpp	(revision 1038)
@@ -25,13 +25,43 @@
 // When a FontSymbol is successfully parsed by this class, it must be
accessed by the
by this class.
+// Local Elements
+ELEM_MAP_ENTRY(9, Font);
+ELEM_MAP_ENTRY(10, FontName);
+ELEM_MAP_ENTRY(11, Character);
+ELEM_MAP_ENTRY(12, Bold);
+ELEM_MAP_ENTRY(13, Italic);
+ELEM_MAP_ENTRY(14, Underlined);
+ELEM_MAP_ENTRY(15, ForegroundColor);
 void IOFontSymbol::StartElement(const wchar_t *name, HandlerStack
*handlerStack)
-    if (this->m_currElemName == L"Font") // NOXLATE
+    case eFont:
         this->m_symbol = new FontSymbol();
+        break;
+    case eUnknown:
+        break;
+    default:
+        break;
@@ -58,6 +88,9 @@
     fd << EncodeString(symbol->GetForegroundColor());
     fd << "</ForegroundColor>" << std::endl; // NOXLATE
     dectab();
     fd << tab() << "</Font>" << std::endl; // NOXLATE
Index: E:/MgDev/OS/Common/MdfParser/IOLineSymbolization2D.cpp
--- E:/MgDev/OS/Common/MdfParser/IOLineSymbolization2D.cpp
(revision 1037)
+++ E:/MgDev/OS/Common/MdfParser/IOLineSymbolization2D.cpp
(revision 1038)
@@ -23,6 +23,13 @@
+ELEM_MAP_ENTRY(1, LineSymbolization2D);
+ELEM_MAP_ENTRY(2, LineStyle);
+ELEM_MAP_ENTRY(3, Thickness);
+ELEM_MAP_ENTRY(4, Color);
+ELEM_MAP_ENTRY(5, Unit);
 IOLineSymbolization2D::IOLineSymbolization2D()
     this->_lineSymbolization = NULL;
@@ -42,10 +49,21 @@
 void IOLineSymbolization2D::StartElement(const wchar_t *name,
-    if (m_currElemName == L"LineSymbolization2D") // NOXLATE
         this->_lineSymbolization = new LineSymbolization2D();
+        break;
+    case eUnknown:
+        break;
+    default:
+        break;
@@ -68,6 +86,9 @@
+            this->_lineSymbolization->SetUnknownXml(UnknownXml());
this->lineRule->GetSymbolizations()->Adopt(this->_lineSymbolization);
         this->lineRule= NULL;
@@ -81,5 +102,38 @@
     //Property: Stroke
     if (lineSymbolization->GetStroke())
-        IOStroke::Write(fd, lineSymbolization->GetStroke(),
"LineSymbolization2D"); // NOXLATE
+        fd << tab() << startStr(sLineSymbolization2D) << std::endl;
+        inctab();
+        //Property: LineStyle
+        fd << tab() << startStr(sLineStyle);
+        fd <<
EncodeString(lineSymbolization->GetStroke()->GetLineStyle());
+        fd << endStr(sLineStyle) << std::endl;
+        //Property: Thickness
+        fd << tab() << startStr(sThickness);
+        fd <<
EncodeString(lineSymbolization->GetStroke()->GetThickness());
+        fd << endStr(sThickness) << std::endl;
+        //Property: ForegroundColor
+        fd << tab() << startStr(sColor);
+        fd << EncodeString(lineSymbolization->GetStroke()->GetColor());
+        fd << endStr(sColor) << std::endl;
+        //Property: Unit
+        fd << tab() << startStr(sUnit);
+        std::auto_ptr<MdfString>
str(LengthConverter::UnitToEnglish(lineSymbolization->GetStroke()->GetUn
it()));
+        fd << EncodeString(*str);
+        fd << endStr(sUnit) << std::endl;
+        if (!lineSymbolization->GetUnknownXml().empty())
+            fd << toCString(lineSymbolization->GetUnknownXml());
+        dectab();
+        fd << tab() << endStr(sLineSymbolization2D) << std::endl;
Index: E:/MgDev/OS/Common/MdfParser/FSDSAX2Parser.h
--- E:/MgDev/OS/Common/MdfParser/FSDSAX2Parser.h	(revision 1037)
+++ E:/MgDev/OS/Common/MdfParser/FSDSAX2Parser.h	(revision 1038)
@@ -69,19 +69,14 @@
the
characters()-
separate calls.
openTag and
characters in the
case when you have
to make sure
instead.
tagOpen is
-        MdfString m_strParserError;
         bool m_tagOpen;
+        MdfString m_strParserError;
         void WriteDefinition(FeatureSource *pFeatureSource, MdfStream
&fd);
         // error handling override
Index: E:/MgDev/OS/Common/MdfParser/IOUnknown.h
--- E:/MgDev/OS/Common/MdfParser/IOUnknown.h	(revision 0)
+++ E:/MgDev/OS/Common/MdfParser/IOUnknown.h	(revision 1038)
@@ -0,0 +1,43 @@
Foundation.
02110-1301  USA
+#ifndef _IOUNKNOWN_H
+#define _IOUNKNOWN_H
+BEGIN_NAMESPACE_MDFPARSER
+class IOUnknown : public SAX2ElementHandler
+    private:
+        std::wstring*     _xml;
+    public:
+        IOUnknown(std::wstring* xml);
+        ~IOUnknown();
+        virtual void StartElement(const wchar_t *name, HandlerStack
*handlerStack);
+        virtual void ElementChars(const wchar_t *ch);
+        virtual void EndElement(const wchar_t *name, HandlerStack
*handlerStack);
+END_NAMESPACE_MDFPARSER
+#endif // _IOUNKNOWN_H
Property changes on: E:\MgDev\OS\Common\MdfParser\IOUnknown.h
   + native
Index: E:/MgDev/OS/Common/MdfParser/IOStroke.cpp
--- E:/MgDev/OS/Common/MdfParser/IOStroke.cpp	(revision 1037)
+++ E:/MgDev/OS/Common/MdfParser/IOStroke.cpp	(revision 1038)
@@ -24,6 +24,13 @@
+ELEM_MAP_ENTRY(1, Stroke);
 IOStroke::IOStroke(std::wstring elementName)
     this->_stroke = NULL;
@@ -42,9 +49,25 @@
 void IOStroke::StartElement(const wchar_t *name, HandlerStack
*handlerStack)
+    // Note: this->m_elementName is not part of the Element Map, so the
+    // eStroke value is substituted - but sStroke will not be the
correct
+    // string, and cannot not be used in place of m_elementName.
     if (m_currElemName == this->m_elementName)
+        m_currElemId = eStroke;
+    else
+    if (eUnknown == m_currElemId)
 void IOStroke::ElementChars(const wchar_t *ch)
@@ -66,6 +89,9 @@
+            this->_stroke->SetUnknownXml(UnknownXml());
@@ -99,6 +125,12 @@
     fd << "</Unit>" << std::endl; // NOXLATE
+    if (!stroke->GetUnknownXml().empty())
+        fd << toCString(stroke->GetUnknownXml());
     dectab();
     fd << tab() << "</" << name << ">" << std::endl; // NOXLATE
Index: E:/MgDev/OS/Common/MdfParser/IOImageSymbol.cpp
--- E:/MgDev/OS/Common/MdfParser/IOImageSymbol.cpp	(revision 1037)
+++ E:/MgDev/OS/Common/MdfParser/IOImageSymbol.cpp	(revision 1038)
@@ -25,6 +25,20 @@
 // When a ImageSymbol is successfully parsed by this class, it must be
accessed by the
by this class.
+// Local Elements
+ELEM_MAP_ENTRY(9, Image);
+ELEM_MAP_ENTRY(10, Content);
 IOImageSymbol::IOImageSymbol() : IOSymbol()
@@ -33,6 +47,8 @@
 void IOImageSymbol::StartElement(const wchar_t *name, HandlerStack
*handlerStack)
     // it's a pain to have the "Image" element contain an "Image"
element
     if (this->m_currElemName == L"Image" && this->m_startElemName !=
@@ -45,6 +61,10 @@
+    else if (eUnknown == m_currElemId)
 void IOImageSymbol::ElementChars(const wchar_t *ch)
@@ -60,6 +80,9 @@
         ImageSymbol* symbol =
static_cast<ImageSymbol*>(this->m_symbol);
@@ -95,6 +118,12 @@
         fd << "</Content>" << std::endl; // NOXLATE
     dectab();
     fd << tab() << "</Image>" << std::endl; // NOXLATE
Index: E:/MgDev/OS/Common/MdfParser/IOVectorLayerDefinition.cpp
--- E:/MgDev/OS/Common/MdfParser/IOVectorLayerDefinition.cpp
(revision 1037)
+++ E:/MgDev/OS/Common/MdfParser/IOVectorLayerDefinition.cpp
(revision 1038)
@@ -24,11 +24,26 @@
+ELEM_MAP_ENTRY(1, VectorLayerDefinition);
+ELEM_MAP_ENTRY(2, PropertyMapping);
+ELEM_MAP_ENTRY(3, VectorScaleRange);
+ELEM_MAP_ENTRY(4, Opacity);
+ELEM_MAP_ENTRY(5, ResourceId);
+ELEM_MAP_ENTRY(6, FeatureName);
+ELEM_MAP_ENTRY(7, FeatureNameType);
+ELEM_MAP_ENTRY(8, Geometry);
+ELEM_MAP_ENTRY(9, Url);
+ELEM_MAP_ENTRY(10, ToolTip);
+ELEM_MAP_ENTRY(11, Filter);
 IOVectorLayerDefinition::IOVectorLayerDefinition()
 IOVectorLayerDefinition::IOVectorLayerDefinition(VectorLayerDefinition
*layer)
     this->_layer = layer;
@@ -41,53 +56,88 @@
 void IOVectorLayerDefinition::StartElement(const wchar_t *name,
-    if (m_currElemName == L"VectorLayerDefinition") // NOXLATE
+        case eVectorLayerDefinition:
+            break;
IONameStringPair(this->_layer);
+            break;
+                IOVectorScaleRange *IO = new
IOVectorScaleRange(this->_layer);
+            break;
+        case eUnknown:
+            break;
+        default:
+            break;
-    else if (m_currElemName == L"PropertyMapping") // NOXLATE
-        IONameStringPair *IO = new IONameStringPair(this->_layer);
-    else if (m_currElemName == L"VectorScaleRange") // NOXLATE
-        IOVectorScaleRange *IO = new IOVectorScaleRange(this->_layer);
 void IOVectorLayerDefinition::ElementChars(const wchar_t *ch)
-    if (m_currElemName == L"Opacity") // NOXLATE
-        (this->_layer)->SetOpacity(wstrToDouble(ch));
-    else if (m_currElemName == L"ResourceId") // NOXLATE
-        (this->_layer)->SetResourceID(ch);
-    else if (m_currElemName == L"FeatureName") // NOXLATE
-        (this->_layer)->SetFeatureName(ch);
-    else if (m_currElemName == L"FeatureNameType") // NOXLATE
-        if (::wcscmp(ch, L"FeatureClass") == 0) // NOXLATE
_layer->SetFeatureNameType(VectorLayerDefinition::FeatureClass);
-        else if (::wcscmp(ch, L"NamedExtension") == 0) // NOXLATE
_layer->SetFeatureNameType(VectorLayerDefinition::NamedExtension);
+        case eOpacity:
+            (this->_layer)->SetOpacity(wstrToDouble(ch));
+            break;
+        case eResourceId:
+            (this->_layer)->SetResourceID(ch);
+            break;
+        case eFeatureName:
+            (this->_layer)->SetFeatureName(ch);
+            break;
+        case eFeatureNameType:
+            if (::wcscmp(ch, L"FeatureClass") == 0) // NOXLATE
+            else if (::wcscmp(ch, L"NamedExtension") == 0) // NOXLATE
+            break;
+        case eGeometry:
+            (this->_layer)->SetGeometry(ch);
+            break;
+        case eUrl:
+            (this->_layer)->SetUrl(ch);
+            break;
+        case eToolTip:
+            (this->_layer)->SetToolTip(ch);
+            break;
+        case eFilter:
+            (this->_layer)->SetFilter(ch);
+            break;
+        default:
+            break;
-    else if (m_currElemName == L"Geometry") // NOXLATE
-        (this->_layer)->SetGeometry(ch); // NOXLATE
-    else if (m_currElemName == L"Url") // NOXLATE
-        (this->_layer)->SetUrl(ch);
-    else if (m_currElemName == L"ToolTip") // NOXLATE
-        (this->_layer)->SetToolTip(ch);
-    else if (m_currElemName == L"Filter")  // NOXLATE
-        (this->_layer)->SetFilter(ch);
 void IOVectorLayerDefinition::EndElement(const wchar_t *name,
@@ -100,74 +150,74 @@
     fd << tab() << "<LayerDefinition
xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\"
xmlns:xsd=\"http://www.w3.org/2001/XMLSchema\"
xsi:noNamespaceSchemaLocation=\"LayerDefinition-1.0.0.xsd\"
version=\"1.0.0\">" << std::endl; // NOXLATE
     inctab();
-    fd << tab() << "<VectorLayerDefinition>" << std::endl; // NOXLATE
+    fd << tab() << startStr(sVectorLayerDefinition) << std::endl;
     inctab();
     //Property: ResourceId
-    fd << tab() << "<ResourceId>";  // NOXLATE
+    fd << tab() << startStr(sResourceId);
     fd << EncodeString(featureLayer->GetResourceID());
-    fd << "</ResourceId>" << std::endl; // NOXLATE
+    fd << endStr(sResourceId) << std::endl;
     //Property: Opacity (optional)
     if (featureLayer->GetOpacity() != 1.0)
-        fd << tab() << "<Opacity>"; // NOXLATE
+        fd << tab() << startStr(sOpacity);
         fd << DoubleToStr(featureLayer->GetOpacity());
-        fd << "</Opacity>" << std::endl; // NOXLATE
+        fd << endStr(sOpacity) << std::endl;
     //Property: FeatureName
-    fd << tab() << "<FeatureName>";  // NOXLATE
+    fd << tab() << startStr(sFeatureName);
     fd << EncodeString(featureLayer->GetFeatureName());
-    fd << "</FeatureName>" << std::endl; // NOXLATE
+    fd << endStr(sFeatureName) << std::endl;
     //Property: FeatureNameType
-    fd << tab() << "<FeatureNameType>";  // NOXLATE
+    fd << tab() << startStr(sFeatureNameType);
     if (featureLayer->GetFeatureNameType() ==
         fd << "FeatureClass"; // NOXLATE
     else
         fd << "NamedExtension"; // NOXLATE
-    fd << "</FeatureNameType>" << std::endl; // NOXLATE
+    fd << endStr(sFeatureNameType) << std::endl;
     //Property: Filter
     if (featureLayer->GetFilter().length() > 0)
-        fd << tab() << "<Filter>"; // NOXLATE
+        fd << tab() << startStr(sFilter);
         fd << EncodeString(featureLayer->GetFilter());
-        fd << "</Filter>" << std::endl; // NOXLATE
+        fd << endStr(sFilter) << std::endl;
     //Property: PropertyMappings
     for (int x = 0; x <
featureLayer->GetPropertyMappings()->GetCount(); x++)
-        fd << tab() << "<PropertyMapping>" << std::endl; // NOXLATE
+        fd << tab() << startStr(sPropertyMapping) << std::endl;
         inctab();
         IONameStringPair * IO = new IONameStringPair();
         IO->Write(fd, featureLayer->GetPropertyMappings()->GetAt(x));
         delete IO;
         dectab();
-        fd << tab() << "</PropertyMapping>" << std::endl; // NOXLATE
+        fd << tab() << endStr(sPropertyMapping) << std::endl;
     //Property: Geometry
-    fd << tab() << "<Geometry>";  // NOXLATE
+    fd << tab() << startStr(sGeometry);
     fd << EncodeString(featureLayer->GetGeometry());
-    fd << "</Geometry>" << std::endl; // NOXLATE
+    fd << endStr(sGeometry) << std::endl;
     //Property: Url
     if (featureLayer->GetUrl().length() > 0)
-        fd << tab() << "<Url>";  // NOXLATE
+        fd << tab() << startStr(sUrl);
         fd << EncodeString(featureLayer->GetUrl());
-        fd << "</Url>" << std::endl; // NOXLATE
+        fd << endStr(sUrl) << std::endl;
     //Property: ToolTip
     if (featureLayer->GetToolTip().length() > 0)
-        fd << tab() << "<ToolTip>";  // NOXLATE
+        fd << tab() << startStr(sToolTip);
         fd << EncodeString(featureLayer->GetToolTip());
-        fd << "</ToolTip>" << std::endl; // NOXLATE
+        fd << endStr(sToolTip) << std::endl;
     //Property: VectorScaleRange
@@ -178,8 +228,14 @@
         delete IO;
+    if (!featureLayer->GetUnknownXml().empty())
+        fd << toCString(featureLayer->GetUnknownXml());
     dectab();
-    fd << tab() << "</VectorLayerDefinition>" << std::endl; // NOXLATE
+    fd << tab() << endStr(sVectorLayerDefinition) << std::endl; //
NOXLATE
     dectab();
     fd << tab() << "</LayerDefinition>" << std::endl; // NOXLATE
Index: E:/MgDev/OS/Common/MdfParser/IOSupplementalSpatialContextInfo.cpp
--- E:/MgDev/OS/Common/MdfParser/IOSupplementalSpatialContextInfo.cpp
(revision 1037)
+++ E:/MgDev/OS/Common/MdfParser/IOSupplementalSpatialContextInfo.cpp
(revision 1038)
@@ -22,6 +22,10 @@
+ELEM_MAP_ENTRY(1, SupplementalSpatialContextInfo);
+ELEM_MAP_ENTRY(3, CoordinateSystem);
 IOSupplementalSpatialContextInfo::IOSupplementalSpatialContextInfo()
     : _ssContextInfo(NULL), featureSource(NULL)
@@ -40,13 +44,24 @@
 void IOSupplementalSpatialContextInfo::StartElement(const wchar_t
*name, HandlerStack *handlerStack)
-    if (NULL != featureSource)
-        if (m_currElemName == L"SupplementalSpatialContextInfo") //
NOXLATE
             this->_ssContextInfo = new
SupplementalSpatialContextInfo(L"", L"");
+        break;
+    case eUnknown:
+        break;
+    default:
+        break;
@@ -62,6 +77,9 @@
+            this->_ssContextInfo->SetUnknownXml(UnknownXml());
this->featureSource->GetSupplementalSpatialContextInfo()->Adopt(this->_s
sContextInfo);
@@ -83,4 +101,10 @@
     fd << tab() << "<CoordinateSystem>"; // NOXLATE
     fd << EncodeString(ssContextInfo->GetCoordinateSystem());
     fd << "</CoordinateSystem>" << std::endl; // NOXLATE
+    if (!ssContextInfo->GetUnknownXml().empty())
+        fd << toCString(ssContextInfo->GetUnknownXml());
Index: E:/MgDev/OS/Common/MdfParser/IOGridScaleRange.cpp
--- E:/MgDev/OS/Common/MdfParser/IOGridScaleRange.cpp	(revision 1037)
+++ E:/MgDev/OS/Common/MdfParser/IOGridScaleRange.cpp	(revision 1038)
@@ -27,6 +27,14 @@
+ELEM_MAP_ENTRY(1, GridScaleRange);
+ELEM_MAP_ENTRY(2, SurfaceStyle);
+ELEM_MAP_ENTRY(3, ColorStyle);
+ELEM_MAP_ENTRY(4, MinScale);
+ELEM_MAP_ENTRY(5, MaxScale);
+ELEM_MAP_ENTRY(6, RebuildFactor);
 IOGridScaleRange::IOGridScaleRange():_scaleRange(NULL), layer(NULL)
@@ -42,25 +50,37 @@
 void IOGridScaleRange::StartElement(const wchar_t *name, HandlerStack
*handlerStack)
-    if (m_currElemName == L"GridScaleRange") // NOXLATE
         this->_scaleRange = new GridScaleRange();
-    else
-        if (m_currElemName == L"SurfaceStyle") // NOXLATE
+        break;
+    case eSurfaceStyle:
             IOGridSurfaceStyle *IO = new
IOGridSurfaceStyle(this->_scaleRange);
-        else if (m_currElemName == L"ColorStyle") // NOXLATE
+        break;
+    case eColorStyle:
             IOGridColorStyle *IO = new
IOGridColorStyle(this->_scaleRange);
+        break;
+    case eUnknown:
+        break;
+    default:
+        break;
@@ -78,6 +98,9 @@
         this->layer = NULL;
@@ -131,6 +154,12 @@
     fd << DoubleToStr(scaleRange->GetRebuildFactor());
     fd << "</RebuildFactor>" << std::endl; // NOXLATE
     dectab();
     fd << tab() << "</GridScaleRange>" << std::endl; // NOXLATE
Index: E:/MgDev/OS/Common/MdfParser/IOGridSurfaceStyle.cpp
--- E:/MgDev/OS/Common/MdfParser/IOGridSurfaceStyle.cpp	(revision 1037)
+++ E:/MgDev/OS/Common/MdfParser/IOGridSurfaceStyle.cpp	(revision 1038)
@@ -23,6 +23,13 @@
+ELEM_MAP_ENTRY(1, SurfaceStyle);
+ELEM_MAP_ENTRY(3, ZeroValue);
+ELEM_MAP_ENTRY(4, ScaleFactor);
+ELEM_MAP_ENTRY(5, DefaultColor);
 IOGridSurfaceStyle::IOGridSurfaceStyle():surfaceStyle(NULL),
scaleRange(NULL)
@@ -38,10 +45,21 @@
 void IOGridSurfaceStyle::StartElement(const wchar_t *name, HandlerStack
*handlerStack)
         this->surfaceStyle = new GridSurfaceStyle();
+        break;
+    case eUnknown:
+        break;
+    default:
+        break;
@@ -61,7 +79,10 @@
-        //this->scaleRange->GetGridStyles()->Adopt(this->surfaceStyle);
+            this->surfaceStyle->SetUnknownXml(UnknownXml());
+       //this->scaleRange->GetGridStyles()->Adopt(this->surfaceStyle);
         this->scaleRange->AdoptSurfaceStyle(this->surfaceStyle);
@@ -102,6 +123,12 @@
     fd << EncodeString(pSurfaceStyle->GetDefaultColor());
     fd << "</DefaultColor>" << std::endl; // NOXLATE
+    if (!pSurfaceStyle->GetUnknownXml().empty())
+        fd << toCString(pSurfaceStyle->GetUnknownXml());
     dectab();
     fd << tab() << "</SurfaceStyle>" << std::endl; // NOXLATE
Index: E:/MgDev/OS/Common/MdfParser/IOMarkSymbol.cpp
--- E:/MgDev/OS/Common/MdfParser/IOMarkSymbol.cpp	(revision 1037)
+++ E:/MgDev/OS/Common/MdfParser/IOMarkSymbol.cpp	(revision 1038)
@@ -27,6 +27,23 @@
 // When a MarkSymbol is successfully parsed by this class, it must be
accessed by the
by this class.
+// Local Elements
+ELEM_MAP_ENTRY(9, Mark);
+ELEM_MAP_ENTRY(10, Fill);
+ELEM_MAP_ENTRY(11, Edge);
+ELEM_MAP_ENTRY(12, Shape);
 IOMarkSymbol::IOMarkSymbol() : IOSymbol()
     this->m_ioStroke = NULL;
@@ -36,30 +53,47 @@
 void IOMarkSymbol::StartElement(const wchar_t *name, HandlerStack
*handlerStack)
-    if (this->m_currElemName == L"Mark") // NOXLATE
-        this->m_startElemName = name;
-        MarkSymbol* markSymbol = new MarkSymbol(MarkSymbol::Square);
-        delete markSymbol->OrphanFill();
-        delete markSymbol->OrphanEdge();
-        this->m_symbol = markSymbol;
+    case eMark:
+            this->m_startElemName = name;
+            MarkSymbol* markSymbol = new
+            delete markSymbol->OrphanFill();
+            delete markSymbol->OrphanEdge();
+            this->m_symbol = markSymbol;
+        break;
+    case eFill:
+            MarkSymbol* symbol =
static_cast<MarkSymbol*>(this->m_symbol);
+            symbol->AdoptFill(new Fill());
+            this->m_ioFill = new IOFill(symbol->GetFill());
+            handlerStack->push(this->m_ioFill);
+            this->m_ioFill->StartElement(name, handlerStack);
+        break;
+    case eEdge:
+            symbol->AdoptEdge(new Stroke());
+            this->m_ioStroke = new IOStroke(symbol->GetEdge(),
this->m_currElemName);
+            handlerStack->push(this->m_ioStroke);
+            this->m_ioStroke->StartElement(name, handlerStack);
+        break;
+    case eUnknown:
+        break;
+    default:
+        break;
-    else if (this->m_currElemName == L"Fill") // NOXLATE
-        MarkSymbol* symbol = static_cast<MarkSymbol*>(this->m_symbol);
-        symbol->AdoptFill(new Fill());
-        this->m_ioFill = new IOFill(symbol->GetFill());
-        handlerStack->push(this->m_ioFill);
-        this->m_ioFill->StartElement(name, handlerStack);
-    else if (this->m_currElemName == L"Edge") // NOXLATE
-        symbol->AdoptEdge(new Stroke());
-        this->m_ioStroke = new IOStroke(symbol->GetEdge(),
-        handlerStack->push(this->m_ioStroke);
-        this->m_ioStroke->StartElement(name, handlerStack);
 void IOMarkSymbol::ElementChars(const wchar_t *ch)
@@ -88,6 +122,9 @@
+        if (!UnknownXml().empty())
@@ -124,6 +161,12 @@
     if (symbol->GetEdge() != NULL)
         IOStroke::Write(fd, symbol->GetEdge(), "Edge"); // NOXLATE
+    // Write any previously found unknown XML
     dectab();
     fd << tab() << "</Mark>" << std::endl; // NOXLATE
Index: E:/MgDev/OS/Common/MdfParser/IOPointRule.cpp
--- E:/MgDev/OS/Common/MdfParser/IOPointRule.cpp	(revision 1037)
+++ E:/MgDev/OS/Common/MdfParser/IOPointRule.cpp	(revision 1038)
@@ -24,6 +24,13 @@
+CREATE_ELEMENT_MAP;
+ELEM_MAP_ENTRY(1, PointRule);
+ELEM_MAP_ENTRY(2, PointSymbolization2D);
 IOPointRule::IOPointRule()
     this->_pointRule = NULL;
@@ -43,23 +50,38 @@
 void IOPointRule::StartElement(const wchar_t *name, HandlerStack
*handlerStack)
-    if (m_currElemName == L"PointRule") // NOXLATE
+    m_currElemId = _ElementIdFromName(name);
+    case ePointRule:
         this->_pointRule = new PointRule();
+        break;
+    case ePointSymbolization2D:
+            IOPointSymbolization2D *IO = new
IOPointSymbolization2D(this->_pointRule);
+        break;
+    case eLabel:
+            IOLabel *IO = new IOLabel(this->_pointRule);
+        break;
+    case eUnknown:
+        ParseUnknownXml(name, handlerStack);
+        break;
+    default:
+        break;
-    else if (m_currElemName == L"PointSymbolization2D") // NOXLATE
-        IOPointSymbolization2D *IO = new
-        IOLabel *IO = new IOLabel(this->_pointRule);
 void IOPointRule::ElementChars(const wchar_t *ch)
@@ -74,6 +96,9 @@
+            this->_pointRule->SetUnknownXml(UnknownXml());
         this->pointTypeStyle->GetRules()->Adopt(this->_pointRule);
         this->pointTypeStyle= NULL;
@@ -117,6 +142,12 @@
         delete IO;
+    if (!pointRule->GetUnknownXml().empty())
+        fd << toCString(pointRule->GetUnknownXml());
     dectab();
     fd << tab() << "</PointRule>" << std::endl; // NOXLATE
Index: E:/MgDev/OS/Common/MdfParser/FSDSAX2Parser.cpp
--- E:/MgDev/OS/Common/MdfParser/FSDSAX2Parser.cpp	(revision 1037)
+++ E:/MgDev/OS/Common/MdfParser/FSDSAX2Parser.cpp	(revision 1038)
@@ -28,6 +28,8 @@
     FSDSAX2Parser::FSDSAX2Parser()
+        m_tagOpen = false;
         Flush();
         Initialize();
@@ -61,7 +63,6 @@
         m_Parser->setFeature(XMLUni::fgSAX2CoreValidation, false);
         m_Parser->setContentHandler(this);
         m_Parser->setErrorHandler(this);
-        m_prevOpenTag = L"";
         m_strbuffer = L"";
@@ -171,7 +172,9 @@
                                      const   Attributes&
attributes)
         std::wstring str = X2W(localname);
-        m_openTag = str;
+        m_strbuffer = L"";   // discard any text between start tags
+        m_tagOpen = true;
         // If the stack is empty, then check to see if we've
encountered the
         // start of one of the below definitions. Allocate space for
the object
         // we will be creating, create the appropriate IO object,
passing in the reference
@@ -193,29 +196,15 @@
             (m_HandlerStack->top())->StartElement(str.c_str(),
m_HandlerStack);
-        m_tagOpen = true;
-        m_charsInTag = false;
     void FSDSAX2Parser::characters(const     XMLCh* const    chars
                                     , const   unsigned int    length)
-        if (m_openTag.compare(m_prevOpenTag) != 0)
-            if (!m_HandlerStack->empty())
-                if (m_charsInTag)
(m_HandlerStack->top())->ElementChars(m_strbuffer.c_str());
-                m_strbuffer = L"";
-        m_strbuffer += X2W(chars);
-        m_prevOpenTag = m_openTag;
+        // The character data may be split into multiple calls, so just
store it for now.
+        // Also, do not record text outside of start/end tags
         if (m_tagOpen)
-            m_charsInTag = true;
+            m_strbuffer += X2W(chars);
     void FSDSAX2Parser::endElement(const XMLCh* const uri,
@@ -223,9 +212,15 @@
                                     const XMLCh* const qname)
         m_tagOpen = false;
+            // Now is the time to make the ElementChars() call.
+            if (!m_strbuffer.empty())
             (m_HandlerStack->top())->EndElement(X2W(localname),
m_HandlerStack);
Index: E:/MgDev/OS/Common/MdfParser/IOUnknown.cpp
--- E:/MgDev/OS/Common/MdfParser/IOUnknown.cpp	(revision 0)
+++ E:/MgDev/OS/Common/MdfParser/IOUnknown.cpp	(revision 1038)
@@ -0,0 +1,71 @@
Foundation.
02110-1301  USA
+IOUnknown::IOUnknown(std::wstring* xml)
+    _xml = xml;
+    m_startElemName.clear();
+IOUnknown::~IOUnknown()
+void IOUnknown::StartElement(const wchar_t *name, HandlerStack
*handlerStack)
+    if (m_startElemName.empty())
+        _xml->append(L"<");  // NOXLATE
+        _xml->append(name);
+        _xml->append(L">");  // NOXLATE
+    else
+        IOUnknown *IO = new IOUnknown(_xml);
+        handlerStack->push(IO);
+        IO->StartElement(name, handlerStack);
+void IOUnknown::ElementChars(const wchar_t *ch)
+    _xml->append(ch);
+void IOUnknown::EndElement(const wchar_t *name, HandlerStack
*handlerStack)
+    _xml->append(L"</");  // NOXLATE
+        delete this;
Property changes on: E:\MgDev\OS\Common\MdfParser\IOUnknown.cpp
   + native
Index: E:/MgDev/OS/Common/MdfParser/Makefile.am
--- E:/MgDev/OS/Common/MdfParser/Makefile.am	(revision 1037)
+++ E:/MgDev/OS/Common/MdfParser/Makefile.am	(revision 1038)
@@ -27,6 +27,7 @@
   IOFill.cpp \
   IOFontSymbol.cpp \
   IOGridColor.cpp \
+  IOGridColorBands.cpp \
   IOGridColorRule.cpp \
   IOGridColorStyle.cpp \
   IOGridLayerDefinition.cpp \
@@ -53,11 +54,13 @@
   IOStroke.cpp \
   IOSupplementalSpatialContextInfo.cpp \
   IOSymbol.cpp \
+  IOUnknown.cpp \
   IOUtil.cpp \
   IOVectorLayerDefinition.cpp \
   IOVectorScaleRange.cpp \
   IOW2DSymbol.cpp \
   MdfParser.cpp \
+  SAX2ElementHandler.cpp \
   SAX2Parser.cpp
 noinst_HEADERS = \
@@ -105,6 +108,7 @@
   IOStroke.h \
   IOSupplementalSpatialContextInfo.h \
   IOSymbol.h \
+  IOUnknown.h \
   IOUtil.h \
   IOVectorLayerDefinition.h \
   IOVectorScaleRange.h \
Index: E:/MgDev/OS/Common/MdfParser/IOAttributeRelate.cpp
--- E:/MgDev/OS/Common/MdfParser/IOAttributeRelate.cpp	(revision 1037)
+++ E:/MgDev/OS/Common/MdfParser/IOAttributeRelate.cpp	(revision 1038)
@@ -24,6 +24,16 @@
+ELEM_MAP_ENTRY(1, AttributeRelate);
+ELEM_MAP_ENTRY(2, RelateProperty);
+ELEM_MAP_ENTRY(3, AttributeClass);
+ELEM_MAP_ENTRY(4, ResourceId);
+ELEM_MAP_ENTRY(5, Name);
+ELEM_MAP_ENTRY(6, AttributeNameDelimiter);
+ELEM_MAP_ENTRY(7, RelateType);
+ELEM_MAP_ENTRY(8, ForceOneToOne);
 IOAttributeRelate::IOAttributeRelate()
     : m_pAttributeRelate(NULL), m_pExtension(NULL)
@@ -41,19 +51,29 @@
 void IOAttributeRelate::StartElement(const wchar_t *name, HandlerStack
*handlerStack)
-    if (m_currElemName == L"AttributeRelate") // NOXLATE
         m_pAttributeRelate = new AttributeRelate();
-    else
+        break;
             IORelateProperty *IO = new
IORelateProperty(this->m_pAttributeRelate);
+        break;
+    case eUnknown:
+        break;
+    default:
+        break;
@@ -77,6 +97,9 @@
+            this->m_pAttributeRelate->SetUnknownXml(UnknownXml());
         m_pExtension->GetAttributeRelates()->Adopt(m_pAttributeRelate);
         this->m_pAttributeRelate = NULL;
@@ -127,6 +150,12 @@
         spIO->Write(fd,
pAttributeRelate->GetRelateProperties()->GetAt(x));
+    if (!pAttributeRelate->GetUnknownXml().empty())
+        fd << toCString(pAttributeRelate->GetUnknownXml());
     dectab();
     fd << tab() << "</AttributeRelate>" << std::endl; // NOXLATE
Index: E:/MgDev/OS/Common/MdfParser/SAX2ElementHandler.h
--- E:/MgDev/OS/Common/MdfParser/SAX2ElementHandler.h	(revision 1037)
+++ E:/MgDev/OS/Common/MdfParser/SAX2ElementHandler.h	(revision 1038)
@@ -20,7 +20,9 @@
 #include <string>
 #include <stack>
+#include <vector>
 #include "MdfParser.h"
+#include "UnicodeString.h"
@@ -44,20 +46,57 @@
 class MDFPARSER_API SAX2ElementHandler {
     public:
-        virtual ~SAX2ElementHandler() {};
+        virtual ~SAX2ElementHandler() {}
*handlerStack) = 0;
         virtual void ElementChars(const wchar_t *ch) = 0;
*handlerStack) = 0;
     protected:
+        void ParseUnknownXml(const wchar_t *name, HandlerStack
*handlerStack);
+        std::wstring& UnknownXml() { return m_unknownXml; }
+        std::wstring m_unknownXml;
         // m_startElemName stores the name of the XML tag that
initiated
         // the creation of this SAX2ElementHandler object.
         std::wstring m_startElemName;
         // m_currElemName stores the name of the last XML start tag.
         std::wstring m_currElemName;
+        int m_currElemId;
+// For each element type, the following macros define a method,
_ElementIdFromName()
+// and two variables, eElementName - an integer ID which can be used in
case
+// statements, and sElementName - a std::string which can be used in
serialization.
+// CREATE_ELEMENT_MAP is called first, and then ELEM_MAP_ENTRY for each
element
+// type.  The IDs provided to ELEM_MAP_ENTRY must be consecutive,
starting from 1.
+#define CREATE_ELEMENT_MAP
+    static std::vector<std::wstring> _elementMap;
+    static std::string _CreateMapEntry(const wchar_t* wName, const
char* sName) \
+        _elementMap.push_back(wName);
+        return sName;
+    static int _ElementIdFromName(const wchar_t* name)
+        std::vector<std::wstring>::const_iterator iter =
_elementMap.begin();   \
+        int id = 1;
+        for (iter++; iter != _elementMap.end(); iter++)
+            if (0 == ::wcscmp(iter->c_str(), name))
+                return id;
+            id++;
+        return 0;
+    ELEM_MAP_ENTRY(0, Unknown)
+#define ELEM_MAP_ENTRY(ID, NAME)
+    static const std::string s##NAME = _CreateMapEntry(L###NAME,
#NAME);        \
+    static const int e##NAME = ID
 #endif // _SAX2ELEMENTHANDLER_H
Index: E:/MgDev/OS/Common/MdfParser/SAX2Parser.cpp
--- E:/MgDev/OS/Common/MdfParser/SAX2Parser.cpp	(revision 1037)
+++ E:/MgDev/OS/Common/MdfParser/SAX2Parser.cpp	(revision 1038)
@@ -50,7 +50,6 @@
     m_Parser       = NULL;
     m_HandlerStack = NULL;
     m_tagOpen      = false;
     Flush();
     Initialize();
@@ -95,7 +94,6 @@
     m_Parser->setFeature(XMLUni::fgXercesSchemaFullChecking, false);
     m_Parser->setFeature(XMLUni::fgSAX2CoreValidation, false); // true
for validation
     m_strbuffer = L"";
@@ -341,7 +339,9 @@
                               const   Attributes&     attributes)
-    m_openTag = str;
+    m_tagOpen = true;
     // If the stack is empty, then check to see if we've encountered
the
     // start of one of the below definitions. Allocate space for the
object
     // we will be creating, create the appropriate IO object, passing
in the reference
@@ -386,30 +386,16 @@
m_HandlerStack);
-    m_tagOpen = true;
 void SAX2Parser::characters(const XMLCh* const    chars,
-            if (m_charsInTag)
store it for now.
     if (m_tagOpen)
@@ -418,9 +404,15 @@
     m_tagOpen = false;
+            (m_HandlerStack->top())->ElementChars(m_strbuffer.c_str());
m_HandlerStack);
Index: E:/MgDev/OS/Common/MdfModel/MdfRootObject.h
--- E:/MgDev/OS/Common/MdfModel/MdfRootObject.h	(revision 0)
+++ E:/MgDev/OS/Common/MdfModel/MdfRootObject.h	(revision 1038)
@@ -0,0 +1,54 @@
Foundation.
02110-1301  USA
+#ifndef MDFROOTOBJECT_H_
+#define MDFROOTOBJECT_H_
+#include "MdfModel.h"
+BEGIN_NAMESPACE_MDFMODEL
+    // DESCRIPTION:
+    // Common base class for all MdfModel classes.  Provides support
for
+    // round-tripping unknown XML data from/to future schema versions.
+    class MDFMODEL_API MdfRootObject
+    public:
+        // Destruction
+        virtual ~MdfRootObject() {}
+        // Operations
+        // Property : UnknownXml
+        const MdfString& GetUnknownXml() const;
+        void SetUnknownXml(const MdfString& pstrUnknownXml);
+    protected:
+        // Construction, initialization
+        // Default constructor is protected to make this class
abstract.
+        MdfRootObject() {}
+    private:
+        // Data members
+        // Cache for parser, keeping unknown XML for round-tripping.
+        MdfString m_strUnknownXml;
+END_NAMESPACE_MDFMODEL
+#endif //MDFROOTOBJECT_H_
Property changes on: E:\MgDev\OS\Common\MdfModel\MdfRootObject.h
   + native
Index: E:/MgDev/OS/Common/MdfModel/Stroke.h
--- E:/MgDev/OS/Common/MdfModel/Stroke.h	(revision 1037)
+++ E:/MgDev/OS/Common/MdfModel/Stroke.h	(revision 1038)
@@ -21,6 +21,7 @@
 #include "SizeContexts.h"
 #include "LengthConverter.h"
+#include "MdfRootObject.h"
@@ -30,7 +31,7 @@
     // concrete classes are used by LineSymbolization and
AreaSymbolization to
     // define the stylization for lines and polygon outlines.
-    class MDFMODEL_API Stroke
+    class MDFMODEL_API Stroke : public MdfRootObject
     public:
         // Construction, destruction, initialization
Index: E:/MgDev/OS/Common/MdfModel/FeatureSource.h
--- E:/MgDev/OS/Common/MdfModel/FeatureSource.h	(revision 1037)
+++ E:/MgDev/OS/Common/MdfModel/FeatureSource.h	(revision 1038)
@@ -22,6 +22,7 @@
 #include "NameStringPair.h"
 #include "Extension.h"
 #include "SupplementalSpatialContextInfo.h"
@@ -31,7 +32,7 @@
 // needed to connect to a feature source.  It also contains extensions
that
 // contain joins for the feature classes in the feature source.
-    class MDFMODEL_API FeatureSource
+class MDFMODEL_API FeatureSource : public MdfRootObject
     public:
Index: E:/MgDev/OS/Common/MdfModel/GridColor.h
--- E:/MgDev/OS/Common/MdfModel/GridColor.h	(revision 1037)
+++ E:/MgDev/OS/Common/MdfModel/GridColor.h	(revision 1038)
@@ -20,6 +20,7 @@
 #include <vector>
 #include "ChannelBand.h"
@@ -29,7 +30,7 @@
     // The grid color is used to stylize the pixel using the given or
calculated
     // color.
-    class MDFMODEL_API GridColor
+    class MDFMODEL_API GridColor : public MdfRootObject
     public:
         virtual ~GridColor();
Index: E:/MgDev/OS/Common/MdfModel/Fill.h
--- E:/MgDev/OS/Common/MdfModel/Fill.h	(revision 1037)
+++ E:/MgDev/OS/Common/MdfModel/Fill.h	(revision 1038)
@@ -19,6 +19,7 @@
 #define FILL_H_
@@ -27,7 +28,7 @@
     // Class Fill is an abstract base that defines how to color/paint
     // feature geometry.
-    class MDFMODEL_API Fill
+    class MDFMODEL_API Fill : public MdfRootObject
     public:
Index: E:/MgDev/OS/Common/MdfModel/MdfRootObject.cpp
--- E:/MgDev/OS/Common/MdfModel/MdfRootObject.cpp	(revision 0)
+++ E:/MgDev/OS/Common/MdfModel/MdfRootObject.cpp	(revision 1038)
@@ -0,0 +1,52 @@
+//  Copyright (C) 2004-2006  Autodesk, Inc.
+//  This library is free software; you can redistribute it and/or
+//  modify it under the terms of version 2.1 of the GNU Lesser
+//  General Public License as published by the Free Software
Foundation.
+//  This library is distributed in the hope that it will be useful,
+//  but WITHOUT ANY WARRANTY; without even the implied warranty of
+//  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+//  Lesser General Public License for more details.
+//  You should have received a copy of the GNU Lesser General Public
+//  License along with this library; if not, write to the Free Software
+//  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA
02110-1301  USA
+// DESCRIPTION:
+// The MdfRootObject class implementation. MdfRootObject is an abstract
class.
+#include "stdafx.h"
+#include "Base64.h"
+using namespace MDFMODEL_NAMESPACE;
+// PURPOSE: Accessor for the UnknownXml property cached by an XML
Parser.
+//          The Xml stream is then serialized when writing to a future
+//          schema version - to support round-tripping.
+// RETURNS:
+const MdfString& MdfRootObject::GetUnknownXml()const
+    return this->m_strUnknownXml;
+// PURPOSE: Accessor to the UnknownXml property cached in this
MdfRootObject
+//          by an Xml Parser.  It is stored here in case it is needed
+//          during serialization.
+// PARAMETERS:
+//      Input:
+//          pstrUnknownXml - an Xml stream containing unknown elements.
+void MdfRootObject::SetUnknownXml(const MdfString& strUnknownXml)
+    this->m_strUnknownXml = strUnknownXml;
Property changes on: E:\MgDev\OS\Common\MdfModel\MdfRootObject.cpp
___________________________________________________________________
   + native
Index: E:/MgDev/OS/Common/MdfModel/Extension.h
--- E:/MgDev/OS/Common/MdfModel/Extension.h	(revision 1037)
+++ E:/MgDev/OS/Common/MdfModel/Extension.h	(revision 1038)
@@ -21,6 +21,7 @@
 #include "AttributeRelate.h"
 #include "CalculatedProperty.h"
@@ -28,7 +29,7 @@
 // DESCRIPTION:
 // Extension class defines the joins between feature classes
-    class MDFMODEL_API Extension
+class MDFMODEL_API Extension : public MdfRootObject
     public:
Index: E:/MgDev/OS/Common/MdfModel/Label.h
--- E:/MgDev/OS/Common/MdfModel/Label.h	(revision 1037)
+++ E:/MgDev/OS/Common/MdfModel/Label.h	(revision 1038)
@@ -20,6 +20,7 @@
 #include "TextSymbol.h"
@@ -31,7 +32,7 @@
     // text label. Other types of Symbols can be used by themselves, or
in
     // combination, to create more intricate labels.
-    class MDFMODEL_API Label
+    class MDFMODEL_API Label : public MdfRootObject
     public:
         // Orientation Enum is used to control the orientation of a
Label with
Index: E:/MgDev/OS/Common/MdfModel/NameStringPair.h
--- E:/MgDev/OS/Common/MdfModel/NameStringPair.h	(revision 1037)
+++ E:/MgDev/OS/Common/MdfModel/NameStringPair.h	(revision 1038)
@@ -20,6 +20,7 @@
 #include "MdfOwnerCollection.h"
@@ -28,7 +29,7 @@
     //  Class NameStringPair represents a pair of strings.  The first
is the
     //  name and the second is the associated text.
-    class MDFMODEL_API NameStringPair
+class MDFMODEL_API NameStringPair : public MdfRootObject
     public:
         //Constructors,
Index: E:/MgDev/OS/Common/MdfModel/LayerDefinition.h
--- E:/MgDev/OS/Common/MdfModel/LayerDefinition.h	(revision 1037)
+++ E:/MgDev/OS/Common/MdfModel/LayerDefinition.h	(revision 1038)
@@ -19,6 +19,7 @@
 #define LAYERDEFINITION_H_
@@ -31,7 +32,7 @@
     // LayerDefinitions are encapsulated by MapLayer objects that make
up a Map. They
     // are referenced primarily by their Uri.
-    class MDFMODEL_API LayerDefinition
+class MDFMODEL_API LayerDefinition : public MdfRootObject
     public:
Index: E:/MgDev/OS/Common/MdfModel/VectorScaleRange.h
--- E:/MgDev/OS/Common/MdfModel/VectorScaleRange.h	(revision 1037)
+++ E:/MgDev/OS/Common/MdfModel/VectorScaleRange.h	(revision 1038)
@@ -21,6 +21,7 @@
 #include "FeatureTypeStyle.h"
@@ -33,7 +34,7 @@
     // collection. Each will result in the drawing of some of the
layer's geometric
     // primitives and/or their labels.
-    class MDFMODEL_API VectorScaleRange
+class MDFMODEL_API VectorScaleRange : public MdfRootObject
     public:
         // Represents the maximum value for the map scale.
Index: E:/MgDev/OS/Common/MdfModel/Symbolization.h
--- E:/MgDev/OS/Common/MdfModel/Symbolization.h	(revision 1037)
+++ E:/MgDev/OS/Common/MdfModel/Symbolization.h	(revision 1038)
@@ -19,6 +19,7 @@
 #define SYMBOLIZATION_H_
@@ -29,7 +30,7 @@
-    class MDFMODEL_API Symbolization
+    class MDFMODEL_API Symbolization : public MdfRootObject
     public:
Index: E:/MgDev/OS/Common/MdfModel/MdfModel.vcproj
--- E:/MgDev/OS/Common/MdfModel/MdfModel.vcproj	(revision 1037)
+++ E:/MgDev/OS/Common/MdfModel/MdfModel.vcproj	(revision 1038)
@@ -514,6 +514,14 @@
 		</File>
 		<File
+			RelativePath=".\MdfRootObject.cpp"
+		</File>
+		<File
+			RelativePath=".\MdfRootObject.h"
+		</File>
+		<File
 			RelativePath=".\NameStringPair.cpp"
 		</File>
Index: E:/MgDev/OS/Common/MdfModel/SupplementalSpatialContextInfo.h
--- E:/MgDev/OS/Common/MdfModel/SupplementalSpatialContextInfo.h
(revision 1037)
+++ E:/MgDev/OS/Common/MdfModel/SupplementalSpatialContextInfo.h
(revision 1038)
@@ -20,6 +20,7 @@
@@ -29,7 +30,7 @@
     //  for a spatial context when the coordinate system is missing
from the
     //  feature source.
-    class MDFMODEL_API SupplementalSpatialContextInfo
+class MDFMODEL_API SupplementalSpatialContextInfo : public
MdfRootObject
     public:
         //Constructors,
Index: E:/MgDev/OS/Common/MdfModel/GridScaleRange.h
--- E:/MgDev/OS/Common/MdfModel/GridScaleRange.h	(revision 1037)
+++ E:/MgDev/OS/Common/MdfModel/GridScaleRange.h	(revision 1038)
@@ -23,6 +23,7 @@
 #include "GridSurfaceStyle.h"
 #include "GridColorStyle.h"
 #include <vector>
@@ -35,7 +36,7 @@
layer's geometric
-    class MDFMODEL_API GridScaleRange
+    class MDFMODEL_API GridScaleRange : public MdfRootObject
     public:
Index: E:/MgDev/OS/Common/MdfModel/RelateProperty.h
--- E:/MgDev/OS/Common/MdfModel/RelateProperty.h	(revision 1037)
+++ E:/MgDev/OS/Common/MdfModel/RelateProperty.h	(revision 1038)
@@ -20,6 +20,7 @@
 namespace MdfModel
@@ -29,7 +30,7 @@
 // RelateProperty class defines the calculated properties from
attributes
 // from the same feature class
-    class MDFMODEL_API RelateProperty
+    class MDFMODEL_API RelateProperty : public MdfRootObject
     public:
Index: E:/MgDev/OS/Common/MdfModel/ChannelBand.h
--- E:/MgDev/OS/Common/MdfModel/ChannelBand.h	(revision 1037)
+++ E:/MgDev/OS/Common/MdfModel/ChannelBand.h	(revision 1038)
@@ -19,6 +19,7 @@
 #define CHANNELBAND_H_
 #include <vector>
@@ -27,7 +28,7 @@
     // Class ChannelBand is used to map the band's value to a valid
color channel value.
     // It defines how to scale numbers into a color channel.
-    class MDFMODEL_API ChannelBand
+    class MDFMODEL_API ChannelBand : public MdfRootObject
     public:
         ChannelBand();
Index: E:/MgDev/OS/Common/MdfModel/HillShade.h
--- E:/MgDev/OS/Common/MdfModel/HillShade.h	(revision 1037)
+++ E:/MgDev/OS/Common/MdfModel/HillShade.h	(revision 1038)
@@ -19,6 +19,7 @@
 #define HILLSHADE_H_
 #include <vector>
@@ -27,7 +28,7 @@
     // Class HillShade is used to specify how to shade given a band and
a light
     // source.
-    class MDFMODEL_API HillShade
+    class MDFMODEL_API HillShade : public MdfRootObject
     public:
         HillShade();
Index: E:/MgDev/OS/Common/MdfModel/AttributeRelate.h
--- E:/MgDev/OS/Common/MdfModel/AttributeRelate.h	(revision 1037)
+++ E:/MgDev/OS/Common/MdfModel/AttributeRelate.h	(revision 1038)
@@ -20,6 +20,7 @@
 #include "RelateProperty.h"
@@ -28,7 +29,7 @@
 // AttributeRelate class defines the attribute class in the target
feature
 // source
-    class MDFMODEL_API AttributeRelate
+class MDFMODEL_API AttributeRelate : public MdfRootObject
     public:
Index: E:/MgDev/OS/Common/MdfModel/Symbol.h
--- E:/MgDev/OS/Common/MdfModel/Symbol.h	(revision 1037)
+++ E:/MgDev/OS/Common/MdfModel/Symbol.h	(revision 1038)
@@ -21,6 +21,7 @@
@@ -32,7 +33,7 @@
     // point geometric primitives. Its use of expressions for its
properties
     // allows it to support multivariate theming. Symbol is an abstract
class.
+    class MDFMODEL_API Symbol : public MdfRootObject
     public:
Index: E:/MgDev/OS/Common/MdfModel/CalculatedProperty.h
--- E:/MgDev/OS/Common/MdfModel/CalculatedProperty.h	(revision 1037)
+++ E:/MgDev/OS/Common/MdfModel/CalculatedProperty.h	(revision 1038)
@@ -20,6 +20,7 @@
@@ -28,7 +29,7 @@
 // CalculatedProperty class defines the calculated properties from
attributes
-    class MDFMODEL_API CalculatedProperty
+class MDFMODEL_API CalculatedProperty : public MdfRootObject
     public:
Index: E:/MgDev/OS/Common/MdfModel/Rule.h
--- E:/MgDev/OS/Common/MdfModel/Rule.h	(revision 1037)
+++ E:/MgDev/OS/Common/MdfModel/Rule.h	(revision 1038)
@@ -21,6 +21,7 @@
 #include "Label.h"
 namespace MdfParser
@@ -39,7 +40,7 @@
     // Filtering criteria takes the form of a tree that uses logical
operators
     // to combine attribute-based and geometry-based filters.
-    class MDFMODEL_API Rule
+class MDFMODEL_API Rule : public MdfRootObject
         friend class MdfParser::IOAreaRule;
         friend class MdfParser::IOLineRule;
Index: E:/MgDev/OS/Common/MdfModel/FeatureTypeStyle.h
--- E:/MgDev/OS/Common/MdfModel/FeatureTypeStyle.h	(revision 1037)
+++ E:/MgDev/OS/Common/MdfModel/FeatureTypeStyle.h	(revision 1038)
@@ -21,6 +21,7 @@
 #include "Rule.h"
@@ -35,7 +36,7 @@
     // It is possible for FeatureTypeStyle's concrete classes to
contain
     // only Labels.
-    class MDFMODEL_API FeatureTypeStyle
+    class MDFMODEL_API FeatureTypeStyle : public MdfRootObject
     public:
         // Construction, destruction, initialization.
Index: E:/MgDev/OS/Common/MdfModel/Makefile.am
--- E:/MgDev/OS/Common/MdfModel/Makefile.am	(revision 1037)
+++ E:/MgDev/OS/Common/MdfModel/Makefile.am	(revision 1038)
@@ -43,6 +43,7 @@
   MapLayerGroupCommon.cpp \
   MarkSymbol.cpp \
   MdfModel.cpp \
+  MdfRootObject.cpp \
   NameStringPair.cpp \
   PointRule.cpp \
   PointSymbolization2D.cpp \
@@ -104,6 +105,7 @@
   MarkSymbol.h \
   MdfModel.h \
   MdfOwnerCollection.h \
+  MdfRootObject.h \
   NameStringPair.h \
   PointRule.h \
   PointSymbolization2D.h \
URL: http://lists.osgeo.org/pipermail/mapguide-internals/attachments/20070108/bf52c4df/attachment.html
More information about the Mapguide-internals mailing list
