[Mapguide_dev] RE: [Mapguide_users] MGRenderingService QueryFeatures
Andy Morsell amorsell at spatialgis.com
Thu Jan 11 18:46:05 EST 2007
To answer your question about which list to post to: mapguide_users is the
proper one for end user support and questions.  Dev is intended for the
source coders and other things related to the MapGuide project including the
Project Steering Committee.  You might be getting more answers there since
the coders are more likely following that list on a regular basis than the
users list..... But, it should probably not become habit to post end user
questions there.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
-----Original Message-----
[mailto:mapguide_users-bounces at lists.osgeo.org] On Behalf Of Scott Hameister
Sent: Thursday, January 11, 2007 3:17 PM
To: Mapguide_users at lists.osgeo.org; mapguide_dev at lists.osgeo.org
Subject: [Mapguide_users] MGRenderingService QueryFeatures
OK Giving up on FCGI answers for QueryMapFeatures....
Anybody have any examples of the API using MGRenderingService and
QueryFeatures...any language would do.
Also Which Group should this go under??? Is Dev for Actual Open Source
coders...or API programmers as well...I seem to get more answers from Dev
but don't want to be impolite
Sent: Thursday, January 11, 2007 10:45 AM
Subject: RE: [Mapguide_users] CGI QueryMapFeatures
Is there any documentation on the FCGI OPERATIONS and params Yet?
Since the WebAPI is so wrapped around it it would be nice to no what
parameters are available...
When I goto http://localhost/mapguide/mapagent/index.html
"OPERATION=QueryMapFeatures" isn't even an option...and I'm assuming even
this site doesn't give all the options of FCGI params either.
Sent: Wednesday, January 10, 2007 6:47 PM
Subject: [Mapguide_users] CGI QueryMapFeatures
I can't find documentation on the FCGI operation QueryMapFeatures When I
change the ViewerAPi Code where it filters by the selectable and visible
layers " LAYERNAMES=" + encodeURIComponent(GetVisSelLayers())"
To a list of Non-visible layers it doesn't work....
....I want users to be able to select features using the geometry on layers
that are not visible as well for parsing purposes? Can I use this Operation
for that
Mapguide_users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide_users
More information about the Mapguide-internals mailing list
