[mapguide-internals] Defect: Bad KML request crashes MapAgent
Jason Birch Jason.Birch at nanaimo.ca
Mon Jan 22 01:46:13 EST 2007
Oh,
And as more of an enhancement request:
Currently, there is no way for a user to save a MapGuide-generated network link to their GE client, and timeouts are not handled gracefully.
If USERNAME and PASSWORD are passed to the intitial MapAgent call, I wonder if these should be passed through to lower-level requests as well, or maybe there should be some way of flagging the MapAgent to allow automatic session regeneration on KML requests.  Alternately, KML could be dealt with like WMS and WFS; requiring specific resources to be tagged.  Unfortunately, a network link will usually hit several resources.
At a higher level, I can work around this by requiring the user to download a KML file that contains the initial GetMapKml request including the username and password, but they are still stuck with the subsidiary layers timing out and the inability to save anything but the parent link locally.
Also, I think that there should be code to wrap any errors the MapAgent throws into KML, preferably into a <Folder> with the title in the name element and the contents in the description.  This would allow a developer to copy/paste the folder out into a text editor for examination.
Jason
From: mapguide-internals-bounces at lists.osgeo.org on behalf of Jason Birch
Sent: Sun 2007-01-21 10:01 PM
To: mapguide-internals at lists.osgeo.org
Subject: [mapguide-internals] Defect: Bad KML request crashes MapAgent
Since we don't have Trac working yet...
By accident, I've found an issue in the KML service.  When requesting a GetLayerKML without specifying the required view window parameters (BBOX, etc) the MapAgent crashes.
Configuration:
Windows XP Pro SP2
MapGuide OS 1.1.0, bundled Apache/Php configuration
Steps to reproduce:
1. Call this URL
http://localhost:8008/mapguide/mapagent/mapagent.fcgi?OPERATION=GETMAPKML&VERSION=1.0.0&FORMAT=XML&DPI=96&MAPDEFINITION=Library%3A%2F%2FSamples%2FSheboygan%2FMaps%2FSheboygan.MapDefinition
2. Copy and paste the contents of the first network link definition into your browser.  It should look something like this but with a different session tag:
http://localhost:8008/mapguide/mapagent/mapagent.fcgi?OPERATION=GetLayerKml&VERSION=1&LAYERDEFINITION=Library://Samples/Sheboygan/Layers/Roads.LayerDefinition&DRAWORDER=8&FORMAT=XML&SESSION=a0798668-ffff-ffff-8000-00e02983d68a_en <http://localhost:8008/mapguide/mapagent/mapagent.fcgi?OPERATION=GetLayerKml&VERSION=1&LAYERDEFINITION=Library://Samples/Sheboygan/Layers/Roads.LayerDefinition&DRAWORDER=8&FORMAT=XML&SESSION=a0798668-ffff-ffff-8000-00e02983d68a_en>
3. Watch as the MapAgent crashes and burns
Jason
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
