[mapguide-internals] RFC required for tile caching changes?
Walt Welton-Lair walt.welton-lair at autodesk.com
Tue Jan 23 16:26:28 EST 2007
If you make the cached tile size a parameter then this will also require some AJAX Viewer work.  IIRC the AJAX code has the current tile size hard-coded.  If you make it a parameter then you'll need to update ajaxviewer.templ (I think) to let it be set dynamically.
There may also be other things you need to fix in AJAX.  For example, it currently requests tiles for rows / columns which are slightly outside your visible extents.  I don't know offhand how many extra rows / columns it requests, but it seems this also depends on the tile size.  Maybe you'd want to request enough rows/columns to give you an additional 25% screen coverage.  So the number of extra rows/columns you'll need to request on each side is 0.25 * screen width in pixels / tile size.  I don't know if AJAX viewer currently has such logic.
Walt
	-----Original Message-----
	From: mapguide-internals-bounces at lists.osgeo.org on behalf of Chris Claydon
	Sent: Tue 1/23/2007 9:42 PM
	To: MapGuide Internals Mail List
	Cc:
	Subject: RE: [mapguide-internals] RFC required for tile caching changes?
	That should be relatively straightforward to achieve. I would add a comment into serverconfig.ini indicating that any modifications to these settings would:
	a)       Only take effect after a server restart.
	b)       Invalidate ALL existing cached tiles.
	Chris.
  _____
	From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Trevor Wekel
	Sent: January 23, 2007 1:34 PM
	Hi Chris,
	As an additional item, can we add serverconfig.ini parameters to control the following:
	- Size of the cache tile where the tiles assumed to be square "TileSize = 300" for 300x300 tiles
	- Tile block size, ie. the mod value in the discussion below "TileBlockSize = 30"
	The first item is good for tuning and is useful if you need to match MapGuide tiles against an externally tiled raster source.  The second item could be used for tuning and eventually to support "block rendering" of tiles.
	Thanks,
	Trevor
  _____
	From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Chris Claydon
	Sent: Tuesday, January 23, 2007 1:26 PM
	We seem to have digressed a little from my original question! I have summarized the issues discussed in this thread below. I would like to implement the changes as proposed in item 2), and to do so without the need for an RFC. Please let me know if this is unacceptable for any reason.
	Thanks,
	Chris.
	1)       We cannot conform directly with the Tile Map Service Specification, because it does not currently support the concept of grouping sets of tiles into individual folders. However, it would be very simple to write a simple script or servlet to map from the specification’s path format directly to the MapGuide format.
	2)       Traian suggested a slightly modified folder naming convention that provides an easier mapping to the original tile index. I like this approach and would be happy to implement it this way. His proposal is as follows:
	“Another suggestion I have -- name the folder part of the path (30 * tile index div 30) and then the file part would be (tile index mod 30).
	So for tile 33,64 the folder would be:
	Base Layer Group/30/60/3_4.png
	And for tile -33,-64 the folder would be:
	Base Layer Group/-30/-60/-3_-4.png
	For tile 1,1, the folder would be:
	Base Layer Group/0/0/1_1.png
	For tile -1,-1 the folder would be:
	Base Layer Group/-0/-0/-1_-1.png”
	3) Various issues were brought up regarding how tiles are generated, and how label placement can be optimized. These are beyond the scope of my proposal, and can be addressed separately without being affected by the changes I’ve proposed.
  _____
	From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Robert Bray
	Sent: January 17, 2007 9:08 AM
	Subject: Re: [mapguide-internals] RFC required for tile caching changes?
	Hey Paul, I think that is because you explicitly added him, for some weird reason this list is already set to reply to list. The change in question would not have made a difference in this case...
	Bob
	Paul Spencer wrote:
	Steve's response bounced from the list, but fortunately reply-to-all was still actually sending to everyone so I actually got the message ... hint, hint ...
	Paul
	On 16-Jan-07, at 11:18 PM, Steve Lime wrote:
	Paul: Er, I spent too much time at the Camp-to-Camp beer tap so my
	memory is a bit fuzzy. We talked about several things from pre-computing
	label positions to what you mention below. You are correct in how
	MapServer works. It doesn't have any special "tiled" mode and hence
	considers each tile just as any other map. In a single map context,
	computing label positions post-clip makes sense.
	Computing label positions pre-clip would result in a single, consistent
	label position for each feature. For points and polygons that's
	generally
	OK I believe. For linear features the results might not always be
	optimal
	since the clipping often provides a nice means of segmenting long
	features
	so that get labeled multiple times. One could work around that at the
	data level by segmenting long features ahead of time.
	I don't believe it would hard to hack MapServer drawing routine
	to do this and someone could test it out. Let me know if interested.
	Steve
			Paul Spencer <pspencer at dmsolutions.ca> <mailto:pspencer at dmsolutions.ca>  01/15/07 7:03 PM >>>
	Walt,
	I don't believe it got documented.  I spoke with Steve Lime (cc'd)
	directly about this during OSGeo.
	At the time, I believe Steve suggested label placement would be done
	before features are clipped for rendering.  I believe the way
	mapserver works, it grabs all features that intersect a given bbox
	then clips the features to the bbox then renders them.  Labelling is
	currently done post-clip.  If it were done pre-clip, then labels
	would be in a fixed position and could overlap tile boundaries
	without problems.
	I do believe that there were some potential problems with this
	approach, but I don't know enough of mapserver internals to remember
	what they were.
	Steve, perhaps you could jump in and fix my explanation?  Also, do
	you think that label rendering changes would be a potential for
	version 5?
	Cheers
	Paul
	On 15-Jan-07, at 2:54 PM, Walt Welton-Lair wrote:
	"In lieu of fixing this in MapServer (there is actually a proposal
	to fix this)..."
	Paul - is there per chance a public link to this proposal?  I'd be
	interested in looking at it.
	Thanks,
	Walt
	Paul
	Spencer (External)
	    Sent: Mon 1/15/2007 7:40 PM
	    Cc:
	changes?
	    Trevor,
	    I don't think I got my idea across clearly :)  Let me explain a
	    little more clearly.
	    In ka-Map, the size of a tile is configurable and by default is
	    200x200 px.  There is a second concept that I've called a 'meta
	    tile'.  A meta tile is some number of tiles wide x high,
	typically 10
	    x 10.  When a request for a tile comes to the tile server, it
	checks
	    the cache.
	    If the tile exists, the tile (200x200px) is returned.  This
	happens
	    without invoking any map rendering ... the tile exists as an
	image on
	    disk.
	    If the tile does not exist, then a map render happens.  A map
	the
	    size of the meta tile is rendered and sliced into tile-sized
	chunks
	    that are stored on disk in the cache directory structure.  While
	the
	    tiles are being created, a lock file is used to 'pause' requests
	for
	    tiles in the same meta-tile directory so that they can all be
	served
	    from the same map draw when it is finished.
	    We chose this approach for several reasons.  First, MapServer
	suffers
	    from edge effects when rendering map images.  This is normally
	not
	    noticeable, but when you put several map draws together in a
	tiled
	    client, it becomes horribly obvious.  The solution was to render
	a
	    slightly larger map image (about 10 pixels in fact) and clip out
	the
	    center as the tile.  Second, MapServer labelling only considers
	the
	    current map draw.  Depending on the size of the rendered label,
	it
	    may not fit into a single tile.  Depending on the size of a
	feature,
	    the label may appear on several adjacent tiles.  In lieu of
	fixing
	    this in MapServer (there is actually a proposal to fix this),
	    rendering a much larger map and slicing it into smaller tiles
	    produces a reasonable effect.  Finally, it is relatively
	expensive to
	    parse the map file and find/read the data compared to rendering
	so
	    rendering a single large image and slicing it is cheaper than
	    rendering each smaller tile (with diminishing returns).
	    I don't know how you actually render the tiles in MapGuide, but
	I
	    don't think you suffer from the same edge and label issues.
	    The ka-Map directory structure looks something like this:
	    <map>/<layer-group>/<scale>/<row-of-metatile>/<col-of-metatile>/<row-
	    of-tile><col-of-tile>.<ext>
	    ... which is similar to Chris' suggestion :)  I don't get the
	    impression that you render the entire contents of the metatile
	    directory in one go though.  Because I do, I only have to check
	if
	    the meta-tile directory exists to know if any tile in the
	directory
	    exists, which is a small optimizatin.
	    One difference between Chris' proposal and the way ka-Map works
	is
	    that the scale and layer group are reversed.  This makes it
	    theoretically possible to share the <layer-group> cache
	directory
	    between different maps simply by creating symlinks or by
	allowing a
	    per-layer-group setting that indicates the root directory to
	keep the
	    tile cache in.
	    Cheers
	    Paul
	    On 15-Jan-07, at 11:49 AM, Trevor Wekel wrote:
	    > Hi everyone,
	    > I did some analysis on file systems a little while ago in
	support
	    > of the
	    > directory structure change.  Here are some approximate numbers
	for
	    > directory entry and file system entries that I pulled from an
	internet
	    > search:
	    > Linux ext3  - each file or directory is approx 8 bytes +
	length of
	    > file
	    > or directory name
	    > Linux Reiserfs  - each file or directory is 18 bytes + length
	of
	    > file or
	    > directory name
	then
	    > each
	    > file entry will require 26 bytes under ext3 and 34 bytes under
	    > ReiserFS.
	    > To facilitate fast directory access, tiles which are close to
	each
	    > other
	    > should like in the same directory.  This reduces the directory
	entry
	    > reads for each tile request.  If we also assume that the read
	block
	    > size
	    > for the file system is 32kbytes (32/64k is often used in RAID
	arrays)
	    > then a directory with 900 entries (30x30 block) will get read
	in a
	    > single IOP (900*34 = 30600).  And since the tiles are blocked
	    > together,
	    > it is very likely that adjacent tiles will fall within the
	same
	    > directory.  Since the directory was just read, it will be
	cached
	and
	    > there will be no disk access required.
	    > If we increase the size of the directories to more than 900
	entries
	    > then
	    > we will incur more than IOP to read the bottom-most directory
	    > structure.
	    > I also think Traian's suggestion of Base Layer Group/
	30/60/3_4.png is
	    > reasonable.  It is more readable than the original mod scheme.
	    >> From a rendering perspective, dealing with 2000x2000 pixel
	blocks
	    >> may be
	    > more efficient but cutting the tiles up from these larger
	images
	will
	    > require some computational effort.  Rendering the tiles in the
	same
	    > size
	    > as requested from the client reduces server load because the
	HTTP
	    > request ends up being simply a file serving operation.
	    > With some of the latest optimizations I have been working on,
	MapGuide
	    > tile serving speeds using "client-sized" tiles are quite
	respectable.
	    > On a machine with a single 3GHz CPU, MapGuide can service more
	than
	    > 100
	    > tiles per second assuming the tiles are being served from
	memory,
	    > ie. no
	    > disk access.  The additional computational effort required to
	generate
	    > "client" tiles from larger pixel blocks will significantly
	impact
	    > performance.
	    > Thanks,
	    > Trevor
	Of
	Paul
	    > Spencer (External)
	    > Sent: Sunday, January 14, 2007 11:59 AM
	caching
	    > changes?
	    > FWIW, Traian's suggestion for naming folders based on a mod of
	r/
	c is
	    > essentially the same approach I took with ka-Map (for the same
	reason
	    > that Chris brought this up) and it seems to work very well.
	In ka-
	    > Map,
	    > tiles are rendered in blocks of about 2000x2000 pixels (tile
	size is
	    > configurable but you might get 10 x 10 tiles in a typical
	    > configuration) and they would go in one of these sub-
	directories.  I
	    > think I figured out that this would be enough directories to
	decently
	    > cache a pretty large area (say, all of the US) without running
	into
	    > file
	    > system limits for most scales.
	    > It would be interesting to know the limits on:
	    > * files per directory
	    > * directories per directory
	    > * total number of directories
	    > * total number of files
	    > * minimum block(?) size in the file system compared to typical
	size
	    > of a
	    > tile (wasted space per tile).
	    > for various operating systems/file system combinations.  I
	know
	we use
	    > ReiserFS because it handles lots of small files better than
	ext3
	for
	    > instance.  Knowing some of this might help make the caching
	system
	    > more
	    > tunable in different environments.
	    > Paul
	    > On 13-Jan-07, at 11:09 AM, Traian Stanev wrote:
	    >> Can you also give an example for tiles with negative indices?
	    >> For example if in the current scheme the tile is -33, -64,
	what
	would
	    >> be the resulting directory path?
	    >> R-2/C-3/-3_-4
	    >> What about tile -1,-1
	(30 *
	index mod
	    >> 30).
	    >> It's a little weird around 0, but it allows for arbitrary
	    >> groupings of
	    >> tiles in folders (they don't have to be 30x30) since the tile
	index
	    >> can be computed directly from the file path, by adding the
	folder
	    >> term
	    >> to the file path term.
	    >> Also, can you tell us what the problem is with having too
	many
	images
	    >> in one directory? Is it a file system issue? And how many
	tiles is
	    >> the
	    >> limit, i.e. why is 30x30 the preferred grouping and not
	1000x1000 for
	    >> example?
	    >> Traian
	Jason
	    >> Birch
	    >> Sent: Fri 1/12/2007 8:57 PM
	    >> Cc:
	caching
	    >> changes?
	    >> Can I forward this to the "tiling" list for comment?
	Chris
	    >> Claydon
	    >> Sent: Fri 2007-01-12 12:24 PM
	caching
	    >> changes?
	    >> A sample tile location would be as follows:
	Repositories\TileCache\Samples_Sheboygan_Maps_Sheboygan\7
	    >> \Base
	    >> The R and C indices correspond to rows and columns where each
	row
	    >> contains 30 tiles vertically and each column contains 30
	tiles
	    >> horizontally.
	    >> This indicates that:
	    >> 1)       We're at zoom level 7
	    >> 2)       We're in grouped row 2
	    >> 3)       We're in grouped column 3
	    >> 4)       The tile location within this grouped row/column
	    >> combination is (3,4).
	    >> The R and C indices never take a zero value (to avoid issues
	with
	    >> negative values around the origin), so this tile corresponds
	to a
	    >> location of (33, 64) in the old scheme.
	    >> I took a quick look at the Tile Map Service Specification,
	but it
	    >> doesn't appear to support the concept of grouping blocks of
	tiles
	    >> into subfolders in its current form. Can you provide more
	    >> information on whether this is possible?
	    >> Chris.
	    >> mapguide-internals mailing list
	    >> mapguide-internals at lists.osgeo.org
	    >> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
	    > |Paul Spencer                          pspencer at dmsolutions.ca
	    > |Chief Technology Officer
	    > |DM Solutions Group Inc
	http://www.dmsolutions.ca/ |
	<winmail.dat>
	|Paul Spencer                          pspencer at dmsolutions.ca    |
	|Chief Technology Officer                                         |
	|DM Solutions Group Inc                http://www.dmsolutions.ca/ |
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-internals/attachments/20070123/d13c4121/attachment-0001.bin
More information about the mapguide-internals mailing list
