[mapguide-internals] ogr postgis layer problems
Tom Fukushima tom.fukushima at autodesk.com
Wed Jan 31 17:17:55 EST 2007
I posted the zip file at the same place as before
http://download.osgeo.org/fdo/3.2.0/OGRProvider-3.2.0.win32.zip.
The old one is now at
http://download.osgeo.org/fdo/3.2.0/OGRProvider-3.2.0.win32.zip.old if
you need it for some reason.
Tom
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Traian
Stanev
Sent: Wednesday, January 31, 2007 2:50 PM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] ogr postgis layer problems
Hi again.
I've fixed both issues in the OGR provider. Selection now works fine,
including multi-select, when tested on SHP files. There was a problem
with intersection queries (the problem was they weren't implemented,
heh). I also fixes the problem of the features disappearing after
selection -- I had forgotten to reset the filters on the OGRLayer in
between Selects. I also fixed a small problem in OGR, which was making
FID filters fail. I'll have Tom post a new Win32 DLL to the provider
download location.
FYI, I recompiled against the following versions of the dependent
libraries: GDAL 1.4.0 (plus my fix), PostgreSQL 8.2.1, Proj 4.5.0, Geos
2.2.3, plus unknown versions of Oracle OCI and ODBC.
Traian
Sent: Wednesday, January 31, 2007 3:33 PM
To: 'MapGuide Internals Mail List'
Hi Paul.
I tried it against an SHP file and selection is definitely not working
right. :) To avoid the disappearing map problem, you can disable
connection pooling for the OGR provider in the serverconfig.ini file.
This will prevent the map from disappearing (since the connection is not
reused after it breaks during selection), but it will not make selection
work. I will see what can be done about fixing this and let you know.
Traian
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Paul
Spencer (External)
Sent: Tuesday, January 30, 2007 9:18 PM
Subject: [mapguide-internals] ogr postgis layer problems
Hi all,
I am looking into an issue regarding postgis layers loaded via the OGR
provider for a client.  The postgis layer is functioning normally when
the map loads (it is initially off but it can be toggled on/off no
problem).  It can be queried using the select.  However, when the layer
has had features selected on it, the next action causes the layer to be
turned off and the layer cannot be turned back on without restarting the
service and web browser.
Any ideas what might be going on?  Bug in the OGR provider?  AJAX
Viewer?  Bad data?
Cheers
Paul
|Paul Spencer                          pspencer at dmsolutions.ca    |
|Chief Technology Officer                                         |
|DM Solutions Group Inc                http://www.dmsolutions.ca/ |
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
