[mapguide-internals] MapGuide 1.2 RC2 and King.Oracle memory leak
Zac Spitzer
zac.spitzer at gmail.com
Sun Jul 15 11:18:37 EDT 2007
Hi Harris,
I'm curious if fixing the memory leak make any difference to performance?
On 7/5/07, Haris Kurtagic <haris at sl-king.com> wrote:
> Hi Tom,
> I believe I mixed up things with Oracle libraries ( 10.2.0.3 and
> 10.2.0.1 ).
> I hope I solved it with 0.7.1 version of provider
> Thank you,
> Haris
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org
> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Tom
> Fukushima
> Sent: Tuesday, July 03, 2007 11:30 PM
> To: MapGuide Internals Mail List
> Subject: RE: [mapguide-internals] MapGuide 1.2 RC2 and King.Oracle
> memory leak
> Hi Haris,
> The source for RC2 in the tar file is the same as the source used to
> build the binaries.
> RC1 was built on June 9th and RC2 was built on June 15th, so you want
> changes that went in on the 9th up to the 14th. You should be able to
> query subversion to get these submissions.
> I'm not sure if RC1 and RC2 are FDO binary compatible, so you may want
> to recompile the SL-King provider with the latest FDO Core as well. The
> RC2 version is available using the 3.2.2 RC2 links at
> http://fdo.osgeo.org/downloads.html.
> Cheers
> Tom
> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Haris
> Kurtagic
> Sent: Tuesday, July 03, 2007 10:11 AM
> Subject: [mapguide-internals] MapGuide 1.2 RC2 and King.Oracle memory
> leak
> HI,
> I hope someone can give me some idea, I saw a ticket for memory leak in
> RC2 and King.Oracle and I can reproduce it easily, it is very obvious.
> Problem is that if I use same provider (same binaries ) in RC1 I can't
> see a leak, also if I run provider on MapGuide RC2 which I build ( debug
> and release) I also can't reproduce error.
> Could be that posted release of RC2 ( windows installer ) and posted RC2
> source are not the same ? ( Long shot question but it really looks
> strange to me ).
> How can I see which files has been changed from RC1 to RC2 ?
> Also I done testing in Fdo2Fo and after fixing memory leak in Fdo2Fdo
> itself which was general leak ( no matter of provider ) I also can't
> reproduce it.
> Thanks,
> Haris
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer
http://zacster.blogspot.com/
+49 157 7453 0726 (german mobile)
+ 49 30 4597 2130 (german landline)
+61 3 9018 5778 (voip via my pc)
+61 405 847 168 (aussie moible)
More information about the mapguide-internals
