[mapguide-internals] MapGuide 1.2 RC2 and King.Oracle memory leak
Zac Spitzer zac.spitzer at gmail.com
Thu Jul 19 13:32:05 EDT 2007
Hi Harris,
I just downloaded and installed 0.7.1 and also 1.20RC2 on my laptop.
i am seeing a consistant increases in both mem and vm using 0.7.1,
very similiar results to the http://trac.osgeo.org/fdo/ticket/72
results
it is taking 15 times as long to display the same data from oracle
than from a sdf with the same data. this was using a 17.5 MB shp file.
Zac
On 7/17/07, Haris Kurtagic <haris at sl-king.com> wrote:
> Hi Zac,
> In general It shouldn't be any significant slow down in provider.
> As a meter of fact I didn't saw any memory leaks in King.Oracle code
> itself so there were no significant changes of code.
> Changes in latest releases of provider includes ( which can be connected
> to performance):
> 1. Problem with memory leaks which I was able to detect was with error
> in building with 10.2.0.3 ( 0.7.1 changed back to 10.2.0.1 ).
> 2. Disabling caching of FDO schema for several connections which can
> cause slower performance with multi user access. I couldn't confirm any
> memory issues because of it so I am planning to enable caching again.
> 3. When provider returns FDO schema to (MapGuide, Map,..) it will create
> a copy of FDO schema to solve issue in MapGuide with multiuser
> concurrent edits. But FDO schema should be cached inside MapGuide so
> this "copy" should occur just once per FDO King.Oracle connection.
> 4. Creating new Oracle Environment for every new connection ( solving
> multi user concurrent access issue)
> Are you experiencing performance degradation in provider? If so in
> MapGuide or Map ?
> Do you experience any memory leaks with 0.7.1 ( MapGuide, Map) ?
> Haris
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org
> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac
> Spitzer
> Sent: Sunday, July 15, 2007 5:19 PM
> To: MapGuide Internals Mail List
> Subject: Re: [mapguide-internals] MapGuide 1.2 RC2 and King.Oracle
> memory leak
> Hi Harris,
> I'm curious if fixing the memory leak make any difference to
> performance?
> On 7/5/07, Haris Kurtagic <haris at sl-king.com> wrote:
> > Hi Tom,
> > I believe I mixed up things with Oracle libraries ( 10.2.0.3 and
> > 10.2.0.1 ).
> > I hope I solved it with 0.7.1 version of provider
> > Thank you,
> > Haris
> > [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Tom
> > Fukushima
> > Sent: Tuesday, July 03, 2007 11:30 PM
> > Subject: RE: [mapguide-internals] MapGuide 1.2 RC2 and King.Oracle
> > memory leak
> > Hi Haris,
> > The source for RC2 in the tar file is the same as the source used to
> > build the binaries.
> > RC1 was built on June 9th and RC2 was built on June 15th, so you want
> > changes that went in on the 9th up to the 14th.  You should be able to
> > query subversion to get these submissions.
> > I'm not sure if RC1 and RC2 are FDO binary compatible, so you may want
> > to recompile the SL-King provider with the latest FDO Core as well.
> The
> > RC2 version is available using the 3.2.2 RC2 links at
> > http://fdo.osgeo.org/downloads.html.
> > Cheers
> > Tom
> > [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Haris
> > Kurtagic
> > Sent: Tuesday, July 03, 2007 10:11 AM
> > Subject: [mapguide-internals] MapGuide 1.2 RC2 and King.Oracle memory
> > leak
> > HI,
> > I hope someone can give me some idea, I saw a ticket for memory leak
> in
> > RC2 and King.Oracle and I can reproduce it easily, it is very obvious.
> > Problem is that if I use same provider (same binaries ) in RC1 I can't
> > see a leak, also if I run provider on MapGuide RC2 which I build (
> debug
> > and release) I also can't reproduce error.
> > Could be that posted release of RC2 ( windows installer ) and posted
> RC2
> > source are not the same ? ( Long shot question but it really looks
> > strange to me ).
> > How can I see which files has been changed from RC1 to RC2 ?
> > Also I done testing in Fdo2Fo and after fixing memory leak in Fdo2Fdo
> > itself which was general leak ( no matter of provider ) I also can't
> > reproduce it.
> > Thanks,
> > Haris
> > mapguide-internals mailing list
> > mapguide-internals at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapguide-internals
> Zac Spitzer
> http://zacster.blogspot.com/
> +49 157 7453 0726 (german mobile)
> + 49 30 4597 2130 (german landline)
> +61 3 9018 5778 (voip via my pc)
> +61 405 847 168 (aussie moible)
Zac Spitzer
More information about the mapguide-internals mailing list
