[mapguide-internals] Rfc 21 posted
Paul Spencer pspencer at dmsolutions.ca
Fri Jun 1 07:05:05 EDT 2007
Personally, I would only want it to affect a specific map within a
specific session.  I believe it is possible to have more than one map
in the session based on the same map definition and I think this
should only affect the specifically named map.  It certainly should
not affect other users in other sessions.
Cheers
Paul
On 31-May-07, at 7:34 PM, Walt Welton-Lair wrote:
> Do these new APIs take into account the caller's session?  You can
> have
> multiple users viewing the same map definition, and therefore there
> are
> multiple runtime maps associated with that map definition (each
> part of
> a different session).
> I also can't remember - is it possible to have two runtime maps for
> the
> same map definition within a single session?
> Walt
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org
> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Bruce
> Dechant
> Sent: Friday, June 01, 2007 1:10 AM
> To: MapGuide Internals Mail List
> Subject: RE: [mapguide-internals] Rfc 21 posted
> Here are my comments.
> In the APIs below there is no need for the "mapName" parameter because
> everything is already contained in the underlying map resource
> referenced by the MgResourceIdentifier so the parameter is redundant:
> void MgMap::UpdateRuntimeMap(MgResourceService* resourceService,
> MgResourceIdentifier* mapDefinition, CREFSTRING mapName); void
> MgMap::UpdateMapDefinition(MgResourceService* resourceService,
> For the other proposed APIs below the "mapName" parameter should be
> replaced with the MgResourceIdentifier because we do operations with
> resource IDs:
> MgByteReader* mapDefinitionAsXml, CREFSTRING mapName);
> MgByteReader* MgMap::MapDefinitionFromRuntimeMap(MgResourceService*
> resourceService, CREFSTRING mapName); void
> MgMap::CreateMap(MgResourceService* resourceService, MgByteReader*
> Thanks,
> Bruce
> Kenneth, GEOGRAF A/S
> Sent: May 29, 2007 2:56 AM
> Subject: [mapguide-internals] Rfc 21 posted
> I have posted a Rfc.
> http://trac.osgeo.org/mapguide/wiki/MapGuideRfc21
> Regards, Kenneth, GEOGRAF A/S
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
|Paul Spencer                          pspencer at dmsolutions.ca    |
|Chief Technology Officer                                         |
|DM Solutions Group Inc                http://www.dmsolutions.ca/ |
More information about the mapguide-internals mailing list
