[mapguide-internals] Rfc 21 posted
Kenneth, GEOGRAF A/S ks at geograf.dk
Sat Jun 2 14:27:48 EDT 2007
Thanks for looking at my proprosal.
You are right, the mapName can be read from the mapDefinition.
However, the current CreateMap function uses this argument to create a
resource identifier:
"Session:" + sessionId + "//" + mapName + ".Map"
Currently, the Viewers extract the mapName from the mapDefinition, and
passes this on to the CreateMap call.
There is nothing preventing a custom viewer from using a different mapName.
So, there should be a mapName parameter.
In all the functions I proposed, the type of mapName should in fact be
MgResourceIdentifer.
I initially chose the CREFSTRING because the CreateMap used this
parameter type.
I have update the Rfc with the new parameter types.
Regards, Kenneth, GEOGRAF A/S
Bruce Dechant wrote:
> Here are my comments.
> In the APIs below there is no need for the "mapName" parameter because
> everything is already contained in the underlying map resource
> referenced by the MgResourceIdentifier so the parameter is redundant:
> void MgMap::UpdateRuntimeMap(MgResourceService* resourceService,
> MgResourceIdentifier* mapDefinition, CREFSTRING mapName); void
> MgMap::UpdateMapDefinition(MgResourceService* resourceService,
> For the other proposed APIs below the "mapName" parameter should be
> replaced with the MgResourceIdentifier because we do operations with
> resource IDs:
> MgByteReader* mapDefinitionAsXml, CREFSTRING mapName);
> MgByteReader* MgMap::MapDefinitionFromRuntimeMap(MgResourceService*
> resourceService, CREFSTRING mapName); void
> MgMap::CreateMap(MgResourceService* resourceService, MgByteReader*
> Thanks,
> Bruce
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org
> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of
> Sent: May 29, 2007 2:56 AM
> To: MapGuide Internals Mail List
> Subject: [mapguide-internals] Rfc 21 posted
> I have posted a Rfc.
> http://trac.osgeo.org/mapguide/wiki/MapGuideRfc21
More information about the mapguide-internals mailing list
