[mapguide-internals] Problem with multi-thread update
Simon Pelicon simon at sl-king.com
Mon Jun 11 08:55:01 EDT 2007
Hi.
I have some problem with updating (update/insert/delete) features.
When I try to  update features at the same time ( multi-thread ),
MapGuide Server stops working ( FDO exception is returned ).
I debugged MapGuide Server and i noticed that before any update in
MgServerFeatureService::UpdateFeatures ( line 480 in
MgServerFeatureService.cpp )
RemoveFeatureServiceCacheEntry function is called (Line 485 in
MgServerFeatureService.cpp).
If i comment out RemoveFeatureServiceCacheEntry function call it seams
that MapGuide Server works OK.
Do you know what could be the problem for this behaviour?
I use MapGuide Server 1.1.0 version.
Thanks!
More information about the mapguide-internals mailing list
