[mapguide-internals] Motion for a vote to eitheracceptorrejectMapGuide RFC 15 - New Query Features API
Bruce Dechant bruce.dechant at autodesk.com
Thu Mar 1 16:16:23 EST 2007
Jason,
What if I added another optional parameter KEEPSELECTION that defaults
to 1 (true), but if you wanted to not keep the selection you could set
the KEEPSELECTION parameter to 0 (false). This way it behaves exactly as
described in the RFC, but allows you to have it the way it was. I can
update the RFC with this amendment.
Thanks,
Bruce
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason
Birch
Sent: February 23, 2007 4:07 PM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] Motion for a vote to
Well, I said I could live with it (just read through the previous
comments) so I'll vote -0 :)
It would have been nice to be able to set a flag on a per-layout or
per-map basis that overrode this behaviour.  Removing it via the API is
a lot of work, and by the time the user sees the selection my reason for
objection is moot.
Jason
Subject: RE: [mapguide-internals] Motion for a vote to either
That is the new default behavior regardless of what the IGNORESCALE
setting is. If you don't want the selection you could always remove it
via the API or the user could simply click on an open space in the map.
Thanks,
Bruce
More information about the mapguide-internals mailing list
