[mapguide-internals] Motion for a votetoeitheracceptorrejectMapGuide RFC 15 - New Query Features API
Bruce Dechant bruce.dechant at autodesk.com
Thu Mar 1 16:53:14 EST 2007
You would have to modify the existing template code and any of your
additional framework code in order to override the default behavior.
Bruce
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason
Birch
Sent: March 1, 2007 2:27 PM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] Motion for a
Sounds promising :)
Where would this be set?  Would it be something that I could set on the
URL that calls the viewer from the overview frame, and would then be
cascaded through?  Or would I have to modify the template code for this
to work?
(note, these are hypothetical questions, as I'm using Fusion for my web
app framework)
Jason
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Bruce
Dechant
Sent: Thursday, March 01, 2007 13:16
Subject: RE: [mapguide-internals] Motion for a vote
Jason,
What if I added another optional parameter KEEPSELECTION that defaults
to 1 (true), but if you wanted to not keep the selection you could set
the KEEPSELECTION parameter to 0 (false). This way it behaves exactly as
described in the RFC, but allows you to have it the way it was. I can
update the RFC with this amendment.
Thanks,
Bruce
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
