[mapguide-internals] Re: Build problems
Thu Mar 15 11:38:38 EDT 2007
Jason Birch wrote:
> Just in case anyone missed it at the end of the localization message was a plea for help on SuSe.
> Apparently there is a considerable uptake possibility here if we can help get it going, and the Spanish-speaking community in OSGeo looks like it's extremely active.
> Frank, do you have any insights?  Would commenting out rik support possibly help?
Jason,
I don't know why the errors are occuring, but the rik driver is not
very important.  It can be omitted on linux by removing "rik" from
the list of supported formats in GDALmake.opt after running configure
(or GDALmake.opt.in before running configure.
Best regards,
> On the other hand, I am not able to install MGOS 1.1 at SUSE 10. Chris
> Gountanis sent me some steps to perform installation at
> Gentoo, but it didn't work. Thanks Chris.
> These are some of the errors I get when building and installing FDO:
> rikdataset.cpp:590: error: 'uLong' was not declared in this scope
> rikdataset.cpp:590: error: expected ';' before 'destLen'
> rikdataset.cpp:591: error: 'Byte' was not declared in this scope
> rikdataset.cpp:591: error: 'upsideDown' was not declared in this scope
> rikdataset.cpp:591: error: expected primary-expression before ')' token
> rikdataset.cpp:591: error: expected ';' before 'CPLMalloc'
> rikdataset.cpp:593: error: 'destLen' was not declared in this scope
> rikdataset.cpp:590: error: 'uncompress' was not declared in this scope
> rikdataset.cpp:597: error: expected primary-expression before ')' token
> rikdataset.cpp:591: error: expected ')' token before 'pImage'
> make[2]: *** [../o/rikdataset.o] Error 1
> make [2]:  Leaving directory
> '/usr/OpenSource_FDO/Thirdparty/GDAL1.3/src/frmts/rik'
> make [1]: *** [rik-install-obj] Error 2
> make [1]: Leaving directory
> '/usr/OpenSource_FDO/Thirdparty/GDAL1.3/src/frmts'
> make: *** [frmts-target] Error 2
> cp: cannot stat './.libs/libgdal.a' : No such file or directory
> cp: cannot stat './.libs/libgdal.so' : No such file or directory
> cp: cannot stat './.libs/libgdal.so.1' : No such file or directory
> cp: cannot stat './.libs/libgdal.so.1.9.0' : No such file or directory
> make: *** No rule to make target 'install'. Stop.
> There are 20 potential clients using SUSE at their servers and they will
> move to another solution/provider if I'm not successful.
> Anybody can help me?
> Lic. Jorge Rubio
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
More information about the mapguide-internals mailing list
