[mapguide-internals] Individual Contributor License AgreementandSpanish Localization
Jorge Rubio j.e.rubio at gmail.com
Thu Mar 29 10:32:54 EDT 2007
Thank you Rex. I'll complete translation now.
2007/3/28, Rex Szeto (Intern) <Rex.Szeto at autodesk.com>:
> [Follow-up]
> A file has been sent listing all the occurrences of the exceptions
> below.
> Thanks,
> Rex
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org
> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jorge
> Rubio
> Sent: Tuesday, March 20, 2007 9:20 AM
> To: MapGuide Internals Mail List
> Subject: Re: [mapguide-internals] Individual Contributor License
> It's perferct. It gives me an exactly idea what the error or exception
> means.
> 2007/3/20, Tom Fukushima <tom.fukushima at autodesk.com>:
> > Hi Jorge,
> > I won't be able to get anyone to look at it this week; however,
> someone
> > may be able to start on it next week.
> > What they will be doing is a search through the code for occurrences
> of
> > the Exception or ErrorDescription name and looking at the method that
> it
> > occurs in.  For example, I just did a search on
> > "MgCoordinateSystemMeasureFailedException" and found that it could be
> > raised from the following methods:
> > ///<summary>
> > /// Measures the euclidian distance between two coordinates.
> > ///</summary>
> > ///<param name="coord1">
> > /// An MgCoordinate that defines the starting coordinate.
> > ///</param>
> > ///<param name="coord2">
> > /// An MgCoordinate that defines the ending coordinate.
> > ///</param>
> > ///<returns>
> > /// The euclidean distance from coord1 to coord2 in coordinate system
> > units.
> > ///</returns>
> > double MgCoordinateSystem::MeasureEuclideanDistance(MgCoordinate*
> > coord1, MgCoordinate* coord2)
> > ///<summary>
> > /// Measures the distance between two coordinates.
> > /// This function uses the coordinate systems ellipsoid
> > /// definition and a great circle algorithm to produce the result.
> > ///</summary>
> > ///</param>
> > ///</param>
> > ///<returns>
> > /// The great circle distance from coord1 to coord2 in coordinate
> system
> > units.
> > ///</returns>
> > double MgCoordinateSystem::MeasureGreatCircleDistance(MgCoordinate*
> > ///<summary>
> > /// Computes the distance between two coordinates.
> > ///</summary>
> > /// An MgCoordinate that specifies the first coordinate.
> > ///</param>
> > /// An MgCoordinate that specifies the second coordinate.
> > ///</param>
> > ///<returns>
> > /// The distance between coord1 and coord2 as a double in coordinate
> > system units.
> > ///</returns>
> > double MgCoordinateSystemMeasure::GetDistance(MgCoordinate* coord1,
> > Is the above what you are looking for?
> > Thanks
> > Tom
> > Rubio
> > Sent: Monday, March 19, 2007 1:21 PM
> > Subject: [mapguide-internals] Individual Contributor License Agreement
> > Hi friends
> > I sent a signed Individual Contributor License Agreement by fax as was
> > suggested when I sent the first e-mail offering spanish localization.
> > In order to do an accurate translation to spanish I need more info
> about
> > what the following exceptions and error description mean and when they
> > are achieved.
> > When I finish translation, files will uploaded following Tom
> > instructions.
> > [Exceptions]
> > MgCoordinateSystemMeasureFailedException              = The coordinate
> > system measure failed.
> > MgDwfSectionNotFoundException                         = The specified
> > section was not found: %1
> > MgDwfSectionResourceNotFoundException                 = The specified
> > section resource was not found: %1
> > MgEmptyFeatureSetException                            = The feature
> set
> > is
> > empty.
> > MgEndOfStreamException                                = End of stream
> > exception.
> > MgFeatureServiceException                             = Feature
> Service
> > exception - %1
> > MgInvalidCastException                                = Invalid cast.
> > MgInvalidDwfSectionException                          = Invalid DWF
> > section:
> > %1
> > MgInvalidFeatureSourceException                       = Feature Source
> > %1
> > MgInvalidLogEntryException                            = An invalid log
> > entry
> > was found.
> > MgInvalidOperationVersionException                    = The requested
> > operation version is invalid.
> > MgInvalidResourcePreProcessingTypeException           = Invalid
> resource
> > pre-processing type.
> > MgInvalidStreamHeaderException                        = Invalid stream
> > header exception.
> > MgLengthException                                     = A length
> > exception
> > occurred.
> > MgLogicException                                      = # Logic
> > exception.
> > MgStreamIoException                                   = A stream IO
> > exception occurred.
> > [ErrorDescription]
> > MgContentDocumentNotEmpty                             = The content
> > document
> > is not empty.
> > MgContentNotNull                                      = The content is
> > not
> > null.
> > MgCoordinateDimensionDifferent                        = The coordinate
> > dimensions are different.
> > MgDataReaderIdNotFound                                = The data
> reader
> > ID
> > was not found.
> > MgDocumentIdentifierFilenameFailed                    = Failed to get
> > the
> > filename from the document identifier because no matching document
> path
> > found.
> > MgFeatureReaderIdNotFound                             = The feature
> > reader
> > ID was not found.
> > MgGroupAndRoleNotEmpty                                = Both the group
> > and
> > role are not empty.
> > MgHeaderDocumentNotEmpty                              = The header
> > document
> > is not empty.
> > MgInvalidAgfText                                      = The AGF text
> is
> > invalid because it failed to parse into a valid geometry object.
> > MgInvalidFeatureSpatialOperation                      = The feature
> > spatial
> > operation is invalid because it is not recognized.
> > MgInvalidLogType                                      = The log type
> is
> > MgInvalidMapPlotCollectionMapPlotInstruction          = The map plot
> is
> > invalid because it contains an unrecognized map plot instruction.
> > MgInvalidNode                                         = The node is
> > invalid
> > because it is not an element node or a document node.
> > MgInvalidWebTargetType                                = The web target
> > type
> > MgInvalidWebTargetViewerType                          = The web target
> > viewer type is invalid because it is not recognized.
> > MgInvalidWebWidgetType                                = The web widget
> > type
> > [FeatureService]
> > MgInvalidFdoProvider                                  = Invalid
> Feature
> > Provider specified.
> > MgBatchInsertNotSupported                             = Provider does
> > not
> > support batch insert. Only one Feature instance is allowed.
> > MgNoFeaturesForInsert                                 = No Features
> for
> > Insert supplied
> > Lic. Jorge Rubio
> > mapguide-internals mailing list
> > mapguide-internals at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapguide-internals
> Lic. Jorge Rubio
Lic. Jorge Rubio
More information about the mapguide-internals mailing list
