[mapguide-internals] Patch: Remove usage of DbXml private header
Helio Chissini de Castro
helio at kde.org
Fri May 11 15:23:02 EDT 2007
Em ven 11 mai 2007, Traian Stanev escreveu:
> Hi Helio,
> Just for information (so that you don't get a nasty surprise), compiling
> against external versions of the libraries is fine, except for gd. For gd
> you should use the source provided by MapGuide. It's ok to use external
> libraries for all of gd's dependencies (jpeg, png, freetype2, etc). I
> recently did a build on the newest Ubuntu and I also used a mix and match
> of external libraries (in particular I used the libACE that was available
> on the machine, since the one that came with MapGuide was not compiling for
> some reason).
> Traian
Ok, so i need disclose more info :-)
I already compiled full mapguide on purpose to create an RPM ( Mandriva in my
case ). I had the problem on the old gd, ( several crashes ) but now the
current version that i'm using with patches are ok. Is there something really
special inside mapguide gd that i miss ?
I'm using just SWIGEx internal.
As external deps, i'm using:
db-4.3.29, dbxml-2.2.13, ace-5.5.2, gd-2.0.34, xalan-c-1.10, xerces-c-2.7.0,
php-5.2.2.
I created packages for fdo and libdwf as well.
My nightmare was just libdwf, when compiling against x86_64. Mapguide itself
have some c++ issues with types during compilation, like have places where
function in defined as long long int in header, but implementation is using
FdoInt64, which compiles fine on i586, but breakes compilation in gcc x86_64.
Due my background as kde devel, i really hate from the deep of my heart
auto*tools, then i keep all mapguide source in sync, but recreated entire
mapguide buildsystem using CMake for the rpm purpose
Is completly working, and i would love to share if have someone interested.
CMake is "really" multiplatform, easy to manage, full textfile without stange
macros, and thanks God, reduce the size of tests tools and maintenance
burden. My current buildsystem is *nix only, but with a little work, can be
added to build on Mac and Windows as well, with one only buildsystem.
JFYI, even i needed to resync every new mapguide release, i prefer 10 times
work this way than using auto*tools again.
Hope i get things more clear.
[]'s
KDE Project South America Primary Contact
Curitiba - Brasil
More information about the mapguide-internals
