[mapguide-internals] Web API
Paul Spencer pspencer at dmsolutions.ca
Thu Nov 8 14:08:25 EST 2007
Kenneth,
we (DMSG) have a working MapGuide layer for OpenLayers that has not
yet been contributed.  Are you interested in collaborating on this?
The person responsible at this end is Mike Adair (cc'd)
Paul
On 8-Nov-07, at 2:01 PM, Kenneth, GEOGRAF A/S wrote:
> As I mentioned, I have been implementing an OpenLayers provider.
> When dealing with the GETMAPIMAGE the "layernames" are taken as
> GUID's.
> This only makes sense when the map is a runtime map, as it does not
> have GUID's in the MapDefinition.
> When using the QUERYMAPFEATURES the layernames are the actual names
> (at least thats how the AJAX viewer sends them).
> I am not sure that setting the "layernames" parameter actually has
> any effect.
> In the AJAX viewer, this line can be found:
>    var reqParams = "SESSION=" + sessionId + "&MAPNAME=" +
> encodeURIComponent(mapName) + "&SEQ=" + Math.random() +
> "&SELECTION=" + encodeURIComponent(selText) + "&QUERYINFO=" +
> (requery? "1": "0");
> Why is the OPERATION parameter missing?
> The GETMAPIMAGE and GETDYNAMICMAPOVERLAYIMAGE does not seem to re-
> read a changed runtime map, if the "SHOWLAYERS" or "HIDELAYERS"
> parameters have not been set, and the runtime map is altered on the
> server.
> Regards, Kenneth, GEOGRAF A/S
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
|Paul Spencer                          pspencer at dmsolutions.ca    |
|Chief Technology Officer                                         |
|DM Solutions Group Inc                http://www.dmsolutions.ca/ |
More information about the mapguide-internals mailing list
