[mapguide-internals] MGOS 2.0.0 Beta 1 posted formapguide-internals
Tom Fukushima tom.fukushima at autodesk.com
Tue Nov 20 18:37:57 EST 2007
Hi Jason,
I couldn't reproduce the .json mime type problem before, but I posted a new web tier installer that should set it correctly.  Can you verify that it fixes the problem?
Thanks
Tom
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Monday, November 19, 2007 2:31 PM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] MGOS 2.0.0 Beta 1 posted formapguide-internals
In general... pretty freakin cool.  I like that each of the layouts is
completely different.
The windows installer needs to be modified to add the following mime
type:
.json  -> application/json
Otherwise Fusion can't pick up its config file.
There are still some problems with the layouts though (at least in IE).
For instance, the zoom slider seems to be set to largest scale, and
doesn't appear to work.  And the type-in scale bar isn't placing the
scale in the correct location.  And the turquoiseyellow layout (at
least) seems to be created at a high screen resolution with no overflow.
I don't see all of "Refresh Map" on my 1280w screen.
There are a few more glitches, but I've got a meeting to get to...
Jason
Subject: [mapguide-internals] MGOS 2.0.0 Beta 1 posted
I've posted what a candidate for MGOS 2.0.0 Beta 1 to
http://download.osgeo.org/mapguide/releases/2.0.0-beta1/
Please try it out before I put it out for general consumption.
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
