[mapguide-internals] RE: Blue Highlight
Crispin at 1Spatial Crispin.Hoult at 1Spatial.com
Tue Oct 2 03:03:02 EDT 2007
That *is* just the ticket.
I worked it through whilst on a long train journey last night and was going
to post the same today... so I will instead confirm it is the GERenderer m_
variable that seems to count.
Only on AJAX though - I have red-dashed and light red flod fill in AJAX but
still solid-blue on DWF/Active-X.  The DWF highlight is obviously
client-side as it has enough geometry to rebuild... so where is the setting
here?
 Crispin
http://www.nabble.com/file/p12993789/Highlight.png
JasonBirch wrote:
> Doh, I should have refreshed my message view before hunting through the
> code for this:
> http://trac.osgeo.org/mapguide/browser/trunk/MgDev/Common/Renderers/GDRenderer.cpp#L1487
> I'll update the ticket...
> Jason
> ________________________________
> From: Traian Stanev
> Subject: RE: [mapguide-internals] Blue Highlight
> There is a very similar function in the GDRenderer.cpp that you would also
> need to modify.
> The one in SE_Renderer is used for the new symbology stuff only. If you
> were using an old-style, erm, style, then you would need to modify
> GDRenderer. Look for the function SetRenderSelectionMode.
> Traian
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
View this message in context: http://www.nabble.com/Blue-Highlight-tf4514163s16610.html#a12993789
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals mailing list
