[mapguide-internals] LoadPackage fails with SymbolDefinition
Kenneth, GEOGRAF A/S ks at geograf.dk
Thu Oct 4 04:18:06 EDT 2007
I have debugged a bit further on the problem, but my knowledge of the
DbXml is insufficient to understand the actual problem.
I can see that the thread waits forever for a lock on the database.
Since that thread is the only thread acessing the database, it should not.
The problem is seen with multiple datatypes, not just the SymbolDefinition.
I tried removing the SETRESOURCEDATA operations from the manifest in the
package, and everything runs fine.
Should I report this as a bug on the trac? Or is that for "release"
versions only?
I can supply a small package that has the error if anyone wants to debug it.
Regards, Kenneth, GEOGRAF A/S
Tom Fukushima skrev:
> Thanks.  I ran into a deadlock when loading the Sheboygan package as
> well with the latest code.  Good to see that it wasn't just my one
> machine.
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org
> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of
> Sent: Monday, October 01, 2007 1:09 PM
> To: MapGuide Internals Mail List
> Subject: [mapguide-internals] LoadPackage fails with SymbolDefinition
> While debugging some code, I discovered that the server will deadlock if
> I try to load a package containing a SymbolLibrary resource.
> I am not sure if the problem is with my build or general, but I just
> wanted to announce the problem so it does not survive into a release.
> I have the current "trunk" version of the source, and I have tracked the
> error to "nssax2reader.cpp:340". The problem operation is
> SETRESOURCEDATA.
> The call never returns, does not use 100% cpu and does not throw any
> exceptions.
More information about the mapguide-internals mailing list
