[mapguide-internals] RFC 38 - GETDYNAMICMAPOVERLAYEnhancementsforSelection
Trevor Wekel trevor.wekel at autodesk.com
Wed Oct 10 12:37:41 EDT 2007
Hi Jason,
Being able to specify a smaller bit-depth transparent image is an
interesting idea but I have a couple of questions/concerns on it:
Will using a smaller depth selection image make a significant difference
to the size of the image being returned?  I'm not sure what a "typical"
selection is but a single parcel is not a very complicated (or large)
image.
If we allow for smaller color depth then we will need to specify
different stylization rules for the selection.  Going from a 24 bit
color space to an 8 bit color space is significant. Using an 8 bit
indexed color scheme may be a reasonable tradeoff.  I will have to check
to see if the renderer can support on the fly the color space
transformation.  This would be a really slick optimization for overlay
images that contain less than 255 colors.
As for what happens with a null selection?  A transparent image should
be returned.
Good questions.  Thanks!
Trevor
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason
Birch
Sent: Wednesday, October 10, 2007 10:05 AM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] RFC 38 -
Having thought about it a bit, one thing that concerns me about this
proposal is that much of the apparent performance of MapGuide web apps
is now determined by the speed of the user's connection, primarily
because of the size of the images.
Is there any way that the selection-only image could be rendered with a
smaller bit-depth, and still have an alpha channel for decent rendering?
I do realize that there will be performance benefits when users are not
modifying their extents and doing multiple selections.  I guess the
client could also be smart enough not to request the selection layer
when there is nothing in the selection?  What would the API do when
called on a null selection?  Return an HTTP error, or a big transparent
image?
As far as selection colour goes...  I would like to see a more robust
option for selection style than just colour :)  Border width, border
style, border colour, fill pattern, fill colour, labelexpression,
labelstyle.  Yeah, I know I'm asking for too much...
Jason
Subject: RE: [mapguide-internals] RFC 38 - GETDYNAMICMAPOVERLAY
Hi Trevor,
Perhaps obvious from enumerator names but (I think it could be better if
that would be written in RFC) If BEHAVIOR is RenderSelection than
returned image is selection only?
If BEHAVIOR  is RenderSelection||KeepSelection than selection is stored
and will be returned on next get ?
When rendering (pan,zoom,..) viewer will use two requests (on for image
one for selection) instead of one request (if KeepSelection is not set)
While doing this change is it wise to add a parameter for color of
selection.
Haris
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
