[mapguide-internals] MG and .NET boilerplatte (MgServerExtensions)
Maksim Sestic max at geoinova.com
Wed Oct 31 12:37:44 EDT 2007
:-) Something's mixing up.
Huh, looks like complicated process :-) I'll use SourceForge.NET for
revision control, and make an installer to post the whole library in
"Samples" section as a single executable. This is a bit tough since I have
to make installer work for both MGE and MGOS, while I'm using MGE for
development. Or I can simply pack the solution up into archive and post it
as is, along with installation notes.
Regards,
Maksim Sestic
JasonBirch wrote:
> I was thinking that they could just be file attachments in the wiki, or
> even <code> sections in the text.
> If you need/want revision control for the samples, then I guess you'd
> have to look at signing a CLA, obtaining commit access through a vote of
> the PSC, etc, etc.  If we're going to do this for code samples, the we
> should probably have a larger discussion around the idea.
> Jason
> -----Original Message-----
> From: Maksim Sestic
> Subject: RE: [mapguide-internals] MG and .NET boilerplatte
> Jason, what's the directory for committing library source and binaries,
> along with API help and client-side examples? Is it possible to do the
> checkin within some "Branches" subdirectory? If it's not possible,
> should I commit the source somewhere else (i.e. SourceForge.NET) and
> publish a link to it under RFC?
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
View this message in context: http://www.nabble.com/MG-and-.NET-boilerplatte-%28MgServerExtensions%29-tf4711850s16610.html#a13513342
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals mailing list
