[mapguide-internals] initialization error
Mike Adair
madair at dmsolutions.ca
Fri Sep 14 15:57:51 EDT 2007
An update to this issue:
Restarting mgserver and mgapache wasn't working. What I did end up
doing was after uninstalling MG server and the web extensions. I renamed
the ProgramFiles/MapGuideOpenSource directory. That doesn't get deleted
when un-installing and has files left over there, one of which must have
been corrupted somehow.
A fresh install into a new directory seems to have worked, so far
anyway. I'll see if works when I switch networks this weekend.
Thanks for the help,
Mike
Tom Fukushima wrote:
> Hi Mike,
> When restarting the web tier I find that I have to:
> 1) Stop the apache service; "C:\Program
> Files\MapGuideOpenSource\WebServerExtensions\Apache2\bin\apache.exe" -k
> stop -n ApacheMapGuide
> 2) Kill any lingering MapAgent.exe and php-cgi.exe processes using
> taskkill.exe /F /IM php-cgi.exe and taskkill.exe /F /IM MapAgent.exe
> 3) Restart apache; "C:\Program
> start -n ApacheMapGuide
> If you switch from fastcgi to standard CGI, a simple restart of Apache
> would work.
> Not sure if this will solve your problem, but it's worth a shot.
> Tom
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org
> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Mike
> Adair
> Sent: Wednesday, September 12, 2007 12:46 PM
> To: MapGuide Internals Mail List
> Subject: Re: [mapguide-internals] initialization error
> Bob,
> I have been aware of having to restart MGserver once in a while, but
> this problem seems different. Restarting MGServer and/or ApacheMapGuide
> services didn't work in this case. Re-installing MGOS fixed the
> problem, until my laptop hibernated for the first time, and now
> restarting the service gives the exception below.
> Any other ideas? Are there some registry keys or files that I should
> look for?
> Mike
> Robert Bray wrote:
>> Mike,
>> You can get around it by simply restarting the MapGuide 1.2 Server
>> service after your laptop wakes up. This has been a persistent thorn
>> in my side for sometime, and this is the best workaround I have found.
>> I think there is also a track ticket for this somewhere, but it has
>> not been addressed yet.
>> Bob
>> Mike Adair wrote:
>>> Hi,
>>> I'm having a problem with MapGuide OS (1.2.0) starting up on my
>>> laptop, especially after it has hibernated or been moved to a
>>> different network. The error in the logs is:
>>> PHP Fatal error: Uncaught exception
>>> 'mgconfigurationloadfailedexception' in Unknown on line 0
>>> (This is from Fusion's CreateSession.php which normally works when
>>> MapGuide is up and running correctly).
>>> I was getting the same message using 1.2.0 RC2(?) so I uninstalled
>>> and then re-installed the stable release, which seemed to fix the
>>> problem for the day yesterday, but it has now re-appeared this
>>> morning. I'd rather not spend the day watching Vista reboot again,
>>> does anyone have any suggestions to fix this?
>>> Thanks in advance,
>>> Mike Adair
>>> mapguide-internals mailing list
>>> mapguide-internals at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
