[mapguide-internals] Is that a BUG?adding a temp layer to map,
 Map.Save() raise MgNotImplementedException
    Champin
    champingfor at 163.com
    Tue Sep 25 13:01:27 EDT 2007
Is that a BUG?adding a temp layer to map, Map.Save() raise
I have post some thread in MapGuide  Users list,but there is no answer yet.
http://www.nabble.com/map.Save%28%29-raise-MgNotImplementedException%EF%BC%8Cprogrammatically-add-layer-to-a-map-tf4510561s16610.html
http://www.nabble.com/How-to-Create-a-layerDefinition-programmtically-%2C-using-xml--tf4514122s16610.html
Map.Save(Resource) raise MgNotImplementedException when I am trying to save
the temp layer to the map.
the same code goes well in MGE 2007(MGOS 1.1?) but failed in MGOS 1.2.
so, is this a bug? if not, what am i doing wrong?
Thanks
View this message in context: http://www.nabble.com/Is-that-a-BUG-adding-a-temp-layer-to-map%2C-Map.Save%28%29-raise-MgNotImplementedException-tf4516885s16610.html#a12883984
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals
