[mapguide-internals] Blue Highlight
Traian Stanev traian.stanev at autodesk.com
Sun Sep 30 23:32:12 EDT 2007
There is a very similar function in the GDRenderer.cpp that you would also need to modify.
The one in SE_Renderer is used for the new symbology stuff only. If you were using an old-style, erm, style, then you would need to modify GDRenderer. Look for the function SetRenderSelectionMode.
Traian
	-----Original Message-----
	From: mapguide-internals-bounces at lists.osgeo.org on behalf of Jason Birch
	Sent: Sun 9/30/2007 11:18 PM
	To: MapGuide Internals Mail List
	Cc:
	Subject: RE: [mapguide-internals] Blue Highlight
	Hi Crispin,
	In that report I was just guessing as to where the change would have to be made.  The images were of what I was able to achieve with a workaround that DM Solutions came up with, but it was an application-specific solution for a printable page, not interactive selection.
	Jason
	From: mapguide-internals-bounces at lists.osgeo.org on behalf of Crispin @ 1Spatial
	Sent: Tue 2007-09-25 1:43 AM
	To: mapguide-internals at lists.osgeo.org
	Subject: [mapguide-internals] Blue Highlight
	Having gone through the joy of a MGServer build just to demo a non-blue
	highlight I edited the code in SE_Renderer as per
	http://trac.osgeo.org/mapguide/ticket/116 but still got a blue highlight!
	Jason - were the images created "mocked-up" or did you create a live
	application?
	 Crispin
	View this message in context: http://www.nabble.com/Blue-Highlight-tf4514163s16610.html#a12875406
	Sent from the MapGuide Internals mailing list archive at Nabble.com.
	mapguide-internals mailing list
	http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
