[mapguide-internals] Quotes around halfline and center
Zac Spitzer zac.spitzer at gmail.com
Tue Dec 16 20:41:07 EST 2008
I'm guessing there's a bit of a performance overhead involved there?
exacerbated when using a tiled map?
On Wed, Dec 17, 2008 at 2:00 AM, Ben Trumbore <ben.trumbore at autodesk.com> wrote:
> OK, I see that the apostrophes are missing.  That isn't correct, but the layer still renders as expected, right?  I created a default polygon layer with Studio 2010, and it includes the apostrophes.
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
> Sent: Monday, December 15, 2008 5:56 PM
> To: MapGuide Internals Mail List
> Subject: Re: [mapguide-internals] Quotes around halfline and center
> I just created a quick sample layer as a test using studio 2009 and
> 2.0.2 which is attached
> On Tue, Dec 16, 2008 at 9:52 AM, Ben Trumbore <ben.trumbore at autodesk.com> wrote:
>> Zac,
>> Are you sure it does that?  I checked the style editor code history and the apostrophes have been included since at least mid-2005.  The UI dropdown doesn't show the apostrophes, but it adds them to the layer when you make a selection.
>> I think the stylization engine is also a bit tolerant of missing apostrophes.  If it fails to obtain a value for what it thinks is a property name, it treats it as a constant string, which in this case has a meaningful value.  Traian can correct me if I'm mistaken.
>>        Ben
>> Spitzer
>> Sent: Monday, December 15, 2008 5:31 PM
>> Thanks Ben!
>> So why does studio 2009 insert them without quotes?
>> z
>> On Tue, Dec 16, 2008 at 1:59 AM, Ben Trumbore <ben.trumbore at autodesk.com> wrote:
>>> Zac,
>>> Most of the stylization elements are defined as FDO expressions.  So,
>>>        <VerticalAlignment>Halfline</VerticalAlignment>
>>> says to take the vertical alignment value from a feature property named Halfline, where
>>>        <VerticalAlignment>'Halfline'</VerticalAlignment>
>>> declares a constant value for the vertical alignment.
>>>        Ben
>>> Spitzer
>>> Sent: Monday, December 15, 2008 3:29 AM
>>> Subject: [mapguide-internals] Quotes around halfline and center
>>> Out of interest, what is the reason for having quotes around some of
>>> the stylisation stuff?
>>> ie
>>> z
>>> Zac Spitzer -
>>> http://zacster.blogspot.com
>>> +61 405 847 168
>>> mapguide-internals mailing list
>>> mapguide-internals at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
>> Zac Spitzer -
>> +61 405 847 168
> Zac Spitzer -
> +61 405 847 168
Zac Spitzer -
+61 405 847 168
More information about the mapguide-internals mailing list
