[mapguide-internals] Vote: Make MGOS 2.0.0 RC4 the release
Jason Birch Jason.Birch at nanaimo.ca
Thu Feb 21 11:36:05 EST 2008
Hi Tom,
This problem seems to be Fusion-specific, and is the same as a selection problem that I have recently reported to Paul privately.  Basically, when you perform a selection, Query.php comes back with a bunch of exceptions.  J Manafi's report shows this (mine was slightly different):
Object not found
ERROR: The specified object was not found.
The specified object was not found. Exception occurred in method GetItem at line 117 in file d:\buildforgeprojects\mapguide_open_source_v2 .0\build_21.9\mgdev\common\foundation\Data/NamedCollection.cpp - GetItem line 117 file d:\buildforgeprojects\mapguide_open_source_v2.0\build_21.9\mgdev\common\foundation \Data/NamedCollection.cpp
{"hasSelection":false}
If there is a new Fusion build that fixes this problem at some point, would it be possible to quickly release a 2.0.0.1 build with only the new Fusion?
Jason
Subject: RE: [mapguide-internals] Vote: Make MGOS 2.0.0 RC4 the release
Hi Jason,
I don't know of a ticket for this or how to determine whether it is a showstopper or not from the information you have provided below.
Tom
More information about the mapguide-internals mailing list
