[mapguide-internals] RE: MapGuide RFC 51 - Raster Re-projection
Walt Welton-Lair walt.welton-lair at autodesk.com
Fri Jul 18 13:56:32 EDT 2008
Tony,
Do you plan on updating DWF Renderer support so that DWF Viewer can display the reprojected rasters?
Walt
-----Original Message-----
Sent: Wednesday, July 16, 2008 2:34 PM
To: MapGuide Internals Mail List
Subject: RE: MapGuide RFC 51 - Raster Re-projection
GD renderer will (hopefully) soon be removed.  I should write a quick RFC for that...
Tony - consider renaming the TileSize parameter to GridSize.  We already use the word "tile" in the context of the TileService, and using a different name would reduce confusion.
Walt
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Steve Dang
Sent: Wednesday, July 16, 2008 2:28 PM
Subject: [mapguide-internals] RE: MapGuide RFC 51 - Raster Re-projection
1. Does this feature work with both GD and AGG renders? or just the AGG?
2. To simplify the INI file content, should we have the TileSize property under the RenderingServiceProperties section?
Steve.
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Tony Fang
Sent: Tuesday, July 15, 2008 11:36 AM
To: mapguide-internals at lists.osgeo.org
Subject: [mapguide-internals] MapGuide RFC 51 - Raster Re-projection
I would like to submit MapGuide RFC 51 - Raster Re-projection for review and comment.
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc51
Thanks,
Tony
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
