[mapguide-internals] RFC 50 - Hide Legend Styles
Bruce Dechant bruce.dechant at autodesk.com
Mon Jul 21 11:22:25 EDT 2008
Maksim,
The clients will need to be enhanced in order to use the changes proposed here.
The changes to the clients are outside this RFC. Even after this change if you prefer to edit XML manually you can still do that. Ie: Whether to show the style in the legend or not.
Thanks,
Bruce
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Maksim Sestic
Sent: Saturday, July 19, 2008 3:22 AM
To: 'MapGuide Internals Mail List'
Subject: RE: [mapguide-internals] RFC 50 - Hide Legend Styles
Bruce,
I know, that's why I was curios about RFC proposing XML definition change.
Shouldn't it propose client(s) functionality enchancement?
Regards,
Maksim Sestic
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Bruce
Dechant
Sent: Friday, July 18, 2008 18:56
To: MapGuide Internals Mail List
Maksim,
The reason for the RFC is so that the information is maintained in the XML
so that you can avoid the manually adding/removing the style information.
Instead, you will be able to use the client to just mark the style as not
displayed in the legend using either Studio or Maestro.
Thanks,
Bruce
Sestic
Sent: Friday, July 18, 2008 9:53 AM
Hi Bruce,
You can change it manually (it's XML definition) and import it back. Then
you won't see unused geometries in both MG Studio or legend. BTW, I'm doing
it all the time :-) Maybe it's not up to the definition itself, it's rather
editor (MG Studio) that should take care of that when saving layer
definition back onto the server.
Regards,
Maksim Sestic
Dechant
Sent: Friday, July 18, 2008 17:11
Subject: [mapguide-internals] RFC 50 - Hide Legend Styles
I would like to submit MapGuide RFC 50 - Hide Legend Styles for review and
comment.
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc50
Thanks,
Bruce
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
__________ NOD32 3278 (20080718) Information __________
This message was checked by NOD32 antivirus system.
http://www.eset.com
__________ NOD32 3281 (20080718) Information __________
http://www.eset.com
More information about the mapguide-internals mailing list
