[mapguide-internals] MapGuide RFC 49 - EnhanceServerErrorReporting
Jason Birch Jason.Birch at nanaimo.ca
Mon Jun 16 23:18:50 EDT 2008
If this was the case it would have to be configurable.  I hate it when systems display anything but generic error messages by default; too much potential for system information leakage.
One of our production asp sites (a proprietary CMS) got hit with a sql injection attack a couple weeks ago and one of the vectors that allowed for easy exploitation was that asp was not configured to supress errors. I'm a bit gun-shy still :)
Jason
----- Original Message -----
From: mapguide-internals-bounces at lists.osgeo.org <mapguide-internals-bounces at lists.osgeo.org>
To: MapGuide Internals Mail List <mapguide-internals at lists.osgeo.org>
Sent: Mon Jun 16 20:01:43 2008
Subject: Re: [mapguide-internals] MapGuide RFC 49 - EnhanceServerErrorReporting
If there is going to be a TreatWarningAsError mode, it's might be
worth considering when rendering an image, to act like
some other some map servers and render the error message into the image
z
On Tue, Jun 17, 2008 at 12:46 PM, Trevor Wekel
<trevor.wekel at autodesk.com> wrote:
> Well...
> I was chatting with Bruce about this one today but it could have some negative impacts.  I could add a "TreatWarningAsError" parameter to serverconfig.ini.  This would upgrade all warnings to full blown exceptions with complete stack trace information.
> It could be difficult to implement depending on catch logic but I will investigate it.  And it would completely kill your map unless all the stylization, labels, etc, were 100% perfect.
> Trevor
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
> Sent: Monday, June 16, 2008 8:36 PM
> To: mapguide-internals at lists.osgeo.org
> Subject: Re: [mapguide-internals] MapGuide RFC 49 - Enhance ServerErrorReporting
> Thanks for follow-up. Gotta love a layman asking for the impossible, eh?  :)
> I'm personally not convinced that continuing on exception is a good strategy. It reduces the likelihood that a problem will be noticed and reported, and increases the likelihood of publishing information that is incorrect when displayed out of context.
> Sent: Mon Jun 16 19:10:01 2008
> Subject: RE: [mapguide-internals] MapGuide RFC 49 - Enhance ServerErrorReporting
> Hi Jason,
> FDO uses a different set of classes for exceptions and changing core FDO code is a little out of scope for a MapGuide RFC.  The MapGuide Server is capable of catching FDO exceptions but we will not get any stack or call parameter information from FDO.
> There's a couple of places where we can trap FDO exceptions:
> 1. Direct API calls to FeatureService from scripts, etc.
> These calls should throw the FDO exception and return the FDO exception message, the MapGuide stack trace, and the MapGuide call parameters.
> 2. Calls to FDO via the Stylizer (i.e. MappingService)
> The stylizer catches FDO exceptions.  I have added a hook allow the MapGuide Server to log these exceptions as warnings.  Since we do not throw them, it is impossible to generate a stack trace and still maintain the same functionality.  If we throw, we will fail the stylization on all the layers and not just the bad one(s).
> However, the trace log will tell you what was executing at the time.  It is not as clean as a stack trace but it should be functional.  The trace log in the RFC is an example of this.  The MgStylizationUtil.ExceptionTrap is written into the trace log file and all of the entries above it are on the same thread (4972) so they apply to that exception.  The warning is also written to the error log but it does not give the stack information.
> As for more FDO information, the MgServerFeatureService.SelectFeatures does contain a fair bit of information:
> Resource=Library://Samples/Sheboygan/Data/VotingDistricts.FeatureSource
> ClassName=SDF_2_Schema:VotingDistricts
> Options={{Operator=1}{GeomProp=Data}{GeomOp=10}{Geometry=POLYGON ((-87.783866628374042 43.691398128787803, -87.676641873488435 43.691398128787803, -87.676641873488435 43.797520000480297, -87.783866628374042 43.797520000480297, -87.783866628374042 43.691398128787803))}}
> Thanks,
> Trevor
> Sent: Monday, June 16, 2008 7:28 PM
> Subject: Re: [mapguide-internals] MapGuide RFC 49 - Enhance Server ErrorReporting
> Yes please :)
> Absolutely in favour of this.  It would be great to be able to know what queries and/or data are causing problems. Right now it is hard to file a small reproducible bug report.
> Does/will this turn on tracing inside FDO also?  Is that an option?  This would make it easier for provider developers to see what mapguide is doing when things go awry :)
> Jason
> Sent: Mon Jun 16 17:57:45 2008
> Subject: [mapguide-internals] MapGuide RFC 49 - Enhance Server ErrorReporting
> I would like to submit MapGuide RFC 49 - Enhance Server Error Reporting for review and comment.
> http://trac.osgeo.org/mapguide/wiki/MapGuideRfc49
> Thanks,
> Trevor
> mapguide-internals mailing list
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
More information about the mapguide-internals mailing list
