[mapguide-internals] Re: build error mapguide 20x branch svn
Zac Spitzer zac.spitzer at gmail.com
Thu May 15 01:10:57 EDT 2008
i reverted to r3166 and have successfully compiled on RHEL 4. Its up
and running and looking good, we doing some testing now.
I did see one error running the server interactively
(2756062112) A stream IO exception occurred.
The TCP/IP protocol is mismatched between the Server and Web
Extensions.  Please install the same version of Server and Web
Extensions.
Exception occurred in method MgStreamParser.ParseStreamHeader at line
91 in file System/StreamParser.cpp
Apache still has to be restarted sometimes in order to be able to
restart mapguide
z
On Thu, May 15, 2008 at 2:31 PM, Tom Fukushima
<tom.fukushima at autodesk.com> wrote:
> BTW, this problem is not in the posted 2.0.1.2715 tar ball.
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
> Sent: Wednesday, May 14, 2008 9:13 PM
> To: MapGuide Internals Mail List
> Subject: [mapguide-internals] Re: build error mapguide 20x branch svn
> looks like it was this changeset
> http://trac.osgeo.org/mapguide/changeset/3168
> On Thu, May 15, 2008 at 1:10 PM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
>> I just hit this error compiling off the 20x subversion branch on RHEL 4
>>  g++ -DPACKAGE_NAME=\"mapguide\" -DPACKAGE_TARNAME=\"mapguide\"
>> -DPACKAGE_VERSION=\"2.0.1\" "-DPACKAGE_STRING=\"mapguide 2.0.1\""
>> -DPACKAGE_BUGREPORT=\"http://mapguide.osgeo.org\"
>> -DPACKAGE=\"mapguide\" -DVERSION=\"2.0.1\" -DPACKAGE=\"mapguide\"
>> -DVERSION=\"2.0.1\" -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1
>> -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1
>> -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1
>> -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1 -DSTDC_HEADERS=1
>> -DHAVE_UNISTD_H=1 -DHAVE_MATH_H=1 -DHAVE_NETDB_H=1
>> -DHAVE_NETINET_IN_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_SOCKET_H=1
>> -DHAVE_GETHOSTBYNAME=1 -DHAVE_SOCKET=1 -DHAVE_HTONS=1 -DHAVE_CONNECT=1
>> -DHAVE_SHUTDOWN=1 -I. -I. -I../MdfModel/ -I../Foundation
>> -I/usr/local/fdo-3.3.0/include
>> -I/usr/local/fdo-3.3.0/include/ExpressionEngine
>> -I../../Oem/ACE/ACE_wrappers -O2 -g -pipe -march=i386 -mcpu=i686
>> -fno-use-cxa-atexit -fexceptions -MT SE_AreaPositioning.lo -MD -MP -MF
>> .deps/SE_AreaPositioning.Tpo -c SE_AreaPositioning.cpp  -fPIC -DPIC -o
>> .libs/SE_AreaPositioning.o
>> SE_AreaPositioning.cpp: In constructor
>> `SE_AreaPositioning::SE_AreaPositioning(LineBuffer*,
>> SE_RenderAreaStyle*, double)':
>> SE_AreaPositioning.cpp:59: error: `_isnan' was not declared in this scope
>> make[2]: *** [SE_AreaPositioning.lo] Error 1
>> make[2]: Leaving directory `/var/www/mg20x/2.0.x/MgDev/Common/Stylization'
>> make[1]: *** [all-recursive] Error 1
>> make[1]: Leaving directory `/var/www/mg20x/2.0.x/MgDev/Common'
>> make: *** [all-recursive] Error 1
>> [root at gis MgDev]#
>> Zac Spitzer -
>> http://zacster.blogspot.com (My Blog)
>> +61 405 847 168
> Zac Spitzer -
> +61 405 847 168
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer -
+61 405 847 168
More information about the mapguide-internals mailing list
