[mapguide-internals] MapGuide Open Source 2.1 -whereisthecontinuous integration system ????
Tom Fukushima tom.fukushima at autodesk.com
Mon Nov 17 16:44:42 EST 2008
Hi Jason,
Jason wrote:
> IIS installation is likely going to be a bit of a challenge.  WiX
> includes an extension for IIS, but it's not all that well documented.
I believe we have a "custom action" to do this in the current installer.  If WiX can run "custom actions", perhaps as a separate executable, we can get the source code for this and use it.  Can you check to see what WiX supports here?
Thanks
Tom
More information about the mapguide-internals mailing list
