[mapguide-internals] Autodesk.MapGuide.Studio.Site.LayerInfo.Save
ljv johan.vikstrom at gmail.com
Mon Nov 24 09:31:43 EST 2008
Thx, i will check with em.
But the server has the same problem, without the culture set (as default)
all text search and replace takes very long time (used when parsing
layouts).  To use the map without setting culture is impossible. The problem
is in the dotnet code.  If a create an  empty web  app that search and
replaces text in the same manner as the mapserver the  response is also
slow.  It's around 1000 times slower than if you set the culture.
ljv wrote:
> I find this (Autodesk.MapGuide.Studio.Site.LayerInfo.Save) functions slow,
> 2-4 seconds to save 2kb.
> There is no problem with server or network, most functions are fast.
>  Except for this: In web.config globalization Culture="xxxx" must be set.
> Unless the culture is explicite set all strings functions like search
> become so slow that the application is useless. Both maestro and mapstudio
> benefit from adding culture to web.config. we have used our
> culture="sv-SE" and English variants and setting the culture speeds the
> viewer and application.
View this message in context: http://www.nabble.com/Autodesk.MapGuide.Studio.Site.LayerInfo.Save-tp20317706p20661930.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals mailing list
