[mapguide-internals] Fusion - Base layers questions...
    Jason Birch
    Jason.Birch at nanaimo.ca
    Tue Oct  7 12:04:39 EDT 2008
Doh.  Used the wrong address for the Fusion developers list.  Please
ensure that if you follow up it goes to fusion-dev at lists.osgeo.org.
Jason
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason
Birch
Sent: Tuesday, October 07, 2008 09:00
To: fusion-internals at lists.osgeo.org
Cc: MapGuide Internals Mail List
Subject: [mapguide-internals] Fusion - Base layers questions...
Hi all,
I recall there was some intention to support arbitrary OpenLayers layers
in Fusion 2.0.  I guess the first question is whether this is still the
intention or has it already been implemented?
Sort-of related, I have some questions about base (tiled) layers in
Fusion.  I think I saw an update a while back that would support the
MapGuide convention of specifying base layer groups as part of the map
definition.  If I didn't imagine it, this is a good enhancement, but
last I saw there are some real problems with base layer groups in
MapGuide; basically: any change in the map definition flushes the tile
cache.  My preference would be to work around this with Fusion by
creating a map that only includes a base layer group, and then
referencing this as a separate base layer.  Is it possible to add
multiple Maps to a MapGroup, and specify which should be a base layer?
If so, is it possible to add multiple base layers?  Will the Legend
present these as a radio choice like in OpenLayers?
If not, is there any intention to add any of this functionality for 2.0?
Motivation:  I understand that we're only a couple weeks from MapGuide
2.1 beta, and it's currently following Fusion trunk... :)
Thanks,
Jason
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
