[mapguide-internals] MapGuide open source builds
Zac Spitzer zac.spitzer at gmail.com
Wed Oct 8 12:01:54 EDT 2008
here's the relevant thread...
http://www.nabble.com/FDO-RFC-21---New-Linux-Buildsystem-Cmake-Based-td17342406.html
On Thu, Oct 9, 2008 at 2:57 AM, Traian Stanev
<traian.stanev at autodesk.com> wrote:
> Someone (Helio...) implemented a cmake build system for FDO and MapGuide recently, with all the external dependencies sorted out. As far as I remember, it didn't make it past the RFC stage, but you may be able to get a hold of his cmake files to try out.
> Traian
>> -----Original Message-----
>> From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-
>> internals-bounces at lists.osgeo.org] On Behalf Of Gabriele Monfardini
>> Sent: Wednesday, October 08, 2008 11:47 AM
>> To: MapGuide Internals Mail List
>> Subject: Re: [mapguide-internals] MapGuide open source builds
>> IMHO the only viable approach should be to have the possibility to
>> build using free tools.
>> This because in this way it is possible to build from EVERY tool, with
>> a little effort.
>> Clearly more advanced features (installer creation and so on) may be
>> available only using some selected non-free tools, but I don't think
>> it is a good idea to cut user base with a non-free tool.
>> > and most serious Windows developers probably be running at least
>> Standard anyway
>> ... there's a lot serious NOT Windows developers out there ...
>> Building under Linux is incredibly tough and frustrating even for
>> expert users
>> - It should be done as a superuser (very very unusual and not safe)
>> - it strangely goes to the end even if there are errors (that forces
>> to frustrating reviews of log files)
>> - many trivial and not so trivial corrections should be made manually
>> in some inner makefiles
>> - dependencies from third-party libraries are handled quite poorly
>> - there are some strange situations (i.e. it creates directory fdo-3.2
>> even if building fdo-3.3 inside)
>> - very often it does not complete succesfully even with standard
>> parameters.
>> The fact is that all these problems have not been mitigated going from
>> 1.2 release to 2.x.
>> All these situations may happen if a project is in 0.2 alpha, but are
>> not so usual when version have major number 2 (i.e. is considered
>> stable). One would expect to download the sources, configure, build
>> and to be ready to try.
>> Using a non-free tool to build the project obviously will limit
>> furthermore the adoption in non windows environment.
>> IMHO it is not a good result for an open source project.
>> Why don't use something like cmake (http://www.cmake.org/)?
>> My 2 cents,
>> Gabriele
>> On Wed, Oct 8, 2008 at 01:17, Jason Birch <Jason.Birch at nanaimo.ca>
>> wrote:
>> > I've reversed my opinion on this one...
>> > While I think it's important that FDO/MapGuide build using Visual
>> Studio
>> > Express, I think it would be reasonable for merge module and
>> installer
>> > creation to require a non-free Visual Studio (I believe that Standard
>> is
>> > the lowest level, and includes all of the setup project support that
>> > Professional has).  I'd imagine that most developers would be happy
>> > running the server from its build location, and most serious Windows
>> > developers probably be running at least Standard anyway.  This is a
>> > reasonable compromise between InstallShield (ouch) and NSIS (no
>> MSIs).
>> > Jason
>> > From: Jason Birch
>> > Subject: RE: [mapguide-internals] MapGuide open source builds
>> > While Visual Studio Pro may meet the project's needs for
>> build/install,
>> > I would personally prefer a system that used free tools.
>> > _______________________________________________
>> > mapguide-internals mailing list
>> > mapguide-internals at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
More information about the mapguide-internals mailing list
