[mapguide-internals] MapGuide open source builds - Linux & Cmake
Helio Chissini de Castro helio at kde.org
Thu Oct 9 22:46:19 EDT 2008
On Quinta 09 Outubro 2008 22:58:47 Zac Spitzer wrote:
> That was an interesting article Gabriele, if a major project like KDE
> is using CMake
> and it's as easy Traian found, plus it already works, lets put together a
> RFC.
> If it only requires some additional files which can co-exist with the
> current build
> system (for now), lets get Helio's work into the source tree and give it a
> go
> On Fri, Oct 10, 2008 at 6:41 AM, Gabriele Monfardini
Ok, did my appointments here and can give more input.. or.. no.. better :-)
On Saturday or Sunday i will make available my current almost ready cmakefied
mapguide, with:
- Tests for external dependencies ( as Gabriele pointed )
- Internal dir dependencies to make possible a paralel building wihtou
breaking the chain ( btw, at Mandriva labs i compiled with a make -j 30 in our
icecream distributed compiler environment ).
- so'naming libraries, to have proper .so.<VERSION>
- All necessary ThirdParty tools removed except the required ones, like gd.
Some tidbits
- Some patches are needed to compile against 64, but minor ones
- Now i have FDO been tested against my cmake version. I will change the test
to match a auto*tools current installation
- Some different steps than the current instructions is needed to setup
external apache. I will detail that ones.
I just not push it today because i want deliver it with trunk, my current one
is 2.0.0 only and is better present a up-to-date experience.
If someone become curious about the compiler cluster, is all open source and
free and if you are like me have more than one machine in network, worth a
lot: http://en.opensuse.org/Icecream
[]'s
KDE Project
Brasil and South America Primary Contact
More information about the mapguide-internals mailing list
